02-16-2015, 08:48 AM | #2 | |
1163
Rep 2,561
Otherwise, they are a PITA for swapping wheels in and out. Especially if you swap out between wheels that require spacers, and wheels that don't need them: you have to wedge them off the hubs (they always stick - you antiseize), or put them back on. At the very least, you will need to align spacers holes with those of the wheels and hubs. Then you may need longer lug bolts as well, so now you have to remember which bolts go with what wheels and spacers. But if that's the only way to make a set of wheels and tires work for your car, it's certainly less painful then not having any wheels at all ! a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
02-16-2015, 08:57 AM | #3 |
Resident Engineer
135
Rep 748
PRO:
Improves look Theoretical improvement in handling CON: Rocks And Gravel.
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
02-16-2015, 09:01 AM | #4 |
Gone Fishin’
7318
Rep 12,125
I had a horrible experience w/ spacers on my e90. I hated them and could always feel the vibratoin. H&R. I heard similar stories w/ them.
I put MS 15/12 on my car last weekend and frankly I cant even really feel them. The HUB rings on this car are huge and make it really easy to install. 10 mins per wheel. Car looks vastly better. |
02-16-2015, 10:39 AM | #5 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Very minor inconvenience when using wheel bolts, might add 10 more seconds per wheel. No difference at all if using wheel studs like in my track car. Just get good quality spacers and stay away from 5-10mm spacers that use the cars hub. 3mm too thin to matter and 12mm+ have its own hub.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
02-16-2015, 11:59 AM | #6 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
I would even question that. I would say spacers theoretically make handling worse (if they alter the OEM wheel offset). Most drivers will not see the difference at "public road" speeds though.
BMW designed the suspension around a given wheel offset. Changing that offset will alter how the suspension behaves as it changes the lever arm length of the wheel/tire relative to the springs and dampers. Further, on the front wheels, spacers also alter the required ackerman angle in the steering as it is turned. On my E92, I installed 12mm front spacers to improve the looks. I was running -2.8 front camber, so the wheels really looked pushed inward. I really disliked what the spacers did to sterring feel where a lot of feedback was lost. Eventually took out the spacers.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
