11-17-2014, 12:18 PM | #1 |
1796
Rep 2,997
Regular driving Review: Michelin Pilot Alpin PA4 in 245/45/18 for M3
Hi all,
I've put about 100 miles on the Pilot Alpin PA4's in 245/45/18 and while not fully broken in, nor any experience in snow, I wanted to post some thoughts on both the tire and tire size for this vehicle for daily driving and normal performance characteristics. Background I, like many others right now, agonized over my winter setup. I actually bought LM-32s mounted in 18x8 "Rial" P10's before returning them to tirerack. I then tried to buy BMW's recommended setup, only to find out I couldn't get a confirmed date of delivery (meanwhile, we started getting some snow here). I wanted a square setup and my last experience was in a 235/45/17 SNOW tire (not a performance winter tire) on a much heavier e39 m5. It was very under-tired and it felt it all the time - I didn't want that again, which was pushing me to go wider. Lastly, I need to drive all winter and while we don't get tons of snow consistently I need to be able to get on an unplowed road with 4" of snow, or a packed snow road, and not sweat it. Which was pushing me to keep a narrower setup. Decision-time Ultimately I chose Michelin PA4's in 245/45/18 because: - I hate balancing issues with an unholy passion and Michelin has consistently been an outstanding balanced tire for me throughout it's entire lifespan. - Seems to be an excellent winter tire for slush, set snow, packed snow, and up to 4" of fresh snow....which is all I'm ever going to deal with. I don't expect them to pull me out of enormous snow drifts and what not. We'll see about ice though. Also, I realized I was being foolish with my concerns over tire width. The HEAVIER F30 335i gets a recommended 225/45/18 tire for winter usage. My lighter, more rigid chassis, lower, and lower COG m3 is going to perform admirably throughout the winter months on a 245/45/18 (this was my thinking) Review Really happy and pleasantly surprised in almost every respect. First off, turn-in: I would honestly rate this as 95% as good as the Michelin PSS which blows me away. The car simply responds as expected with a balanced and immediate turn-in and takes a neutral stance immediately. I credit the chassis and a stiff winter sidewall. Comfort/ride quality: This is a winter performance tire and has a taller front tire. I have the adaptive suspension. To me, it feels like each mode has adjusted one mode softer. Sport now rides more like comfort, sport plus closer to sport, and comfort rides to me like an F30 335i on 18" wheels. This is by no means soft - the chassis is still ultra-rigid, the steering is in essence the same, it's just bump absorption has gotten a bit better. Noise: Slightly quieter than the Michelin PSS in all respects. But only slightly Dry Accelerative Traction: It's excellent....but DSC is more intrusive in gears 1-3 upon full throttle and when full power hits (usually around 3500 rpms). MDM mode is more of a necessity. Let me rephrase this: Dry traction is far better than I expected out of a winter performance tire. In everyday driving, it's a barely noticeable difference from the Michelin PSS....especially the Michelin PSS in outdoor temps of 40-60 degrees, when it's not quite as good. Dry lateral traction: There's a bit more wiggle, a bit more squidge (made up word), a bit more tire roll.....but other than that I'm going to say this thing drives exactly the same up to 7.5-8/10ths as the summer tires in similar temperatures. It's very confidence inspiring on public roads. At the end of the day though, these are winter tires so I'm not going to rate them above 7.5-8/10ths of the car's normal public road driving performance. These aren't tires you take to a track. Braking: No notable difference in normal, non-ABS threshold braking. I think ABS kicks in earlier and i think stopping distances from a max-distance perspective are longer. Feels that way. But without testing, who knows. I expect these tires are substantially heavier, which is going to influence it. Steering: I think I already covered this but I will say that I was most concerned about steering. Historically, I've had bad experiences going to a much different type of tire when it comes to steering. Here, there's really no difference besides what might be placebo effect. I'm comparing this against michelin PSS in 40-60 degree weather, so bear that in mind. I'm quite surprised by the steering and imagine this has to do with an EPS system as well in addition to the F80s relatively numb tiller (compared to some cars I've owned). Regardless, I like the F80s steering and switching to these tires in this size seems to have made no impact on it. ... I realize it's a little early to be reviewing a snow tire. However, most of my concerns were around day to day enjoyment being sacrificed for snow traction and so far I can say that it seems unfounded. For when the snow comes. I plan on having some extra weight in the trunk and we shall see what happens then Hope this helps someone!
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
11-17-2014, 01:09 PM | #2 |
4440
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Lol...you should see my PM box today between myself and Miguel agonizing about this very topic!!! We must have been going back-n-forth how many times this morning Miguel?!?! What was the outcome again?
