BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Any Ideas on this leak?
      06-10-2014, 06:07 PM   #1
darik67u
darik67u's Avatar
Drives: 2007 335 FBO
Exclamation Any Ideas on this leak?
Hey guys,
I have been leaking oil for a few months. I got under the car today and snapped some shots of this. I'm not sure what part it is, or how the rubber sleeve was moved. Any ideas on what it is? It is located off of the oil pan, just above the steering rods. Thank sin advance for the help!
[IMG][/IMG]
      06-10-2014, 11:36 PM   #2
PichaDis11
PichaDis11's Avatar
295
Drives: E90 N52
Seems like the Waterpump. I'm almost certain that may not be your leak though. Look above the engine first then proceed down. Oil at bottom could come from various places. VCG, OFHG, OIl filter cap gasket. I only saw 1 pic btw. The last one. so I'm not sure of the others.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      06-11-2014, 10:47 AM   #3
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Check your valve cover gasket and the oil filter housing. This one is coming from the top, and these are the usual suspects.
I do not have a 335, but I heard that the turbos could leak oil in the WP area too.
      06-11-2014, 11:50 AM   #4
darik67u
darik67u's Avatar
Thanks for the help! The water pump is what has the rubber isolator popping out. I will search up top for the leak. I suspect that the oil filter gasket is leaking.
      06-11-2014, 04:44 PM   #5
bmwsinceday1
Drives: 2009 328i
looks like oil, but rub some on your finger, then dip finger in some water and gently rub the finger with thumb- if the slimy fluid dissolves/is gone, it was coolant (ethylene glycol dissolves in water), if it doesnt and remains slimy, its oil.
