Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Forge charge pipe and Wagner FMIC anyone ???
      06-09-2014, 02:08 AM   #1
Si-M240i
137
Drives: M240i LCI
I am thinking of changing to the forge charge pipe but wanted to know if a one has done this to the Wagner FMIC and if there were any issues? Also if running more boost is the jubilee clip going to hold out? My lowers seal keeps leaking any I don't want to keep changing it as I am just about to go to my 3rd seal in 18 months
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      06-09-2014, 07:25 AM   #2
Si-M240i
137
Drives: M240i LCI
134 reads and nobody yet
      06-09-2014, 08:06 AM   #3
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
I have the wagner ic and yet to break the OEM hose and Im pumping 425 wheel Lb/tq
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      06-09-2014, 08:09 AM   #4
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
87
Drives: 2011 335d M sport
It seems they all will leak, never seen a VW that did not...
BMW Advanced Diesel, 2011 335d M sport...
      06-10-2014, 01:42 AM   #5
Si-M240i
137
Drives: M240i LCI
Wagner emailed me back and said it should fits as all dimensions and fitting are the same as OEM. I have alocal BMW specialist (Independant) that will fit it for £60 too. I am going to order it, get a better clamp to replace the jubilee clip it comes with and get it fitted.....I will update you when done....as it's a larger bore too, I am guessing I may even get a small power gain
      06-10-2014, 06:02 PM   #6
DieselRacer
87
Let us know, I'm interested in this kind of stuff, hope it works out and adds power to boot...
      06-11-2014, 01:49 AM   #7
Si-M240i
137
Drives: M240i LCI
waiting for confirmation that I'm booked in for next wednesday
      06-13-2014, 07:24 AM   #8
Si-M240i
137
Drives: M240i LCI
all booked in and ready to go next wednesday. Getting some better clamps this weekend as I don;t want to rely on jubilee clips when I have extra boost running.
The pipe is really well made and the machining is very good too. It even can with 2 large "O" ring seals fitted in the top mount. I have ordered a new seal from BMW for the lower mount.
Update next week when fitted
      06-13-2014, 08:11 AM   #9
Puerto Rican 335d
Puerto Rico
229
Please post pics
      06-13-2014, 05:05 PM   #10
Ajs_435d
Ajs_435d's Avatar
355
Drives: 435d m sport m performance
Is this the pipe that replaces the red one?
If so i have a forge and its very tight, machined tolerances was too small.
Are you going to do a dyno run or see if it makes more power mate?
      06-16-2014, 02:05 AM   #11
Si-M240i
137
Drives: M240i LCI
ajs 335d
Yup this is the red Forge pipe. I also have the Wagner FMIC fitted so it's metal where the seal is and not plastic like the OEM one. I am hoping the tolerences are tight as I keep getting a slight leak from the lower seal. Probably because of the extra boost required for 380BHP & 600 Ft Lbs
I won't be doing a dyno run as it's not going to drop my power and it not a significant enough a change to pay for another dyno run....even though the Dyno I use is next door to where the pipe is being fitted.
      06-16-2014, 03:48 PM   #12
Ajs_435d
Ajs_435d's Avatar
355
Hi mate PM sent,
No i was asking before and after fitting of the wagner IC to see if it made a difference to power???
      06-17-2014, 01:36 AM   #13
Si-M240i
137
Drives: M240i LCI
ajs_335d
Hi Mate,
I had my remap done before the Wagner was fitted and then went back to have it "tweaked" when it was fitted...from memory I think it went up by a further 20BHP but I had also had a CKS custom exhaust fitted in the meantime with all the boxes deleted. CAT and DPF still fitted though.
Did you fit the forge pipe yourself ?
      06-18-2014, 06:01 AM   #14
Si-M240i
137
Drives: M240i LCI
All fitted and thrashed to try and make it pop off and it has stayed in place. They did modify my bottom clip to make it lock better as the Wagner fitting for the clip is slightly different.
