02-11-2015, 12:04 AM | #1 |
657
Rep 1,749
do we know if the car loses power with valves closed?
Has anyone tested the car on dyno keeping the valves closed with one of the available methods? I'm planning on getting downpipes but thinking I csn keep the valves closed with my MPE to get a nice sound that's not too loud. However I certainly am not willing to lose power
02-11-2015, 03:39 AM | #2 |
34
Rep 155
My experience on other cars More flow = more power but ... You loose a lil torque down low and gain upper rpm HP where u don't need or use on the street.. that's why I'm keeping my stock exhust..
02-11-2015, 03:58 AM | #3 |
BimmerPost Supporting Vendor
80
Rep 440
do you know that ARMA has exhaust valve product? it links to OBD2 system so you can set RPM to open/close the valve.
02-11-2015, 06:52 AM | #4 |
10817
Rep 27,600
I have not experienced any noticeable change in power when I have my valves closed. Its basically just night and day in sound change. then again I have yet to really get on the car with valves closed to feel the difference between the two.
I drive mostly with valves closed 80/20
02-11-2015, 06:58 AM | #5 |
329
Rep 984
My guess is you would see a few horsepower on a dyno but never actually feel it.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
02-11-2015, 07:54 AM | #6 |
Go ///M or go home
276
Rep 1,280
The power difference will be negligible at best. I've owned a few valve controlled exhaust cars and never noticed a power difference.
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT |
02-11-2015, 09:01 AM | #8 |
1397
Rep 3,152
probably do not lose power from them opening; if so, then why would they open under WOT?
02-11-2015, 10:13 AM | #9 |
657
Rep 1,749
I'm asking if they lose power closed.
Thanks for the input. I just feel since they still open in efficiency mode tells me closed valves have some effect otherwise why not keep closed |
02-11-2015, 09:34 PM | #10 |
2680
Rep 3,406
Why do people think that a reduction in back pressure on a turbocharged car results in less low-end torque? You see this in every other thread related to exhaust and it's beyond me why people believe this.
02-11-2015, 09:40 PM | #11 |
2680
Rep 3,406
OP, you're not going to get a quantitative answer. Any difference in power between exhaust flap modes will be within standard variance of two separate dyno pulls. Data will be inconclusive.
Any reduction or increase in exhaust flow will effect power simply by definition. I'd guess the flap is good for 1 to 2 RWHP at most. |
03-09-2015, 12:03 AM | #12 |
148
Rep 774
Drives: 21 X5 M50i
Does anyone know if having the valves closed most of the time has a negative impact on the engines longevity? Guessing no, but...
03-09-2015, 06:04 AM | #13 | |
329
Rep 984
No, not at all. Never.
03-09-2015, 07:12 AM | #14 |
1357
Rep 3,349
Nope, the hot side is going to force that air out one way or another.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
03-09-2015, 07:24 AM | #15 |
1003
Rep 3,396
This was the consensus back on the N54 back when it was debated to death over on the 335i E9x forums.
03-09-2015, 07:27 AM | #16 |
148
Rep 774
Drives: 21 X5 M50i
Ha what're you pulling your hair out for? It's a reasonable question. You just said it may incrementally reduce horsepower, which seems to logically indicate some additional load on the engine. Unless you can definitively state it doesn't impact the engine using some real facts then put your hair back in.
-Matthew
03-09-2015, 07:31 AM | #17 |
1357
Rep 3,349
Doesn't necessarily put more load on the engine as much as it restricts the airflow of the turbo.
03-09-2015, 03:31 PM | #18 |
Curiosity Killed the Cat
241
Rep 822
Valves open all day for me. It seems from diagrams the flaps just change what chambers the exhaust gas flows through. So open of closed, it is still flowing pretty good, but not through the muffler
SOLD - 2015 /// F82 M4 / AY-SO
"AY-BRAVE" I'M BACK - 2016 M4 GTS I'M BACK AGAIN - 2021 M4 COMP FPB |
03-09-2015, 07:22 PM | #19 |
57
Rep 146
I made a pull on efficient mode and then realized and switched over to sport plus and made another pull 30sec later and made another 2whp. Could mean something but my baseline varied by 3whp so...
03-09-2015, 10:32 PM | #20 |
Rep 133
stock car is already open/close with throttle response?
JB4 | Fie Cattless DP| Vorsteiner Diffuser | Black Grill | LED Parking Light | 15% Tint | M Spoiler | Black Side Grill | LED Number Plate Light | M Floor Mat | CF Knob | CF Centre Console Trim | Handbrake Grip with Alcantara | ADV1 5.0v1cs 20"
03-10-2015, 12:57 AM | #21 |
657
Rep 1,749
Efficient mode opens valves too as rpms raise so all three modes ultimately open valves so unless you have a device that can control valves we can't test it
03-10-2015, 05:10 AM | #22 |
73
Rep 549
May be it will get you +1hp)
The power is about cats, not about valves.
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
