11-19-2014, 02:28 PM | #1 |
Rep 65
Warning to OEM 640M owner.
I have purchased the OEM BMW 640M Winter Tire package from the dealer and had them installed.
Everything looked fine from the outside but when I got home and checked it carefully, my 9” wheel were mounted in front and 8 ½ at rear. No big deal as it fits but not right so I had them fix the mistake next day. BTW, you have to place a small mirror behind the spoke to see the difference in parts# because visually it looks identical from outside with square tires setup. Part# for Rear wheel should starts with 9J and Front wheel should starts with 8 ½. |
11-19-2014, 03:35 PM | #2 |
1796
Rep 2,997
Damn, I guess that's confirmation of what I was trying to figure out: that the 9" would fit in the front and you could order a square setup and run it with tire rotation.
11-19-2014, 09:23 PM | #4 | |
1033
Rep 1,997
thanks! matt
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
11-20-2014, 07:18 AM | #5 |
Rep 65
It definitely rides softer than PSS but other than that my M3 with Continental rides like Lexus in Comfort (suspension) setting. This is not a bad thing in a crappy road that we have here.
11-20-2014, 07:29 AM | #6 |
Rep 65
I don’t have a photo of my car but here is a photo of another forum member with 640M on F80.
http://f80.bimmerpost.com/forums/sho...&postcount=146 640M package comes with Continental ContiWinterContact TS830P 255/40 R18 tire. |
11-21-2014, 02:53 PM | #7 |
23
Rep 115
Drives: 2015 M4 6MT
The parts manager at my dealer agreed with this approach also and I ordered 4 of the 18" rears. Should have them in a couple of weeks and will let everyone know if there is an issue.
11-22-2014, 06:09 AM | #8 |
3773
Rep 6,673
Would'nt running a square setup mess up the steering and handling geometry? You want to take all that engineering and throw it away so you can save a few bucks on tires?
Any other merits to a square setup maybe I'm missing??? |
11-22-2014, 07:28 AM | #9 | |
23
Rep 115
Drives: 2015 M4 6MT
If BMW was recommending a staggered tire setup for the 641M/640M, I might agree. But they are not, and there is no way that 2mm of offset will mess up the steering and handling geometry. Especially since they are the same as the summer fronts anyway. Last edited by stonecliff; 11-22-2014 at 07:33 AM.. |
11-22-2014, 07:35 AM | #10 | |
163
Rep 641
M2 competition, Alpine White
Previously Owned : X3 M 40i, F80 M3 Comp Pack, DCT, Yas Marina Blue, F80 M3, DCT , E92 M3 Comp Pack, E92 M3, Z4MC, E46 M3 CS, E46 M3 |
11-22-2014, 08:45 AM | #11 |
23
Rep 115
Drives: 2015 M4 6MT
In this case, it's not the wheel size that matters; it's the tire size. Since the tires are the same size in all four corners, only the offset affects steering geometry. And 2mm is a pretty minimal difference, increasing front track by 4mm total.
11-22-2014, 09:15 AM | #12 |
163
Rep 641
Why then do BMW make the wheels different sizes ?
11-23-2014, 08:06 AM | #13 |
23
Rep 115
Drives: 2015 M4 6MT
Great question. And the related question is "why did they change the offset from the recommended summer to winter wheels when they are putting the same size tires on them?"
Hard to imagine that BMW would think it is a problem to put snow tires on the stock 437M wheels, no? |
11-23-2014, 09:39 AM | #14 |
163
Rep 641
I wonder if it has to do with being able to fit chains which is I think a requirement in some places.
Or maybe just a ploy to sell more wheels.
11-23-2014, 11:26 AM | #15 |
Rep 65
I am very surprise that I am the only 640M owner with 9” wheel mounted in front and 8 ½ wheel mounted in rear by mistake.
Anyway, I am no expert in steering/handling geometry so I personally decided to stick with BMW’s recommended staggered winter wheel setup. I do love my stock 19” wheel but 640M(18”) isn’t all that bad. Especially, I find it easier to clean than stock 19” because of less surface area and spoke design. |
11-23-2014, 01:22 PM | #16 | |
General
1569
Rep 29,202
On the F10 the 18x8 is ET30 while the 19x8.5 is ET33.
11-23-2014, 03:03 PM | #17 | |
Maverick
57
Rep 228
M |
11-24-2014, 07:46 AM | #18 |
Rep 65
You place a small mirror behind the spoke to see the part number. I haven’t checked it since I had it corrected by the dealer but I remember it’s a first left (or right) spoke from the valve stem. The part number begin with either 9J (rear) or 8 ½J(front).
11-24-2014, 09:41 AM | #19 |
163
Rep 641
Hopefully mine are on the correct ends of the car as I put them on myself. TPMS reset seems straightforward per idrive and pressures showing the same as my trusty Longacre gauge. On 20 mile trial run with temp at around 8C on damp greasy roads revealed no issues, ride (on the pilot Alpins on 18s as opposed to PSS on 19s) seemed a bit smoother I would say sport setting for suspension feels about the same as comfort previously.
We will probably have a warm winter here now and render all this a waste of time.
11-24-2014, 10:37 AM | #20 |
329
Rep 984
I'm not quite sure what you're getting at here. This is for a winter tire and wheel setup, I don't think anyone is trying to save a few bucks on tires. Second, a square setup has historically been a superior tire setup to the staggered tire setup for handling purposes.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
11-26-2014, 09:44 PM | #21 | |
Maverick
57
Rep 228
I used a mirror to look behind the spoke on each wheel. The spoke you need to look at is immediately to the right ( counterclockwise) of the tire valve. He had the 9 inch wide wheels (9J) on the front, and the 8.5 inch (8-1/2J, not 8J) on the rears. Going to swap them tomorrow. M |
11-30-2014, 11:07 AM | #22 | |
168
Rep 507
