03-14-2015, 09:34 AM | #1 |
657
Rep 1,749
dctnot handling tune especially between shifts
I run ess tune and after trying all of their 3 tunes on the box I settled on linear tune. part of the reason I noticed with more boost than the 21 to 22 , full throttle shifts are met with a big disruption in a shift at at 2 to 3 or even 3 to 4. This may be engine not happy?
The other thing I don't like is in d3 mode going on freeway at 70 let's say snd you stomp the pedal, normally and with linear tune , the dct will instantly drop to 3rd and rocket off. However with all power increase if I try that, it seems dct slips snd won't bite right away? It seems 480 to 500 whp and dct isn't happy but if it's same unit as f10 why is that? |
03-14-2015, 10:02 AM | #3 |
Croatian
884
Rep 3,613
Drives: PORSCHE
Well you're running way more boost than your ECU and DCT are thinking they are. Hence DCT isn't applying enough force to capture the discs.
Just a thought.
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
03-14-2015, 10:20 AM | #5 |
Gone Fishin’
7318
Rep 12,125
Stock US MDM? May just be the nannies kicking in imo. Until I turned on Euro MDM it was like 0 spin in my car. Plenty are running the dct at a much higher power # and a piggy.
03-14-2015, 10:22 AM | #6 |
1357
Rep 3,349
I've heard doing a factory reset/adaption will help, if it is in fact the DCT.
Not sure what all is involved in that. It's all in the settings... The only thing what would help this is to get a DCT tune to increase clamping pressure... Which hasn't been done yet.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
03-14-2015, 10:29 AM | #9 | |
1357
Rep 3,349
Terry just doesn't want to wait because Gintani is being flakey after they said they'd flash it, and never responded, then said they were working on it, only to flake out again... I guess that's not the first time they've done this.
03-14-2015, 10:31 AM | #10 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
Sorry OP
03-14-2015, 10:34 AM | #11 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
03-14-2015, 10:35 AM | #12 |
329
Rep 984
Is this happening with DSC off? If you have DSC on, or MDM on, that's what is going own. If DSC is off, I know what you're talking about, and yes it is the clutch slipping. Just wait, the more boost you run the worse it gets
Just incase others are not aware, even on lower boost settings (e.g. MAP 2) the DCT clutch will slip for a split-second until it catches.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
03-14-2015, 10:39 AM | #13 |
657
Rep 1,749
I guess I'll need to do more trials with traction off, mdm on vs off etc as I can't be certain now which settings I've had on which tune.
I know for me the sweet spot from a former e92 v8 guy is the ess linear tune adding 3 to 4 psi boost in a progressive fashion that pulls in a more linear fashion to redline as it keeps power at 460whp from 5400 to 7400. no lag, shifts hard but smooth and it's a lot of fun. Sometimes people get caught up in max power dyno but more boost seems to add lag, less ability to put power down and less linear feeling. However I'm still frankly interested in answering my own dct question so I'll play this weekend on trying scenarios |
03-14-2015, 11:03 AM | #16 |
23
Rep 210
03-14-2015, 11:03 AM | #17 | |
Gone Fishin’
7318
Rep 12,125
03-14-2015, 11:18 AM | #18 |
657
Rep 1,749
I like a turbo kick buy if it can't put power down or you need to roll into it more, you are effectively creating a more linear delivery with your foot. I like as much kick as possible with dct biting hard, no disruption at full throttle shifts and not having to overly feather the throttle
03-14-2015, 11:32 AM | #19 | |
1357
Rep 3,349
Terry is trying to get that done to see if it works out on the pure care.
03-14-2015, 02:24 PM | #21 | |
289
Rep 1,575
Hopefully Terry's Dodson upgrade will work out...however it's a pricey upgrade $1,500 labor + $1871usd (2550nzd) for 800ftlb clutches |
