What is wrong with my transmission? Please Help, anyone manual trans experts
08-25-2010, 10:32 AM | #23 |
Rep 102
First, I have done the CDV delete/remove and I recommend it. But with that said, I don't think it has anything to do with the problem of the OP (or the "new" OP).
The CDV effectively only affect the uptake of the clutch and not the application/down-press of the clutch. For the clunking problem, in my experience, it happens when the clutch is applied (abruptly) while the car is just transitioning into engine breaking. |
08-25-2010, 11:43 AM | #24 | |
200
Rep 1,834
Drives: '05 E90 330i Manual
And to add insult to injury, my other vehicle is an Isuzu turbo diesel pickup with a super sensitive throttle - so it's always an adjustment when going from the 330i to the Isuzu, but getting more use to it now. The only way I can explain how I find this works for me with the 330i is it's almost like you have to keep the throttle partially depressed while pushing the clutch in, and then increase as needed for the gear change. Or slightly better you need to first press the clutch in and then take your foot off the throttle - timing has to be right though to prevent the engine from revving, it's just that fraction of a second that's necessary to smooth this out. And while I type this I can still say that I don't always get this a 100% correct, but it works - even managed to get my wife to get this right. Other than that on the actual gear changes I have noticed that it can be fairly notchy especially when cold and in particular from 1st to 2nd. Then there is also the tendency to "hold" onto the gear and you have to either be a bit more firm or rather change gear a bit more slowly - once the engine and gearbox is at operating temperature it's fine though. My previous car and most other vehicles that I have driven are much the same when cold. Philip |
08-25-2010, 12:24 PM | #25 |
Rep 179
It is dual-mass flywheel. You probably notice it more when you disengage the clutch very fast. When you learn to do it a bit smoother and slower you will not notice it anymore.
CDV delete will help to feel the clutch better (much better) and improve the smoothness of your shifts, won't help with notchiness. |
08-25-2010, 01:01 PM | #26 |
200
Rep 1,834
Explain to me more about this CDV delete - apart from earlier in this thread I haven't heard of this before...
08-25-2010, 01:15 PM | #27 | |
81
Rep 177
08-25-2010, 01:31 PM | #28 | |
200
Rep 1,834
Edit: Read through it and of course very interesting! Makes a lot of sense from what I have experienced - there is a certain numbness in the clutch action which I thought was me just not yet use to it. But I find that I can consistently "swap cogs" a lot quicker and smoother in my diesel powered Isuzu pickup than the 330i! Will have to investigate this further and see if there is someone locally who could do this... Philip Last edited by Three_thirty_I; 08-25-2010 at 01:56 PM.. |
