Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      08-08-2014, 02:00 PM   #1
M8 JTD
M8 JTD's Avatar
335
Drives: F31 335d & 718 GTS
Left rear mysteriously losing pressure
Hi all,
I collected my M4 on the 21st of June and have now covered just under 3500 happy miles.
One small issue though - Every week my left rear tyre consistently loses 0.2-0.3 BAR (3-4.5 PSI) more than the others.
I've checked the tyre thoroughly - no nails/nicks/punctures + put some washing-up liquid around the valve - no obvious bubbles/air escaping.
Anybody else experienced a similar issue? - Any suggestions?
Many thanks,
Joe
Future: M8 Comp & 992 911
Current: F31 335d & 718 GTS
Previous BMW's: F15 M50d, F82 M4
Previous Other: Caterham 620, Lotus Exige S, TVR Cerbera
      08-08-2014, 02:09 PM   #2
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
2415
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
Seal leak. (ie: around the rim). It isn't set properly (or there could be a nick on the rim, but that is less likely if it is new)
Put some water/soap around the rim and you should find a place it is leaking a bit.
      08-08-2014, 02:09 PM   #3
GrussGott
GrussGott's Avatar
18179
Drives: 2018 M4 Comp Indv
I had this on my e93, oddly the same tire - it was never diagnosed ... was looked at by the dealership and a tire shop with nothing found. I replaced the tires and haven't had problems since (same wheels).
It was kind of a pain in the arse, but one of those things. Sorry can't be of more help.
Originally Posted by TurtleBoy View Post
He tries to draw people into inane arguments, some weird pastime of his.
      08-08-2014, 03:44 PM   #4
Neil McRae
BMW Motorsport
Neil McRae's Avatar
235
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
get the dealer to replace the tyre on warranty.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      08-08-2014, 04:01 PM   #5
M8 JTD
M8 JTD's Avatar
335
Cheers guys
I'm already booked in at the dealer next Saturday to have the Electronic Service History re-loaded (the service history tab is missing in my idrive).
I'll get them to remove the tyre, check both wheel and tyre then re-fit/replace.
      08-08-2014, 04:28 PM   #6
nachob
2314
Drives: 2004 330i ZHP, 2022 Cayman T
Yes, if you can't find leak on valve stem or nail the seal is bad. I had this happen once and noticed one of the long moulding nipples that are about 3/4" long was bent into the sealing area producing a slow leak. I took air out of tire and pushed against sidewall to free the little flash and reinflated. Solved. Another time valve was not seating correctly and slow leak. Soapy water and spray bottle will find it.
      08-08-2014, 06:01 PM   #7
myzmak
myzmak's Avatar
2415
Drives: Lucy.
2015 F80 M3  [10.00]
Happened to me with some new wheels on my current ride. Posted all about my issues, but tire shop ruined the tires when installing and bead would not seal properly so leaked and leaked.
If it is just a minor leak you can get a sealer to keep the leak from happening.
Drivin' Lucy
      08-08-2014, 06:58 PM   #8
M3 n X5M
M3 n X5M's Avatar
172
Drives: 2011 X5 M, 2008 e90 M3 6 MT.
I have solved two cars losing air like this so far by tightening the nut around the stem just a sixth of a turn or less with some nose tip pliers. Just a hair of increase in tightness.
If this does not work then reseat the tire.
Dealers stated it was too slow a leak to detect each time, and that they needed to keep it overnight. My fix was free...
      08-09-2014, 11:48 AM   #9
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
This. But first like others above suggest throw some soapy water on tire and look for bubbles.
      08-16-2014, 10:04 AM   #10
M8 JTD
M8 JTD's Avatar
335
Thanks for all the comments/advice guys - very much appreciated.
My dealer successfully reloaded my ESH this morning - Service History tab now visible in the idrive + showing the correct date/mileage for my running in service.
Now the bad news, the issue with my left rear turned out to be a nail very close to the side. New tyre being fitted next week - dealer discounted tyre down to £220 + fitting for free so could have been worse.
f80post
