European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      06-20-2014, 03:37 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
F8X M3/M4 Macht Schnell wheel spacer reference thread
One of the first things that can really enhance the appearance of your new M3 are spacers. Not only can they be aesthetically pleasing, but the added track width can improve handling characteristics as well. Often the question of "what size spacers can I run" is brought up numerous times on the forums. This can be a bit of a loaded question since there are many variables to account for.
This thread will serve as a reference to help make their decision based on the above criteria.
Examples
- Wheel choice (OEM 18", 19" or 20")
- Tire choice
- Suspension
- Driving habits/track use
- Aesthetic preference
Wheel/Tire Specifications
OEM F8X M3/M4 Wheel Specs
- 18x9.0 Front (ET29) 18x10.0 Rear (ET40), Style 513M
- 19x9.0 Front (ET29) 19x10.0 Rear (ET40), Style 437M
OEM F8X M3/M4 Tire Specs
- 18": Michelin Super Sport/Continental ContiSportContact 3: 255/40-18F, 275/40-18R
- 19": Michelin Super Sport/Continental ContiSportContact 3: 255/35-19F, 275/35-19R
OEM F8X M3/M4 ZCP Wheel Specs
- 20x9.0 Front (ET29) 18x10.0 Rear (ET40), Style 666M
- 20x9.0 Front (ET29) 19x10.0 Rear (ET40), Style 666M
OEM F8X M3/M4 ZCP Tire Specs
- 20" Michelin Pilot Super Sport/Continental ContiSportContact 3: 265/30-20F, 285/30-20R
Entry Formatting
Please submit your entries using the following formatting:
1. The year/model of your BMW: (ie: 2015 M3)
2. Wheels/offset:
Front: (ie: 18x9.0 Style 513M, ET29)
Rear: (ie: 18x10.0 Style 513M, ET40)
3. Tire size:
Front: (ie: Michelin PS2 255/40-18)
Rear: (ie: Michelin PS2 275/40-18)
4. Suspension:
(ie: Stock, Adaptive M w/ H&R Sport Springs)
5. Macht Schnell Spacer size:
Front: (ie: 18mm)
Rear: (ie: 15mm)
Let's begin.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
davem3fan185.50
      06-20-2014, 03:41 PM   #2
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Pre-Installation
There's a bit more to installing spacers than yanking the wheels off and sandwiching them between the wheels. Here's how to determine what kit is needed.
The outermost point of your tire/wheel combo will be at the outermost "bulge" of your tire's sidewall. Using a straightedge or ruler flush with both the top and bottom of the tire - measure the clearance from the outer face of the tire to the inner lip of your fender and record the results onto paper for later.
We can gauge the clearance using a tape measure:
1. Begin by jacking up the vehicle and securing with jackstands. Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush mounting surface, eliminating the chance of vibration:
2. A small amount of anti-sieze on the hub lip will make spacer removal easier if needed
3. Extended lugs must be used and are included with all Macht Schnell spacer kits and cannot be carried over from E9X chassis. Secure wheel with new fasteners and torque to 103ft lbs, reinspecting after 50 miles.
Reference
OEM Wheel Specs
18" Style 513M
Wheels: 18x9.0 Front (ET29) 18x10.0 Rear (ET40)
Tires: 18": Michelin Super Sport/Continental ContiSportContact 3: 255/40-18F, 275/40-18R
19" Style 437M
Wheels: 19x9.0 Front (ET29) 19x10.0 Rear (ET40)
Tires: 19": Michelin Super Sport/Continental ContiSportContact 3: 255/35-19F, 275/35-19R
20" Style 666M
Wheels: 20x9.0 Front (ET29) 20x10.0 Rear (ET40)
Tires: 20": Michelin Super Sport/Continental ContiSportContact 3: 265/30-20F, 285/30-20R
Installation
Tools needed
Electric/Pneumatic Impact Gun
17mm Deepwell Socket
Wire Wheel/Brush
Anti-Sieze
Torque Wrench
1. With vehicle securely on jackstands, remove wheel
2. Clean both hub surface/lip and back of wheel with wire brush to remove any surface rust
3. Brush light coat of anti-sieze onto hub lip to aid in easier removal later on
4. Install spacer onto wheel hub and line up with lug holes
5. Reinstall wheel
6. Lightly cinch provided longer wheel lugs with electric impact, DO NOT TORQUE INTO PLACE. Final torque will be applied with torque wrench.
7. Remove jackstands and lower vehicle. Torque wheel lugs with torque wrench to 103ft.lbs. with wheels on ground
8. Admire your handywork. Enjoy! Be sure to re-torque after 50 miles.
Appreciate 2
Xtabi1701.50
AND1_M369.00
      06-20-2014, 03:42 PM   #3
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Before
equipped with Macht Schnell Competition Spacer kit: (20mm front, 20mm rear)
Year/model BMW
2015 M3
Wheels/offset
Front: 19 x 9.0 Style 437M, ET29
Rear: 19 x 10.0 Style 437M, ET40
Tire size
Front: Michelin Pilot Super Sport 255/35-19
Rear: Michelin Pilot Super Sport 275/35-19
Suspension
Adaptive M Suspension, Stock springs
Spacer size
Front: 20mm
Rear: 20mm
      06-20-2014, 03:44 PM   #4
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25085
Drives: '22 Chalk Gray Porsche C2S
Tom, did Josh have spacers put on his F80 M3 today? If so, what sizes? I'll be down there to slap some on mine - as usual - once I get my car.
