02-16-2015, 10:43 PM | #1 |
Supreme Leader
2284
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
SUPREMEPOWER l AWE-Tuning SwitchPath Exhaust
SUPREME POWER AWE Tuning Presenting the AWE Tuning F80 M3 SwitchPath™ Exhaust line up: ● Dual 3” CNC mandrel bent system ● Max gains of 20hp and 31ft-lbs of torque at the crank ● Proprietary “rattle-less” exhaust valve design ● Featuring SwitchPath™ Technology, Resonated and Non-Resonated ● Available with 90mm or 102mm double walled adjustable tips ● SwitchPath™ Technology utilizes factory valving and M-Sport button ● Hand crafted from T304 stainless steel ● No Check Engine Light - Guaranteed ● Perfect Fitment - Guaranteed ● Featuring the AWE Tuning Lifetime Exhaust Warranty ● Engineered, designed, and manufactured in-house at AWE Tuning Product Details: Leveraging two and a half decades of performance engineering, AWE Tuning is proud to present the BMW F80 M3 SwitchPath™ Exhaust Suite. ● Dual 3” CNC mandrel bent system ● Max gains of 20hp and 31ft-lbs of torque at the crank ● Proprietary “rattle-less” exhaust valve design ● Featuring SwitchPath™ Technology, Resonated and Non-Resonated ● Available with 90mm or 102mm double walled adjustable tips ● SwitchPath™ Technology utilizes factory valving and M-Sport button ● Hand crafted from T304 stainless steel ● No Check Engine Light - Guaranteed ● Perfect Fitment - Guaranteed ● Featuring the AWE Tuning Lifetime Exhaust Warranty ● Engineered, designed, and manufactured in-house at AWE Tuning AWE Tuning SwitchPath™ Technology AWE Tuning SwitchPath™ technology responds to the exhaust valve commands sent from your BMW ECU, dependent on your throttle input and M-Sport button setting. This means that the AWE Tuning F80 M3 SwitchPath™ Exhaust will transform from a sophisticated “Touring” note to an aggressive “Track” note with the touch of the M-Sport button or throttle position. In other words, exhaust volume is civil when you want it, and quite disobedient when you’re in the mood. The volume game: From civil to disobedient. We’ve spent the majority of our R&D time perfecting the AWE Tuning M3 Exhaust Suite to provide options for virtually every taste: Resonated SwitchPath™ Exhaust with your stock downpipes: This is the most sophisticated of the lot, while still announcing that you’ve arrived. Aggressive when you want it, yet refined at part throttle and highway speeds. This exhaust brings out the natural tone of the M3 motor without compromising neighborhood relations. Resonated SwitchPath™ Exhaust with your aftermarket downpipes: Your volume is already turned up with your aftermarket downpipes, but chances are you may want a bit more sophistication and refinement without losing the aggressive yell of the twin turbo engine. This is the system that makes de-catted downpipes a bit more suitable for daily usage. Non-Resonated SwitchPath™ Exhaust with your stock downpipes: This is an aggressive set up, with sharper edges. It announces your entry while still maintaining trademark AWE Tuning sophistication. We recommend this combination for those looking for more full throttle growl from their M3, with a slightly higher part-throttle / highway cruising volume (non-returnable due to sound preference). Non-Resonated SwitchPath™ Exhaust with your aftermarket downpipes: If you have to ask, this isn’t your system (non-returnable due to sound preference). What’s in the Box? The AWE Tuning BMW F80 M3 SwitchPath™ Exhaust Suite includes either
[CENTER] Last edited by supremepower; 02-16-2015 at 11:02 PM.. |
02-17-2015, 12:45 PM | #5 |
1003
Rep 3,051
Kool. Ima going to place a order today!
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
02-17-2015, 02:09 PM | #6 |
Outlaw
90
Rep 250
Drives: 2015 M4 JB4
How does it sound with Downpipes? im getting A/R Downpipes... and this looks like the perfect exhaust to go with it... i wanted BMW performance one but it requires cutting while this one connects right to the downpipes.
so how much? how much is it? and how much does it weight? |
02-17-2015, 03:16 PM | #7 | |
Supreme Leader
2284
Rep 6,548
02-17-2015, 05:25 PM | #10 |
386
Rep 2,989
02-17-2015, 05:56 PM | #12 |
1586
Rep 2,148
I'm pretty sure that it means they suggest you get the resonated version if you have or plan to get down pipes. They are basically telling you that it's going to be super loud with non-res and down pipes, so you can't order and then complain it is too loud and you want to return it afterwards.
02-17-2015, 06:20 PM | #14 | ||
Supreme Leader
2284
Rep 6,548
With stock downpipes, the satisfaction in sound comes from the lack in drone |
02-17-2015, 09:38 PM | #17 |
946
Rep 1,275
Any chance you'll have pictures with the 102mm black diamond tips?
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
02-17-2015, 11:16 PM | #19 |
Supreme Leader
2284
Rep 6,548
