Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Rubbing?
      06-17-2014, 07:21 PM   #1
LAFNGAS
Drives: 09 335I, 09 Twin Turbo GCSRT8
Rubbing?
i run michelin pss in the 235/265 size on the 19" rims, currently on my 09 335I sedan
rim specs are:
front, 19x8.5 et35 5x120 cb72.6
rear, 19x10 et33 5x120 cb72.5
the rear sounds like its rubbing however theres no marks on the fender well or tire, could it be the fender liner and has anyone else had this issue. im going to roll the rear fenders when i get home regardless but seeing if there might be any other info prior to
      06-18-2014, 01:17 AM   #2
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
rim specs are:
Yeah you most likely are rubbing somewhere, since you have 19x10 et33 at lci and tyre that is wider than normal 265/30/19 is. Fender roll should stop the rubbing. You could try to see where it rubs, there should be marks inside the wheel well or you could use chalk. One possibility could be the fender/bumper bracket.
You have basically same situation as this member http://www.e90post.com/forums/showthread.php?t=998284
Here is 19x10 et20 at pre-lci e90 with 265/30/19, fenders rolled and added camber. Your wheels would be same as et25 would be at pre-lci, so you can get away without rubbing. http://www.e90post.com/forums/showthread.php?t=977183
      06-21-2014, 11:11 AM   #3
LAFNGAS
ill take a peek when i get home, will be rolling the fenders and will look closer at the wheel well to see if im hitting elsewhere.
MUCH appreciated!!!!!!!
