06-19-2014, 08:41 AM | #1 |
42
Rep 154
Mille Miglia wheels installed
Finally got the wheels I ordered months ago!
19x8.5 ET42 and 19x9.5 ET44 with 235/35 and 265/30 tires I'm lowered on H&R coilovers and get a lot of rubbing in the back over large bumps. I have ordered 571lb spring rate springs to replace the stock H&R 457lb springs. That should solve the problem. Alignment is also set at maximum rear camber. |
06-19-2014, 09:43 AM | #3 |
139
Rep 575
Looks amazing!
The front doesn't rub?
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
06-19-2014, 12:24 PM | #5 |
42
Rep 154
Absolutely stock fenders.
Front will rub over very large bump when the wheels are turned. Otherwise, it will never rub. Rear is an whole other story. Can't wait to get stiffer springs installed!!! |
06-19-2014, 12:59 PM | #6 |
326
Rep 914
Stiffer springs will probably work. Also roll your rear fenders and it will give you a few more millimeters of clearance
06-19-2014, 01:13 PM | #7 | |
42
Rep 154
I've got the springs on order anyway, so I'll give that a try first. |
06-19-2014, 05:50 PM | #9 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Looks great. I think stiffer springs will ride better anyways, I plan to go that way eventually. What brand tires are you using? I'm sure you know that you can just go with smaller tires or raise your height setting.
I removed my rear seat and went with a lightweight battery to help rear weight. You are right that rolling the fender lip won't get you much. You need to try to figure out where you are rubbing and mod/pull that area. At the very least, trim the inner fender liner and the white plastic piece where the bumper and fender connects. Those are the main areas that are probably rubbing. BTW I've been running max rear camber for 10k miles or so now and not noticing uneven wear. I rarely rub now as long as I don't have extra weight in my car but I have my coils set maybe an inch higher than yours. Good luck, keep us updated.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
06-20-2014, 06:32 AM | #10 | |
42
Rep 154
I don't want to raise or go with skinnier tires. The look is so perfect as is. As for tire wear associated with camber, I'm not even worried if it's the case, these tires are cheap (yet surprisingly good) I'll update here as soon as I get the springs installed. |
06-22-2014, 06:46 AM | #12 |
Wild Card
91
Rep 683
Side shots?
Show me a sane man and I will cure him for you. |
