02-07-2015, 06:34 PM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
CANflap for those without a JB4!
As most of you know BMS has included CANflap with their JB4 system since 2009. It's a feature that lets you adjust the tailpipe exhaust valve to be open or closed on the fly from your drivers seat rather than having to manually unplug the valve. They recently added it to their S55 JB4 and its been very well received. So much so that many customers who want to run OEM tuning, flash tuning, or even other less sophisticated piggyback systems, have been asking BMS to make a stand alone module so they can have this feature. Myself included!
So BMS has worked up a quick install version of a stand alone module which is in testing now. Intro price will be $279 and it will be available with the OBDII connector (plug in and tuck under an interior cover), or a hardwire harness where you connect 4 posti-taps for a more permanent installation. Here's an early DEMO video of it in action. Note that BMS feels although the price is high for what it does they plan to add more functions to it down the road via free firmware updates. An in dash boost gauge is high on that list. In addition to controlling the exhaust flap it can also delete OBDII codes. Mike |
02-07-2015, 06:38 PM | #2 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
Pretty much like the Macht schnell module?
02-07-2015, 07:28 PM | #7 |
4918
Rep 115,980
02-07-2015, 07:32 PM | #8 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
Looks very cool. Nice that there'll be more expansion w it.
LIVE FAST..DRIVE FASTER!! |
02-07-2015, 08:56 PM | #9 | |
21
Rep 270
02-07-2015, 08:58 PM | #10 |
262
Rep 658
For those that have these products that delete the CEL how do you know if it's a real problem or the catless Downpipes?
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
02-07-2015, 09:00 PM | #11 |
21
Rep 270
02-07-2015, 09:31 PM | #12 | ||
2712
Rep 2,371
1st, as mentioned in the original post, there is a more permanent way to install it, tapping into wires, rather than using the OBD2 port. Quote:
So, any of the CEL deleters, including this one, are not going to get you to pass smog, regardless of whether the OBDII port is occupied or not.
2015 Black Sapphire Metallic 6MT M4
02-07-2015, 09:59 PM | #13 | |
21
Rep 270
02-07-2015, 10:01 PM | #14 |
2712
Rep 2,371
Then NY smog testers are different than ones I have encountered, and I have smogged cars in at least 15 different states by now (the joys of military service transferring me all around the country)
02-08-2015, 07:05 AM | #15 | |
4918
Rep 115,980
exclusively for competition race use. 2) You will not be able to set emissions readiness with catless downpipes installed. Deleting a pending CEL via the OBDII port with a code delete tool is not going to set readiness or allow you to pass emissions testing. After a minute or two the CEL will just come right back on as the DME is not able to complete it's emissions testing cycle without OEM downpipes. Mike |
02-08-2015, 09:33 AM | #16 |
117
Rep 105
Seems like the time/date/MPG/etc. changes with each push of button still? No way to separate the two? Same functionality when you only have one button (no auto lights)?
02-08-2015, 10:13 AM | #18 |
32
Rep 178
So I guess I'm confused on the difference between code clearing on this device opposed to the JB4.
In terms of functionality, is it any different than that of the JB4? Because it looks incredibly illegal here, but fine with the JB4. |
02-08-2015, 11:18 AM | #19 | |
4918
Rep 115,980
Mike |
02-08-2015, 11:25 AM | #20 | |
4918
Rep 115,980
Mike |
02-08-2015, 11:26 AM | #21 | |
4918
Rep 115,980
Mike Last edited by Mike@N54Tuning.com; 02-08-2015 at 11:37 AM.. |
02-08-2015, 01:26 PM | #22 | |
32
Rep 178
