Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What is wrong with my transmission? Please Help, anyone manual trans experts
      05-09-2010, 06:17 PM   #1
Dubs335
Drives: 2009 335xi Coupe Black
when doing form 1st to 2nd to 3th at times is were rough. I press in the clutch and i get a clunk. i took it to the dealer on more then once and they keep telling me that it is the clutch engaging and disengaging. this feels more than just the clutch engaging and disengaging because it does not happen every time i shift. Sometimes it does not do it depending on if I'm turning, going up a hill. you feel it more at lower rpm's. if anyone knows anything about manual transmission, what could cause a clunk when engaging and disengaging the clutch?
      05-09-2010, 06:38 PM   #2
sn0wwhite335
117
Drives: 2010 335i MSPORT.
2010 335i  [0.00]
i have a similar issue when shifting from 1st - 2nd...
'10 e92 335i m-sport; AW/Blk | ZPP | ZCW | NAV | Alarm | Logic7
19' 225s | JB+ | BMS DCI | CF TRiM | OEM PERF SHIFT/EBRAKE KIT
sold: 07 e92 328xi & 07 e90 335i
      05-09-2010, 07:29 PM   #3
kred
kred's Avatar
80
Drives: '07 e92 328i 6mt
every manual driver on here knows about the 1-2 shift but never heard anything like your problem. seems like somethings wrong to me
2007 Space Gray 6MT 328i / BMW SSK
      05-09-2010, 08:06 PM   #4
nyknickfan
nyknickfan's Avatar
Drives: 2008 Alpine White 335i Sedan
If there is a clunk when you shift in the gearbox try shifting at higher RPMs (around 2500-3000)...if the clunk is coming from the clutch itself then there is most likely a problem
      05-09-2010, 08:46 PM   #5
Healey3000
Drives: 2008 328i, with 3 pedals
Hi,
Pressing in the clutch (disengaging the driveline) can result in a clunk for more than one reason. If you approach the thought process by understanding how the various parts are connected, it helps to identify the contributing sources.
The first source may be the flywheel. The dual-mass flywheel has two masses connected by a stiff set of springs. When you unload the driveline, the two masses can move relative to each other, resulting in a clunk. It could be that the springs have weakened or failed but it could also be the driving style, if you still have applied throttle when you press the clutch pedal.
Backlash in the gearbox can also cause clunking. As gears wear, there is more play between them so a change in loading can cause them to move relative to each other - clunk, but a different kind of sound.
Third, the flexdisc (guibo) may be failing. How many miles do you have on the car? This is a wear item and has to be replaced eventually.
Fourth, the differential may be worn out just like the gearbox. I would suspect that this will be louder than the gearbox and more clunk-like.
A good shop can identify the culprit. Other than the guibo, these are all expensive components so take your time to really be sure before you start replacing parts.
This kind of sound will definitely be affected by driving conditions. At low RPM you are more likely to hear it; it's really a complex set of variables, primarily torque and RPM.
Hope this helps,
Adnan
      05-09-2010, 09:32 PM   #6
runrider
I pretend to be smart.
runrider's Avatar
20
Drives: '06 325i 6MT 39k
Originally Posted by Healey3000 View Post
Hi,
Hope this helps,
Adnan
Great write-up, thanks!
      05-09-2010, 09:38 PM   #7
Dubs335
i have 17,000 miles, this started happening soon after i bought it. it seemed like it happened during my break-in period, i might have been driving like an idiot. it even feels like it makes the car sway more then normal during shifting.
      05-09-2010, 10:09 PM   #8
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
Hi,
Hope this helps,
Adnan
Wow. Great post!
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      08-13-2010, 04:13 PM   #9
karlusmagnus
Drives: 2008 328xi
A little bit old to resurrect perhaps, but I have a 35k mile 328xi (2008 E92) and I find the 1st to 2nd a little clunky, while 2nd to 3rd is easier.
The car is new to me, so not sure if this is a wear item, or normal. I'd like to have a good overview before asking dealership their opinion.
