06-09-2014, 02:18 PM | #1 |
Rep 11
HPDE with 8AT
I am new to the High Performance Driver Education. I want to know if I should just let the 8AT in my 2013 335i xDrive handle the shifts or should I do anything with the shift lever? My car is stock, no paddle shifters.
06-10-2014, 09:11 AM | #2 |
649
Rep 4,323
i've done it and it's been great!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
06-10-2014, 09:48 AM | #3 |
16
Rep 234
If you are brand new to the track just put it in manual mode and leave it in one gear, say 4th (depending on the track). You need to concentrate more on what's going on outside the car than what's going on inside the car. Even with manual/smg equipped cars I always recommend new students get a lay of the land first then worry about shifting. When you finally hit the top of 3rd, 4th or 5th gear then you need to start worrying about shifting. In the mean time, concentrate on your braking, turn-in, apex, exits which are far more important. If you don't get those down your gear selection won't matter much because you just can't add speed to the equation.
06-13-2014, 07:45 PM | #5 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
As for leaving it in 4th, that is good advice for new 5/6MT guys, but 8ATs are really close ratio, so leaving it in one gear would be very limiting.
Ahead of the curve for specF30
