BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > UK
      02-20-2015, 02:01 PM   #1
NJ 1161
NJ 1161's Avatar
75
Drives: 335D M3
BBK KIT e9x, 405mm floating disc, 380mm rear, pb brakes
So, for sale is my big brake set up which includes front and rear. Plenty of pics in my thread, but low mileage, and never tracked or even used in anger.
Amazing kit, with 405mm 8 pot fronts, and 380mm 6 pot rears. All upgraded floating discs, stainless steel brake lines and powder coated calipers. Please be aware that due to the size of the front discs these will only fit under 20" alloys. Over £4.5k new by the time you've paid expensive shipping and 20% import tax. All immaculate.
Detail of the kit can be seen here. My rotors are the upgraded floating rotors that look great and powder coated calipers.
http://pbbrakes.com/brake-kits/bmw/3...brake-kit.html
Some spiel from the website,
PB big brake kits are precision CNC engineered from the finest materials specifically for your vehicle, directly replacing stock brakes. The brake kits, which are available in a variety of colours and options, include calipers, rotors, brackets, lines and shims.
Our rotors are manufactured from high grade FC30 iron alloy with anti-rust coating. They utilze large vents to dissipate heat more efficiently. Center caps are made from aerospace grade aluminium with hard anodizing electrolyte treatment for improved durability. Each rotor is manufactured to a tolerance of +/- 0.02mm to ensure perfect balancing. Any rotor that does not meet our high QC standards will not leave the factory.
Floating rotors allow the braking surface to 'float' on the hub, negating the affect of metal expansion and reducing the possibility of discs warping when they are over-heated. They also improve heat dissipation, meaning they cool down more quickly than our standard 2-piece rotors, which reduces brake fade over prolonged periods.
Calipers are made from high quality 6061 T6 heat treated aluminium, squeeze forged, and finished with an anti-rust coating. They include aluminium pistons with progressive sizes to ensure even pad wear, and internal oil and dust seals for protection against the elements.
Brakes are on the car so can be viewed and fully tested. Replacement pads/ discs ( when needed) are easily available as same size as lots of other brands and interchangeable.
PRICE £2700 ovno
Will remove when deposit received. Based in Ipswich, Suffolk. Can be contacted on 07711 953828.
m3post
