03-09-2015, 07:27 PM | #1 |
21
Rep 84
E92 M3 alloys issue!!!!!
Iv had my wheels balanced and checked for leaks, double spoke polished alloys, when hitting a pot hole it sends a funny shiver through the steering wheel, has anyone else experienced any kind of issues with the Oem wheels..any guidance will be much appreciated, thanks :thre adjacked:
03-09-2015, 07:32 PM | #2 |
4986
Rep 11,891
does it happen every time you hit a bump?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
03-09-2015, 07:37 PM | #3 |
3284
Rep 6,726
Worn steering coupler? Do these have the same style steering coupler as the E46 M3 did? I know those wore and could cause a funny shake sometimes.
You'll have to define "funny shiver" since hitting potholes will typically make your steering wheel shake |
03-09-2015, 07:50 PM | #5 |
3284
Rep 6,726
That looks more like something is broken or worn on your suspension. Almost like a tram lining effect.
Have you looked underneath, removed your wheels and check for broken tie rods or end links? I think one of those are common, I just can't remember which. You can search. |
03-09-2015, 07:52 PM | #6 |
21
Rep 84
Iv checked all suspension at front and everything seems in order, I did however put some 19" aftermarket alloys and take a drive, seemed to drive a lot better..
03-09-2015, 08:49 PM | #8 |
11586
Rep 12,728
if the wheels balanced fine, and the tires are in good condition (not previously ran with bad alignment and uneven wear), then its a worn suspension component.
Instagram; @roastbeefmike
03-09-2015, 10:23 PM | #10 |
3284
Rep 6,726
You said you swapped with aftermarket wheels and it drove a lot better. Assuming it was a staggered setup, sounds like your wheels/tire combo is at question.
Are you running a staggered setup? Maybe you have a slight bend in the wheel and aren't seeing it |
03-10-2015, 03:05 PM | #15 |
377
Rep 2,982
suspension bushings? How old is your car. Beat up bushings will vibrate a lot on hard braking and it'll cause crappy tire wear. Check the whole thing inside and out. Typically hitting potholes shakes the whole car, not just the steering wheel...
03-10-2015, 07:38 PM | #16 |
21
Rep 84
2008 59k miles, manual.. I hate the cowboy mechanics that chat a load but don't know what's going on.. N the dealers just like to rob you blind.. I'm from West Yorkshire and wouldn't mind travelling to see a good solid mechanic..
