06-08-2014, 07:39 AM | #1 |
50
Rep 226
4 series in snow / bad weather ?
Going from a X1 that handled very well during this bad winter we just went through to a 4 series Xdrive. Anyone have actual experience with the 4 series Xdrive this winter with feed back. I'm concerned with how low the 4 is.
Also any feed back on the drive/comfort difference of the regular 4 all wheel drive VS the M sport all wheel drive? Thanks |
06-08-2014, 08:16 AM | #2 |
1435
Rep 4,724
I just got my 4, but my e92 with x-drive and proper tires was amazing in the winter. I assume my 435 with AWD will be just as good. Proper tires are the key!
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
06-08-2014, 09:05 AM | #3 |
813
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
Good winter tire is the key, and you still have to be careful over big bumps of ice as your car is much lower now.
06-08-2014, 09:33 AM | #4 | |
597
Rep 1,805
Get some blizzaks and enjoy.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
06-08-2014, 10:01 AM | #5 |
demoted
454
Rep 1,172
At 145mm the 4 series xDrive has a fair bit of ground clearance. Throw on some snow tires and unless you have more than 5" of snow you should be good to go. I've driven M3s during most winters for the past 20 years. I think my E92 had 115mm of ground clearance. I finally paid the price last winter when a chunk of ice split the DCT transmission pan (a known weak point). The only thing I don't know is whether the 435i has any such vulnerabilities.
06-08-2014, 01:20 PM | #6 |
156
Rep 1,014
I've driven an E93 (RWD) w/ sport package through the last 7 winters with 17" Blizzaks with no significant problems except during large snows when even some FWD cars have issues.
around here, roads are generally clear within 24 hours of any small or moderate snowstorm. I plan on driving my 435 vert in the winter, too; will just have to watch with the slightly lower clearance. obviously, getting winter tires and likely wheels, too, but it sounds like with the M Sport brakes, it will be 18" wheels (would have been better to go down to 17")
///M4 'vert
06-08-2014, 03:24 PM | #7 | |
demoted
454
Rep 1,172
06-08-2014, 10:47 PM | #8 | |
156
Rep 1,014
my wife has 19" wheels and swaps summer/winter tires on those, so, yes, 18" should be ok. I think all 4 tires are the same width on the 435, right? on the 335 the rears are wider (summer); I used the same width for the winters.
///M4 'vert
06-08-2014, 10:52 PM | #9 |
demoted
454
Rep 1,172
No...
