03-02-2015, 10:26 AM | #1 |
445
Rep 1,529
Drives: YMB F80 M3
Arma Speed Carbon Fiber Intake System REVIEW!
This is a review for all of you who are interested in the Arma Speed Intake system or any after market intake system to replace your stock one. I was able to win a system from Arma Speed and knew very little about them. I only found out about the contest after a fellow member on here posted about the contest. After seeing his system and the pictures of the carbon fiber quality I was determined to win.
Why change the intake system? Ever since I picked up my M3 I knew I wanted to go above and beyond on my mods. Coming from a E90 335i to the M3, it was a huge jump. With the car still being so new, many companies are still trying to develop a intake system. From previous experience, a after market intake system helps with airflow in the filters, sound of the turbo/spool (335i was twin turbo) and potential horsepower gain. With the new M3/M4 being so quite I hoped that an intake system might make it sound a little better. Arma Speed Intake: After seeing pictures of the development of the intake system, here on the forums, I was interested in the build quality and how it would look in the engine bay. When I first opened the box with all the parts inside. I saw that Arma Speed wrapped everything up nicely to ensure that the carbon pieces were not scratched. After taking out the first piece I was shocked at how light the pieces were compared to OEM and how great the weave looked in person. As I tore the packaging apart, exposing more and more pieces, I got really excited as to how it would look in the engine bay. I was most interested in the filter design. Arma has incorporated a valve feature, which they claim can help with Torque at low rpms. Install: As soon as I received my package with the Arma Speed intake system I was on my way over to Long and company at LTMW for the install. I have always gone to LTMW for all my car part installs and they have never disappointed. LTMW is great and always delivers great service. All the guys that work there are fantastic! The install was super easy and straight forward no issues what so ever. Quality: The Arma Speed intake system was very well made. The pieces and fitment was spot on except for the center piece (which was hitting the hood but they have since fixed this issue). The carbon fiber weave complimented the Carbon Fiber Brace that was already in the engine bay. I inspected each piece individually and found no flaws at all. It was a very nicely made product and I was very impressed! First impressions (Sound-start up): After installing the intake system, I started the car to see if there was a difference. First thing I did was let the car warm up a little after it had been sitting, due to the install. After revving it a little I could hear the turbo spools were louder and a whoosh sound when letting off the throttle. I was really impressed with the sound so far but was eager to drive it on the street and see how it performs in real life. First impression (Driving): Right away when I was backing the car outside you can hear slight differences in the engine bay. When I got outside the lot of LTMW, I did a little pull and instantly could hear the sucking of air through the windows. It was a memorizing sound!! On downshifts you can hear slight blurps in the engine bay also. From the inside with the windows up, you can clearly tell there was a difference in how the car sounds. But I was eager to test it on a full day of driving since the following day I was going to do the Targa Trophy Holiday Cruise. Full day of driving impression: After driving the car for 5+ hours on the Targa Trophy run, you can clearly hear the intake system working its magic. Constant sound of the intake sucking in air and whoosh sounds. I would let off the throttle just so I could hear it. The intake system sounds so good. It is definitely a LOT louder then stock. Having this system and driving around will leave a big smile on your face, as well as a amazing looking engine bay. Performance: I cannot really comment on this part of the intake system yet, because I have a check engine light that maybe affecting my dyno numbers. But I will be updating this part of the review once I get my JB4 on and run Map 0 with the stock intake and Arma Speed Intake. Conclusion: After driving the car around for the Targa Trophy event. I never encountered any problems whatsoever with the system I also did a lot of spirited driving during the run and just could not get over how much better the car sounded under load. I had a few friends in the car and they could instantly tell something was different about the car without me saying anything about the intake system. I would definitely recommend this system to fellow F8x members. Thank you Long@LTMW, Noel@ArmaSpeed, and Dionne Mascunana@MascunanaBear for photos.
2015 BMW M3 (Yas Marina Blue)| Toyo Tires | Moton Suspension |
Instagram: YMB_F80 Last edited by YMB_F80; 11-24-2015 at 05:14 PM.. |
03-02-2015, 11:37 AM | #2 |
384
Rep 1,203
Drives: 2021 M2C
That intake definitely flows very well with the engine bay.
Speedwell-Industries434.00 |
03-02-2015, 12:45 PM | #3 |
2712
Rep 2,371
Nice looking (although could use a close up shot of the entire engine bay, not the distant shot that is in the first picture.
From your description, it sounds like it sounds great. However, don't fool yourself into thinking there are HP gains. A number of reputable companies have done tests with no intake on at all, and saw zero gains on the dyno. The single dyno that shows a gain (that has been posted on the forums, at least) from an intake is a fake dyno, with a completely different shape than any other S55 dyno. Doesn't mean that an intake is not worth it, that's for you to decide, and with your description of the sound from this intake, it sounds pretty nice, and that alone could make it worth the cost.
2015 Black Sapphire Metallic 6MT M4
03-02-2015, 01:32 PM | #4 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
I doubt that an intake will add any power on a stock tune. The amount of air entering the engine is controlled by how much boost the turbos are allowed to add. Boost is controlled by ECU via the waste gates that allow exhaust gases to bypass the turbine wheel.
