10-11-2014, 10:54 AM | #1 |
23
Rep 115
Drives: 2015 M4 6MT
Wheel bolt torque settings?
Anyone know the "official" wheel bolt torque settings per BMW? I'd like to torque them properly after changing pads. Thanks.
10-11-2014, 11:46 AM | #2 |
1904
Rep 5,678
105 ft lbs
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
someMoreMplease36.00 |
10-11-2014, 02:36 PM | #3 |
23
Rep 115
Drives: 2015 M4 6MT
Thanks. That's a bit higher than I thought it would be. Appreciate the help.
10-12-2014, 05:20 PM | #4 | |
560
Rep 570
10-12-2014, 05:52 PM | #5 | |
1904
Rep 5,678
Edit... found the link. Info is in the 2nd post - http://f80.bimmerpost.com/forums/sho...eel+lug+torque
10-12-2014, 08:42 PM | #6 | |
23
Rep 115
Drives: 2015 M4 6MT
10-12-2014, 08:46 PM | #7 | |
BimmerPost Supporting Vendor
8250
Rep 18,839
Drives: BMW
All F-Chassis use the 105ft-lb torque spec, spacers or without spacers. Previous E9X models have a 12mm shank, which use the 88ft-lb spec. Hope this helps!
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-12-2014, 09:03 PM | #8 |
23
Rep 115
Drives: 2015 M4 6MT
Many thanks for the explanation. Time for a bigger torque wrench!
10-13-2014, 02:22 PM | #9 |
560
Rep 570
I just confirmed with my BMW center Service Manager, via his M Technician, that the F8X lug bolt torque is 140Nm (103.26 lb/ft).
Thanks for helping flesh this out, everyone! |
10-13-2014, 07:25 PM | #10 |
23
Rep 115
Drives: 2015 M4 6MT
Extremely helpful. Here is why I turned to the board for this question:
First answer from my dealer's service department to this question was: "just hand tight, don't use an air wrench". When I explained I was looking for a number (!), they came back and said I would have to bring my car in "because each car model is different". Needless to say, I found that ridiculous. So I called my sales guy and asked him if we would find out. He called back and told me it was definitely 80 ft. lbs. Not wanting any more BS answers, I turned to the guys who know. I should have asked you first... Thanks! |
12-09-2014, 05:50 PM | #13 |
471
Rep 2,991
That's the bolt head.
The F80 uses 14mm x 1.25 pitch bolts, with a 17mm thread. |
12-19-2014, 11:56 PM | #14 |
358
Rep 1,199
Hey Tom. After how many miles would you suggest to re-torque the bolts?
12-22-2014, 11:18 AM | #15 |
8250
Rep 18,839
Drives: BMW
Always a good idea to recheck at 100mi.
12-29-2014, 10:15 AM | #16 |
Commander-In-Chief
2172
Rep 8,937
Lug torque
This may or may not be the case (the reason for the change). My '12 ML has 14mm lugs and uses 88 lb-ft torque.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
01-05-2015, 11:00 AM | #17 |
1797
Rep 2,997
I just drove 2000 miles on my winter wheels torqued to ~85-90 lb/ft. When I went to re-torque them this morning to 105 lb/ft, I literally got no movement on the vast majority of the bolts before my torque wrench clicked over.
Just wanted to share this for those who may be concerned if they under-torqued the wheel. |
01-23-2016, 02:07 PM | #18 |
14
Rep 62
Thanks for the help identifying the torque requirement. Seems ridiculous that BMW would not include this information in the owners manual........like they have in the past.
01-23-2016, 03:02 PM | #19 |
208
Rep 311
Further evidence: this is from a set of OEM wheel locks. M14=140nm
07-15-2016, 05:14 PM | #20 |
16
Rep 53
Correct Torque is........
If you want to be accurate (not considering the accuracy of your torque wrench) 140nm is 103.25870089878 pounds. 120 nm is 88.50745791324. So rounding to the nearest pound, it would be 103 and 89 respectively. Incidentally, how many have had your torque wrenches recertified after 5 or 10 years of careful handling or 2 years of throwing it in the tool box.
08-22-2017, 02:57 AM | #21 |
126
Rep 615
Damnit.... I have been using 89 lbs/ft on my x3 f25 without any problems for years.... on my F80, since new i have been having wheel balancing issues. Last night i finally got tired and decided to try something myself... Unmounted the wheel and noticed right away that the wheel was over torqued. Cleaned the hubs and refitted the wheels and torqued the wheels slowly. Torque the wheels at 89 ft/lbs. Test drove it last night and after a year and half i can finally say it is butter smooth... Decided to ask the question on Google as far as the torque spec on the f80 and i find myself reading this thread. Damnit my torque is way off.... Hope i do not lose the smoothness of the car when re torquing.
