02-28-2015, 08:11 PM | #1 |
Rep 8
Oil Cooler Shield?
Is anybody looking into sources for some sort of shield for the front oil cooler? I have not really investigated it on my car, but I can't believe that something could not be rigged up that would protect the cooler w/o impeding air flow. Waiting for the rock salt to be washed away so I can drive my car again...
02-28-2015, 11:12 PM | #3 |
649
Rep 4,323
Can make a front facing louver shield to protect, but these posts are with straight up road debris.
Drive any sedan over road debris fast enough and something will go wrong...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
03-01-2015, 08:09 AM | #4 |
214
Rep 981
Years ago I had a dieselgeek skid plate on my 04 jetta. It was like 1/4" and weighed prob 15lbs or so and tied into the subframe. It def did it's job, I remember one time on the highway I hit something hard enough to make the car bounce up a bit and there was no damage.
The key to this will be to tie it into something solid and find a way to keep the air moving. |
03-01-2015, 09:21 AM | #5 | |
1163
Rep 2,561
This is definitely needed, and I would buy one for my F80 in a heart beat.
Subscribing to this thread awaiting the news. Quote:
I've busted more than my share of fog lights and under-engine plastic bits over 25+ years of driving, but never did any permanent damage to the drive train. The closest I ever got was taking a wrong turn down a mountainous dead-end road that had a few stray rocks challenging the integrity of my E36M3 cross-brace, but it stood firm and protected the oil pan. Evidently, there is nothing of the kind under F80, and the oil cooler is the first to take the hit, spill its contents, and potentially inflict terminal damage to the engine. Not acceptable. a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
03-01-2015, 07:16 PM | #6 | |
M4 748(a)
630
Rep 427
03-02-2015, 03:32 AM | #7 |
143
Rep 320
What the car needs is something like this, which is the stock undertray on the mini GP2
http://www.minigenuineparts.co.uk/mi...30_566KIT.html This is a carbon fibre composite, so it is very strong, but flexible and light. It is hard to see in the pictures, but the slots at the front are actually louvres. This has an aerodynamic effect that effectively sucks air from the front of the car through the louvres. I have one of these cars as a rally car, and the undertray has taken some massive hits of kerbs, rocks, debris and still is intact. If someone could design something like this with the louvres properly engineered and placed so it allowed flow through the oil cooler it would work well. Effectively just extend the current undertray forward with and additional section with louvres for the oil cooler. In fact, BMW designed the mini undertray (as the GP mini is a BMW car), so why couldn't they do something similar for the F80/82? |
03-02-2015, 01:31 PM | #8 | |
1745
Rep 1,700
03-02-2015, 01:34 PM | #9 |
1397
Rep 3,152
I had an offroad skid plate made for my beast
03-02-2015, 02:30 PM | #11 |
1397
Rep 3,152
lol I was kidding I understand that this (extremely bad ass car) is not a tank, and I can not run over boulders. I also realize it is not a submarine, and I should't drive through deep water
03-02-2015, 03:02 PM | #12 | |
18184
Rep 11,760
Drives: 2018 M4 Comp Indv
You would really think a track-biased car could ford a river - sheesh, at least a tributary.
03-02-2015, 03:05 PM | #13 |
230
Rep 646
Drives: IG: khanhdom
I'm picking up my F83 Thursday and my friend who's a machinist says he will be able to fab something up where it's aerodynamic and let more airflow into the oil cooler and also protect it with some kind of shield. I'll keep ya updated.
03-02-2015, 03:16 PM | #14 | |
2712
Rep 2,371
However, the oil cooler does seem to be in a pretty vulnerable position, and I don't think anyone will argue that oil is somewhat vital to the engine remaining in operating condition. And by 'pretty vulnerable position', it appears to me that some lesser types of road debris could easily seriously damaged the oil cooler. I'm thinking things like baseball sized rocks, chucks of ice that fall from the back of over cars during winter, etc... It looks, to my non-engineer eye, that a simple piece of aluminum or steel could be made to go over that area and provide some slightly greater protection, without adding significant weight to the vehicle, nor seriously degrading the airflow over the cooler, and also not allowing the F8x to run over boulders....
2015 Black Sapphire Metallic 6MT M4
03-02-2015, 03:20 PM | #15 | |
Gone Fishin’
7318
Rep 12,125
03-02-2015, 03:22 PM | #16 | |
2712
Rep 2,371
($50 is a random, wild-ass guess)
03-02-2015, 03:23 PM | #17 | |
Gone Fishin’
7318
Rep 12,125
03-02-2015, 03:24 PM | #18 |
1796
Rep 2,997
I have forded what I would consider to be minor tributaries in my m3. The trick is to carry momentum and use high revs but no throttle input to create a negative intake vacuum so no water is sucked in.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
03-02-2015, 03:28 PM | #19 | |
2712
Rep 2,371
Plus, you'll be w/o your M for a good few weeks, at least.
03-02-2015, 03:31 PM | #20 |
Gone Fishin’
7318
Rep 12,125
03-02-2015, 03:36 PM | #21 | |
2712
Rep 2,371
Anyways, I don't understand why anyone would be against this, but whatever.
03-02-2015, 03:42 PM | #22 |
Rep 67
They used to have one of these for the E36... it was meant to reduce the chance of debris doing damage but if you run over a parking stump, you are still SOL.