      06-20-2014, 04:05 PM   #5
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Just posted - Josh went 20mm square, but its very aggressive and will likely rub on cornering on lowered suspension setups.
More M3s coming in next week!
      06-20-2014, 04:08 PM   #6
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25085
Originally Posted by tom @ eas View Post
Just posted - Josh went 20mm square.
Nice. Thanks! 20mm is perfect. All it needs is a drop now. Can I use the stud kit that you guys installed on my F30 335i?
MinMax228.00
      06-20-2014, 04:09 PM   #7
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
F-chassis uses a 14mm stud, it will need to be replaced.
      06-20-2014, 04:11 PM   #8
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25085
Which F-chassis uses the 14? The F30 or F8X? I guess I'll sell the kit off my 335i if it can't be used.
      06-20-2014, 05:06 PM   #9
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Forgot about your F30! Your current lugs will work, not a problem.
      06-20-2014, 05:07 PM   #10
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25085
Sweet! Thanks Tom!
      06-20-2014, 09:20 PM   #11
Bluehinder
12
Drives: BMW M5
Just took delivery of M4. It needs spacers more than a drop. Really needs spacers. Will follow this thread.
2018 GT350
2019 Ford Raptor
2021 Porsche GT4
2024 M4 Comp Convert
      06-22-2014, 08:12 AM   #12
mlc
13
Drives: X3 M40i, Grey / Oyster
Stupid question: in order to get the same look as 20mm spacers, would one order custom wheels with ET9 & ET 20 or ET 49 & ET60?
      06-23-2014, 04:50 PM   #13
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Would be hard to find a ET60 wheel. Keeping the thread M3/M4 related to eliminate confusion, or please PM me directly.
      06-23-2014, 04:59 PM   #14
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Wheel specs and images posted in Post #2.
      06-27-2014, 05:51 PM   #15
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Year/model BMW
2015 M3
Wheels/offset
Front: (ie: 19 x 9.0 Style 437M, ET29)
Rear: (ie: 19 x 10.0 Style 437M, ET40)
Tire size
Suspension
Spacer size
Front: 12mm
Rear: 15mm
Notes
Opted to replace extended wheel lugs (included) with 90mm Macht Schnell Competition Studs since vehicle will be used on track (frequent wheel changes). Vehicle has optional Carbon Ceramic Brakes, which does not have any variances from non-equipped F8X models in terms of fitment.
F80 M3 Macht Schnell Spacer & Stud (new stance)
      06-29-2014, 03:42 PM   #16
Mikli
88
Drives: G05F36F16F82E90E86E46E36E30
Year/model BMW
2015 M3
Wheels/offset
Tire size
Suspension
Spacer size
Front: 12mm
Rear: 15mm
Is it going to work on a M4 without CCB but same spec? Or 20/20mm or 15/15mm?
      06-30-2014, 04:55 PM   #17
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Same specs apply with or without CCB.
      06-30-2014, 05:28 PM   #18
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Year/model BMW
2015 M3
Wheels/offset
Tire size
Suspension
Spacer size
Front: no spacer
Rear: 10mm
      07-01-2014, 11:39 AM   #19
purdyawesome
purdyawesome's Avatar
26
Drives: 2015 F80 M3, 2014 F15 X5
So spacers appear to be a pretty popular mod on the M3's. Most seem to maintain that the wheel wells have a better look with some amount of space taken up to fill in the gap. Here's my question- if it looks better, and it offers some minimal handling improvement, why are the cars not engineered that way? Is there a DOT rule or some sort of benchmark they need to adhere to? Or are they designed with the stock gaps because that is the geometry that the engineers at BMW found work best? Cause if it's the first, I'm interested in doing this to my ride. If it's the latter, I would be inclined to stick with what the engineers intended.
      07-01-2014, 11:42 AM   #20
purdyawesome
26
Second part of my question- at what point on the m3 with stock 19" wheels will you start having debris fly up and soil your car? My highly modified wrangler 35's stick out about 2" past my fenders and tho it looks cool, it's a pita to keep clean! I would want full fender coverage on my m3 and will want the tires to look stock- only with a subtle improvement. Thinking 20mm may be overly aggressive with my goal in mind.
      07-01-2014, 11:48 AM   #21
tom @ eas
tom @ eas's Avatar
8154
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
All vehicles are engineered to satisfy a number of needs: From perfectly flat roads to harsh winters (and everything in between). Spacers have been used for years (not only BMW), BMW uses them on the M3 GT4. Even Porsche offers them as a factory part.
Pushing the rubber outwards will always run this risk. While no one will be running 2" thick spacers on a BMW, less aggressive thicknesses will keep more fender over the tire.
      07-01-2014, 02:19 PM   #22
JTO24
never could compete with Lloyd Braun
JTO24's Avatar
5275
Drives: 2022 G80 M3 6MT
To add to Tom's post, these cars must be able to use snow chains in the winter in Germany. That means the offsets cannot be so extreme from the factory as to cause any issues once the cars are equipped with the chains.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold)
2016 981 Cayman 6MT | Jet Black (sold)
2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold)
2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold)
Tags
aggressive, eas, extended lug, lugs, macht schnell, offset, spacers
f80post
