07-06-2017, 02:53 PM | #375 |
Rep 11
Automatic Headlight Control
Hi,
does anyone know, how to disable the automatic headlight? If the light shift is in position '0' the light control is still on. It seems to be only a feature in Germany. Is there any coding parameter to disable the light control? Thanks. |
07-06-2017, 03:31 PM | #376 |
2376
Rep 8,364
It is also a feature of Hong Kong or Taiwan. There is FDL in BDC_body; I think it may be FLC_Aktiv. Switch to freigeschaltet_in_Stellung_A.
07-07-2017, 12:50 AM | #377 |
Rep 11
07-13-2017, 09:45 PM | #379 |
21
Rep 50
Hi Almaretto, I just had my 2017 X1 at dealer for the airbag recall done today, the also performed DSC programming and SIB 12 85 17 DME update. I have no idea what exactly performed. BUT, all my coding is gone now ! I try to re-code but the "code FDL" is grey out.
My Esys is 3.27.1 with V2.6.2.124, is my code is outdated ? Can you send me the link and instruction to update my code. Thank You ! |
07-14-2017, 12:51 AM | #380 | |
2376
Rep 8,364
Fxx, Ixx, & Gxx Series Coding: (No Request) Latest Software Links |
07-17-2017, 04:16 AM | #381 |
17
Rep 45
Dear all
I coded BDC_body 3056, KOMFORT_SCHLIESSEN to "Werte = 00" for pressing car lock of keyfob to close the side mirror immediately without delay. But I still need to hold a second to close all the windows and sunroof. Is it possible to close the windows and sunroof at the same time of side mirror closed? Thank you. |
07-17-2017, 06:58 AM | #382 | |
Rep 11
after coding the automatic headlights , it would be great to have the dashboard lights alwas on. Only with DRLs the dashboard lights remain disabled. Maybe, you've got an answer to enable them permanently? Thank you. |
07-17-2017, 12:52 PM | #383 |
2376
Rep 8,364
I do not understand the question. My instrument cluster and dash are always on. They just change colors depending on time of day.
07-17-2017, 02:25 PM | #384 | |
Rep 11
German specification maybe? |
07-17-2017, 02:58 PM | #385 |
2376
Rep 8,364
07-18-2017, 12:55 PM | #387 |
Rep 39
Drives: X1 F48 25i
MAY be the instrument light setting is in low position
07-24-2017, 08:35 AM | #389 |
2362
Rep 4,255
Weirdly enough comfort close for the trunk doesn't actually work no matter how many times I code it. All the other windows work fine.
///M Power
07-25-2017, 08:01 PM | #390 |
2376
Rep 8,364
07-25-2017, 08:59 PM | #391 |
2362
Rep 4,255
Don't think so. Everything else took.
///M Power
07-26-2017, 06:14 PM | #392 |
2376
Rep 8,364
07-26-2017, 07:22 PM | #393 |
2362
Rep 4,255
Oh maybe! I was just holding the close button then tried lock neither worked. Did close the windows holding lock though.
///M Power
07-29-2017, 08:18 PM | #394 | |
2376
Rep 8,364
07-29-2017, 08:36 PM | #395 | ||
2362
Rep 4,255
///M Power
07-30-2017, 12:04 PM | #396 |
127
Rep 243
That's odd man, then again each individual car does weird things sometimes. That's one of the first things I coded, worked instantly and ever since. Also coded it to other X1s with success. Try coding it again, just that value by itself. Should work.
stefan2361.50 |
