12-02-2014, 12:25 AM | #1 |
Rep 25
Tires for the track?
Hey all,
I'm waiting for the delivery of my mw m3 and am eager to get to the track. Before I track the car I need to get some additional tires. I wanted to get tires that would fit on the stock 19"wheels and would last me at least 2 solid days of driving on the track (hopefully Thermal Driving classes). I was thinking about purchasing another set of the the stock tires. What are your thoughts on this? I don't want to waste money but I also don't want to get a set of track wheels, so I prefer just tires. I would really appreciate the insight and help. I am currently moving from my vw r32 mkv to the bmw. Some of the major differences will be the four wheel drive compared to the rear wheel drive in the m3, so I'm looking for a tire that has great grip. Any help would be greatly appreciated. Thanks guys! |
12-02-2014, 09:34 AM | #2 |
560
Rep 570
Track Tires
It likely depends on your driving ability/level. Specifically, when I was a beginner/low-intermediate driver on-track, I could get away with a street tire - such as the Michelin Pilot SS. As I advanced, I found that street tires would overheat too quickly and they'd wear very badly within a few sessions (especially w/stock alignment). Running an R compound tire such as a Bridgestone RE-11, Dunlop Star Spec, Yokohama AD08, etc. definitely helped w/tire life and aligned more w/the intermediate-advanced levels of driving (E90 M3).
For me, slicks are too hard on the car (mechanically), so I don't mind some give that R-compound street tires provide and higher slip angles that slicks don't allow. I'd suggest Yokohama Advan AD08 tires or the others mentioned above. Also, some addition of negative camber to the front end (I ran -1.4 degrees and zero toe for the E90). I'll probably do the same for my F82 in the spring...it's an improvement in track performance w/out too much neg. camber for the street (unless you go the aftermarket suspension route w/camber plates, etc. for more camber) |
12-02-2014, 09:42 AM | #3 |
592
Rep 5,396
I agree, except I will point out that the ad08r, hankook rs3 and re-11 are not R compounds, they are extreme summer tires.
if you are staying with stock wheels, you need to stay with stock tire widths. that makes your choice easy, its ad08r in stock sizes. they will represent a big upgrade in track performance, and tire life. the PSS are not meant for the track, and you will have issues with edge wear on the front tires
12-02-2014, 10:16 AM | #4 |
206
Rep 472
As stated the Yoko in stock sizes or the Pilot Sport Cups.
I would go with the Pilot Sport Cups myself for the track but either will work over the stock PSS. |
12-02-2014, 07:31 PM | #5 | |
Rep 25
And again I really appreciate all your guys' effort! Cheers |
12-02-2014, 07:39 PM | #6 |
205
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Pilot Sport Cups are more than a relatively new driver can use and will mask small mistakes, that then lead to large mistakes. Add cold weather and any moisture and you'll have your hands full but then your in Socal. RE11 (if they fit) or AD08 are solid options here....they have stick, break away smoothly and make some noise at the limit, which you want, and will work well on a wet track.
And welcome to big meaty tire prices.
F80 M3 / Mineral Grey-Silverstone / CCB
12-02-2014, 09:39 PM | #7 |
114
Rep 672
Drives: M2 Comp
Garage List 73 911 RSR [0.00]
04 996 Cup [0.00] 06 997 Cup [0.00] 12 Boxster Spyder ( ... [0.00] 15 Sierra HD Denali [0.00] 16 GT3RS [0.00] 17 Radical SR3 [0.00] 18 Model X [0.00] 18 GT350R [0.00] 19 M2 Comp [0.00] |
AD08R. Good track tire and excellent street tire for SoCal.
12-03-2014, 08:12 AM | #9 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Agree, the AD08 would be a good track tire and step up from PSS. I used them when I tracked my E60 M5 and they were very good. They're a little less comfortable for daily driving, but not too bad.
The next step up in track tire for stock 19" rims would be the Toyo R888. More of a dedicated R comp track tire, definitely much stickier and should probably be used in conjunction with track pads and higher temp brake fluid. 265/30/19 (or 265/35/19) for the front and 295/30/19 sizes are available and not too expensive. They are not great for the street, stiff and noisy. Also poor in wet conditions. You can have a set switched out for about $80 if you want to alternate with the PSS for daily driving. A lot more track tire options for 18" rims are available, but kind of limited for 19".
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
12-03-2014, 10:01 PM | #10 | |
Rep 25
12-03-2014, 11:30 PM | #11 |
892
Rep 9,032
Best bang for the buck is NT05, IMO. solid tire and pretty cheap. Good for beginner to intermediate drivers.
StarSpecs are also great and last a long time. They probably have the best wet traction of the top Summer tires. There have been multiple reports of RS3 heat cycling out after a few track days despite good tread left. ADO8's are solid and a good bet, but cost a bit more. It's probably more tire than a beginner needs. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