Unless a more aggressive tune is being used and/or bigger turbos fitted that allow for more air going into the engine, I don't see the intake adding any power.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-02-2015, 05:42 PM | #6 |
445
Rep 1,529
Drives: YMB F80 M3
Instagram: YMB_F80 |
SanchoDivine553.50 |
03-02-2015, 06:38 PM | #7 |
Sunburnt Member
158
Rep 525
Thanks for taking the time to post this, but way too many artsy, 50000mm zoom, 1mm DOF shots. Might look pretty to you, but useless for the rest of us
Just get the basic shots first, and then get "creative"
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
03-02-2015, 07:18 PM | #8 | |
445
Rep 1,529
Drives: YMB F80 M3
I don't take pictures so , simply asked my buddy to just take pictures of the intake system.
Instagram: YMB_F80 Last edited by YMB_F80; 03-02-2015 at 10:04 PM.. |
03-02-2015, 09:18 PM | #10 |
946
Rep 1,275
Wow, looks really clean (especially on post #8). Thanks for sharing.
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
03-02-2015, 10:38 PM | #11 | |
2681
Rep 3,407
Not making any predictions about the gains (if any) to be had from this particular intake but in general. |
03-02-2015, 10:40 PM | #12 |
2681
Rep 3,407
You can thank Instagram for making everyone think they're a photographer.
03-03-2015, 12:41 AM | #13 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
Lots of Bling. I love carbon fiber, but I'd rather blow all that money else where. Looks awesome though
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
03-03-2015, 12:46 AM | #14 | |
445
Rep 1,529
Drives: YMB F80 M3
No I totally understand where you are coming from. Would this be one of my must want/need mods?! No. But there is a really cool factor when you just pop the hood and be hit with all the carbon fiber thats in there. Haha then again my list of MODS that I want are a buncha want and not needs
03-03-2015, 01:33 AM | #16 |
Sunburnt Member
158
Rep 525
Honestly? That was the best photo of the whole lot!
03-03-2015, 06:28 AM | #17 | |
General
21117
Rep 20,741
But even if the intake does provide less restriction to the airflow, the ECU still controls the boost level. Once the set boost level has been reached, the ECU opens the waste gates and no additional boost is generated. A better flowing intake only has the compressor working a bit less to generate the preset boost level, but the engine produces the same amount of power. This is not a normally aspirated engine. Just the fact that a simple tune can increase power by 40+hp indicates that the compressors are not choked by the stock intake in stock form (tune). If you reduce the size of the intake, at some point you will choke the compressors thus physically limiting boost and the engine will produce less power. So yes, an intake the size of a straw will limit the ability to produce power.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-03-2015 at 12:28 PM.. |
03-03-2015, 09:21 AM | #18 |
2712
Rep 2,371
What the intake could do is allow the turbos to spool faster, thus generating max boost and max torque sooner. No real HP gain, but an increase in the area under the curve. It doesn't seem, though, that the stock intake is much of a restriction.
03-03-2015, 10:00 AM | #19 |
657
Rep 1,749
Man you seem to know a lot about not much. It's lowering g the work needed to suck the volume of air leads to less pumping losses and parasitic loss of power. Air filters, or intakes aren't making big power but the system works a little less to get the needed air volume and that translates to a few hp put down due to less wasted pumping lisses. Straw analogy is accurate
UOTE=CanAutM3;17496145]You seem to be contradicting yourself, in the other thread you mentioned that intakes do next to nothing on airflow... so which is it ? But even if the intake does provide more airflow, the ECU still controls the boost level. Once the set boost level has been reached, the ECU opens the waste gates and no additional boost is generated. A better flowing intake only has the compressor working a bit less to generate the preset boost level, but the engine produces the same amount of power. This is not a normally aspirated engine. Just the fact that a simple tune can increase power by 40+hp indicates that the compressors are not choked by the stock intake in stock form (tune). If you reduce the size of the intake, at some point you will choke the compressors thus physically limiting boost and the engine will produce less power. So yes, an intake the size of a straw will limit the ability to produce power.[/QUOTE] |
03-03-2015, 10:37 AM | #20 | ||
General
21117
Rep 20,741
Based on our previous arguments, it seems you don't know much at all. (See, I can throw insults too .)
6 years of science and engineering college studies and over 21 years working at an engine manufacturer got me to learn a thing or two about the physics around engines. But I am far from knowing everything and I am not always right. That is why I like forums such as this one, I always get to learn something new . Quote:
The S55 is not a normally aspirated engine. Engine pumping losses only occur downstream of the turbo. On a boost controlled engine, any losses upstream of the turbo are compensated by the turbo. Judging from the pictures, the Arma intake is only upstream of the turbo. The turbo needs to work a little less, not the engine. So I maintain my point, on a stock tune, no more power to be had . BTW, same goes for high flow filters. Last edited by CanAutM3; 03-03-2015 at 12:30 PM.. |
03-03-2015, 10:41 AM | #21 |
General
21117
Rep 20,741
Good point. It could theoretically reduce lag and boost threshold. But as you say, not sure if meaningful.
03-03-2015, 10:45 AM | #22 | |
2712
Rep 2,371
But if you like bling, and if the sound difference is important to you, go for it. (Generic you, not you, specifically)