My experience with manuals extends to a G50 gearbox on a porsche 964 (very straightforward) and a 915 gearbox on a 73 porsche 911 (like a bag of antlers).
Opinions welcome if what i experience is par par for course, or a wear and tear item.
Thanks
Karl.
      08-13-2010, 04:24 PM   #10
ArabianSensation
ArabianSensation's Avatar
38
Drives: M3
CDV delete? :P
      08-13-2010, 04:49 PM   #11
coh4777
29
Drives: 07 BMW 335i Coupe
1 --> 2 shift is a little "notchy" on the 3ers. Sounds normal to me, but play around with your shift point and you will find the RPM range that is smoother.
COH4777
2007 335i Coupe - Jet Black / Coral Red / Aluminum Trim / 6MT / Sport / Premium / CA / Navi / iPod + USB
      08-13-2010, 05:44 PM   #12
karlusmagnus
Drives: 2008 328xi
Thanks guys. I'll play around some more.
CDV delete is Clutch Delay Valve? Hard to believe that someone would delete this, particularly on a stock car, but anything's possible I guess.
      08-13-2010, 05:59 PM   #13
Zoraster
Zoraster's Avatar
Drives: E36, E82, E90
Why is it hard to believe? Removing that garbage results in totally smooth shifting.
      08-13-2010, 06:29 PM   #14
Majikthese42
Philosopher-king
Majikthese42's Avatar
20
Drives: 2008 E91
It's a popular modification on various BMW models, with instructions given on most of the BMW boards.
I wouldn't bother to do it, although I drive a station wagon.
Back to the OP -- I'm no expert, but I have 186k on my Volvo's original clutch. Maybe drive another one with a manual transmission and compare them?
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
      08-13-2010, 09:15 PM   #15
Catfish454
Catfish454's Avatar
Drives: 2014 550i x-Drive M-Sport
Regarding the removal of the CDV: I did it two weeks ago, and it has made a world of difference! I now feel "connected" with the clutch, where before it felt like it was in the next county. Very simple, cheap, and takes all of 15 minutes. Do it. You won't regret it!
      08-13-2010, 09:41 PM   #16
lastMleft
lastMleft's Avatar
30
Drives: e92 M3
What is CDV?
      08-13-2010, 09:59 PM   #17
IcebergM4
IcebergM4's Avatar
361
Drives: '23 M4C
Originally Posted by rider View Post
What is CDV?
CDV = Clutch Delay Valve
My 1-2 shifts are a little rough as well and I think I'll be doing this sooner than later myself.
      08-14-2010, 04:58 AM   #18
lastMleft
lastMleft's Avatar
30
Drives: e92 M3
Hey Iceberg what's the cost for CDV upgrade?
      08-25-2010, 02:08 AM   #19
silvermist99
Drives: 335i 6MT & X5D 6AT
2007 BMW 323I  [0.00]
2007 BMW 335I  [0.00]
i get clunk when I'm not acclerating in first gear. IE. going 15km/h. holding speed, clutch in and i get clunk
If I'm acclerating and clutch in, I don't get a clunk. What can this be?
      08-25-2010, 02:18 AM   #20
jayy178
25
Drives: 2007 335i Coupe / 2014 535i
i also have this on my manual, but I notice it only happens when I first start my car for the day and take it for a drive. Later in the drive or day the clunk is gone. It could be due to my adjustment to clutch/accelerrate shift point but doubt it..
2003 E46 323i (former)
2007 E92 335i M-Sport (former)
2014 F10 535i M-Sport (former)
2016 F30 328i M-Sport
2016 F15 X5 x35i M-Sport
      08-25-2010, 07:45 AM   #21
3Coupe4Me
3Coupe4Me's Avatar
81
Drives: 2007 328i Coupe
From my experience I believe that this clunk happens usually when the clutch has not been warmed up enough. It's really grippy at that point. It's also when you are being gentle with the the engine and shifting at low RPM points. I'm new to BMW and I do find the 1-2 shift is rough.
      08-25-2010, 08:05 AM   #22
MusclezMarinara
262
Drives: VALNCYA
CDV DELETE FTMFW!!! thats your problem
