Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      01-27-2015, 10:32 AM   #1
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
305's rear and 275s front on stock wheels
I know this has been discussed before but do we have any updates from the folks that have gone with the wider tires sets front and back on the stock wheels? I truly love the stock but I fee like it needs to be wider in the rear.. Does the 305's on the rear make the back look any beefier/wider... I like that ass you know any negative feed back about performance from the folks that have gone this rout?
Thanks in advance...
      01-27-2015, 05:26 PM   #2
rmedeir1
132
Drives: BMW MW M4 - MPE, CCBs, all CF
      01-30-2015, 07:34 PM   #3
teamwerx
teamwerx's Avatar
32
Drives: 2015 M4
      01-30-2015, 10:28 PM   #4
Cajun1
Cajun1's Avatar
140
Drives: M4!
      01-30-2015, 11:00 PM   #5
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
According to the spec of most tire makers, 10" wheels are too narrow for 305 tires.
      02-01-2015, 01:19 PM   #6
ixse
238
Drives: 2015 boxster s
Using 305 on 10in wheel wont give you any better traction than 285s. Most tire shops wont even install it for you due to possible tire failure. Ive tried oversized tire before.. All it does is it creates "pre-flex" on the side walls of the tire and causes much faster wear and wobbly side wall under hard cornering applications. Thankfully mine didnt explode or anything, but it definately felt worse than putting on correct sized tires.
Trust me in this, putting 275 dot r comps will make it feel 100000 times better than 305 pss .
      02-01-2015, 01:27 PM   #7
WVUDrJay
WVUDrJay's Avatar
262
Drives: 2015 M4
Apparently according to tire rack 295/30 will fit on stick runs and is in acceptable range.
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
      02-01-2015, 04:00 PM   #8
TahoeM3
410
Drives: F-type R, GTR, X5 50i
I've held back from posting in this thread because while I've expressed my thoughts in similar threads, I haven't yet actually changed my tires and don't have real world experience with larger tires yet.
I don't disagree with you that 305s are probably overkill on a 10" rim, but the stock 275s are smaller than a normal 275 and have the tread width of a normal 255 tire at 9.5". So even going to a regular (non-M4 spec) 275 would give wider tread which would help lateral grip. The regular PSS 275/35 has a 10.2" tread width. R-comps would be a big upgrade, but good luck driving those on the street on a regular basis.
My personal thought is that a 285/35 or 295/35 is probably the best balance for both improved straight line and lateral grip. I'm curious to see what BMW goes with for the competition package.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black
2022 BMW X5M MBB/SO
Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,...
      02-01-2015, 10:27 PM   #9
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Drives: 2020 Mineral White 30d MSport
Here you can do all the tire comparison's you want, it gives you an idea how far you can go switching sizes
http://www.dakota-truck.net/TIRECALC/
....Life is too short to drive boring cars
      02-05-2015, 12:59 PM   #10
FSHNGRY
FSHNGRY's Avatar
2337
Drives: INDIVIDUAL F90 M5C LCI
I hope this is true. I really want to get some beefier tires for my car. Do you think you'll be able to fit these tires on an M4 with 12mm spacers and a very subtle drop? I just installed KW HAS kit and the spacers and I would like to get some fatter rear tires.
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
f80post
