06-27-2014, 02:42 AM | #1 |
Rep 8
Golf Tee Mod?
So I have my M3 and I have brought it to my shop and disconnected the plug for the valves muffling the exhaust. It won't keep the flaps open.
Anyone have any insight? Thanks! |
06-27-2014, 04:24 AM | #2 |
195
Rep 881
I assume that ones unplugged it stays in 'normal mode' or closed valves. You'll have to find a way to keep the flaps permanently open by using a wire or similar.
06-27-2014, 03:10 PM | #5 | |
936
Rep 4,327
Drives: M340
I unplugged the connectors when all the valves were open and that solved the problem. I would assume that M4 would have a similar system as well.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
06-27-2014, 03:31 PM | #6 |
572
Rep 1,986
Did you get any error message after you unplugged cable from valve controller?
If no error code comes up, I am thinking about just cutting that portion of the exhaust that has valve flap and weld straight pipe to it. |
