ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      08-29-2014, 10:29 AM   #1
rsutoratosu
114
Drives: Z4 3.0i
Brakes - What anti-squeal do you use ?
I ran out and didn't apply any when I change my rear brakes.. and yeah now when I tap the brakes a little I get the famous squeal noise.
What do you guys use on the pads ?
should i get something like this
http://www.ecstuning.com/BMW-E92-335...ads/ES2537721/
-Roranji
      08-29-2014, 11:56 AM   #2
Karacticus
Karacticus's Avatar
15
Drives: 2007 Z4 3.0si Coupe
I've used this stuff with pretty good success, purchased through bavauto.com
http://noisefree.com/
It's not a fancy website!
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      08-30-2014, 05:35 AM   #3
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Originally Posted by rsutoratosu View Post
Thats what I've always used. The little packets are kind of a pain to use. I believe it was The Hack who pointed out you can also get the same stuff in tubes as ATE Plastilube. Bimmerworld is one source.
      08-30-2014, 08:43 AM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
For all the metal->metal contacts on the outside (like caliper->caliper carrier, back&sides of brake pads et) I use copper grease (very thinly applied), as I find that copper grease sticks better/leaves a better film in harsh conditions than silicone grease.
For the guiding pins I use a silicon based grease as it has rubber guiding grommets/bushings. I think plastilube is also a silicon based grease.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      08-31-2014, 12:45 PM   #5
rsutoratosu
114
Drives: Z4 3.0i
thanks for info
-Roranji
zpost