Thanks Joe for sharing your review thus far, definitely helpful. More helpful for me however, would be to see some more pics of that BBS setup!!! Thanks
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-17-2014, 01:19 PM | #3 |
1796
Rep 2,997
heheh, it's pouring today so no new pics right now
I saw him last week and he was agonizing over it still. His choice is vastly different than mine, as he has much greater flexibility to stay home during snow days, have a short commute, or take a different vehicle. At the end of the day, my money says he buys BMW's setup. He's a hardcore BMW-phile at heart and he'll sleep better knowing he bought BMW's setup. Of course, he does have a few non-BMW parts on his car already....so maybe I'm wrong... |
11-17-2014, 01:29 PM | #4 | |
4440
Rep 5,733
Miguel and I have very similar situations which makes it difficult for us to decide whether to spend the $$$ and get a winter setup. We left our conversation as both of us holding off this winter and if its too much of an inconvenience, getting a setup next season. But I'm still torn...
12-15-2014, 06:00 PM | #5 |
114
Rep 424
I just installed these tires, 255/35/19 front and 285/35/19 rear on my m4s stock wheels. In little snow like we had last week they were perfect.
Under hard acceleration they actually really impressed me. |
11-16-2015, 12:09 PM | #6 |
231
Rep 1,267
Bought this tire for my F30... So far so good, maybe a little soft to my taste compared to the summer Conti run flats. Traction not as good. But I'm still breaking them in. Have yet to try in snow.
What is your sweet spot for inflation on 245/45/18 ? Last edited by ft1330; 11-16-2015 at 12:22 PM.. |
11-16-2015, 03:36 PM | #7 | |
1796
Rep 2,997
I'm pretty sure I had them at ~36 PSI give or take but I can't remember honestly.
11-17-2015, 06:27 AM | #9 | |
231
Rep 1,267
11-17-2015, 07:57 AM | #10 | |
1796
Rep 2,997
Example 1: I turn down a flat backroad with 4" of unpacked snow. Using momentum and decent tire grip, I make it through just fine. Example 2: I know I need to traverse a long, windy, back road with some uphills on 4" of unpacked snow. I would not be sure I would make it without issue.
11-17-2015, 12:45 PM | #11 |
Rep 32
OP why did you return the LM-32s? Did you try them and not like them? I was looking at the 255/40s. Look like PA2s are available in that size as well. I'm in MD and have similar winter driving requirements.
11-17-2015, 01:08 PM | #12 |
1796
Rep 2,997
I prefer Michelin as a brand due to my experience with very even wear and excellent balance -no other reason
11-17-2015, 07:00 PM | #14 |
1032
Rep 1,997
thanks for the feedback!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
11-18-2015, 09:28 AM | #15 |
1796
Rep 2,997
BBS wheels in 18x8 sizing, widely available.
11-18-2015, 10:32 PM | #16 |
533
Rep 1,415
Hey Joe,
Are the PA4s directional or not? I know theyre asymmetric and have an "outside" marking on the tire, but I think I've installed mine on the wrong sides. I don't understand why there is no arrow for rotation if they are directional. |
11-19-2015, 04:22 AM | #17 |
135
Rep 238
11-19-2015, 08:49 AM | #18 | |
1796
Rep 2,997
As far as I know, no, they are not directional and you can cross rotate them.
11-19-2015, 08:53 AM | #19 |
1796
Rep 2,997
11-19-2015, 09:17 AM | #20 | |
533
Rep 1,415
If you cant see the photos try this link: https://photos.google.com/album/AF1Q...9B_HAbgnHSoCNM Why do they curve one way on one side and the other way on the other. The front left curves the same same as the rear right I think. None of this matters? |
11-19-2015, 02:22 PM | #21 |
1796
Rep 2,997
There are non-directional tires like that - since there is an "outside" mark you'd have to have side-specific tires to make them directional. They are non-directional.
11-20-2015, 08:09 PM | #22 |
533
Rep 1,415
So after spending a day on the PA4 for the first time, I will only comment on the road noise and comfort.
The tire is noticeably noisier than the PSS and rides a bit bumpier. You can definitely feel the difference versus the smooth ride of the PSS. I can get used to both items and the noise isn't very significant, but the ride comfort definitely isn't as great as the PSS. I didn't do any real acceleration or braking to comment on those. So as a first impression, its obviously not a PSS. I sort of wonder what a AS3 would feel like, but I doubt I'll ever make that purchase. |
