02-16-2015, 11:43 AM | #1 |
41
Rep 164
JB4 Frustration (hiccups)
hello all, I'm sure this is a common issue going on. I've had my jb4 for about 4 months now. currently at map 2 with Downpipes and filter... after some hard driving I would get some hiccups and choking of the fuel whenever I'm at a full stop. it's not the whole time, but it's very common. when I first got the jb4 and started with map 0, this wasn't an issue, but ever since I enabled the wastegate control I've been getting these issues. however I would also get a driver malfunction at times, but would go away and not got into limp mode. I ended up taking my car to the dealer, and they said I would have to remove the jb4 in order for them to do complete testing. as much as I love this jb4, I would hate to have to disable it completely and revert back to stock in order for me to not have this issue. in addition I'm even up to date with the firmware, as others have claimed to fix this so called issue. I'm open to hear what others have to say about this issue, and if there is a FIX for it. because I am very unhappy with this situation because it's embarrassing when my car feels like it's about to shut down.
02-16-2015, 11:48 AM | #2 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
02-16-2015, 11:50 AM | #3 |
Part Time Firetruck Crash Barrier
789
Rep 1,563
My first guess would be bad or inadequate gas. Do you always fill up at the same place? I used to have an issue filling up at a particular station nearby that claims 93 octane, but obviously something was up because I would "knock" a little bit with my jb4 map 2 on my 335. . .
m340ix Mineral Grey/Tacora Red |
02-16-2015, 12:07 PM | #4 | ||
41
Rep 164
02-16-2015, 12:23 PM | #7 |
1003
Rep 3,051
Very true. It also sound like a fuel issue. Not the proper mix. Personally I have always did 5 gallons of E85 then top of with 91
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
02-16-2015, 12:34 PM | #8 | |
4918
Rep 115,980
Mike Last edited by Mike@N54Tuning.com; 02-16-2015 at 12:43 PM.. |
02-16-2015, 12:39 PM | #9 | |
4918
Rep 115,980
I'd say unplug the P3 as a first test. Then if the problem is still there get a BMS USB cable so you can log the issue. The JB4 will display afr bank 1 & 2, timing, throttle, fuel pressure, trims, and from that BMS can determine what is causing that stumble and how to fix it. If you don't have a BMS cable how did you update the firmware? Mike |
02-16-2015, 01:18 PM | #10 | ||
41
Rep 164
02-16-2015, 02:36 PM | #12 | |
1390
Rep 2,336
Active 8 module with Zima DP's. Perfect! Much smoother power delivery than stock trim. http://5252motorsports.blogspot.ca/2...s-for-bmw.html
02-16-2015, 02:57 PM | #13 |
471
Rep 2,991
There is almost no one here that knows enough to actually help you troubleshoot the car. Reach out to Terry at BMS, get some datalogs and actually work on solving your problem, rather than grasping at straws.
02-16-2015, 04:11 PM | #14 | |
Rep 60
02-16-2015, 05:57 PM | #15 |
4918
Rep 115,980
02-16-2015, 07:26 PM | #16 |
657
Rep 1,749
Mike you are quick to post on other threads about jb4 yet when people have issues, which I've seen 4 this past 2 weeks on forum, you tell them not to post Here. I think everyone is interested in any problems out there, whether it's is bms or another product
02-16-2015, 07:42 PM | #17 | |
Sunburnt Member
158
Rep 525
He reeks of a used car salesman.... "Don't look at that, look over here at this shiny bit!". Be very careful when telling people not to post, as censorship does NOT sit well with many people. I for one greatly appreciate M3/M4 owners posting on an M3/M4 board about their issues they're having with their tunes, whether it be JB4 or any other. It adds to our collective knowledge base, and we shouldn't be hiding the issues on some N54 forum. This is a forum to talk about our S55 engines. I would think that many F8x owners would want to know if a certain tune is too sensitive about fuel quality issues and that not enough safety buffer has been taken into consideration with a certain tuning product. What happens on a hot day, at high altitude, if you happen to get a bad batch of 93? I know that I have absolutely ZERO interest in a tune that throws the car into limp mode, and is overly sensitive to a batch of fuel that is slightly below the rated octane level, and I am extremely grateful to other F8x owners who share their experiences with all products, whether they be bad or good. But we should hear both sides of the story, and not just the ones that a reseller wants us to hear.
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible Last edited by Merli; 02-16-2015 at 07:56 PM.. |
02-16-2015, 07:47 PM | #18 |
3169
Rep 2,135
Great idea spamming another tune, but tell me how that competes with my 550whp I'm seeing from a custom map 6 on my JB4?
02-16-2015, 07:55 PM | #19 | |
48
Rep 122
02-16-2015, 08:14 PM | #20 |
1390
Rep 2,336
It can't, and I never claimed it could. Read the OP. I gave my opinion to his question. You are just #1. Does that satisfy your temper tantrum child? By the way, I did have a JB4 previous.
02-16-2015, 08:16 PM | #21 | |
3169
Rep 2,135
02-16-2015, 08:22 PM | #22 |
32
Rep 178
Definitely want to hear about problems here instead of n54 tech. I don't want to have to lurk multiple sites to get simple information if I don't have to!
