2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Exhaust Valve disconnect possible
      06-07-2014, 11:20 AM   #1
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
This is for sale on ebay:
CG Precision VSC-1 Exhaust Valve Controller BMW M135i M235i F20 F21 F22
So, can this modification work:
http://www.e90post.com/forums/showthread.php?t=80661
Will see if the switch is on my car.
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/
      06-07-2014, 12:54 PM   #2
e46m3lol
e46m3lol's Avatar
384
Drives: F30 FBO, E70 X5D, W204 C63 FBO
When I did the customer exhaust system on my 228i, I unplugged the plug that connects to the valve. I've been driving the car like this for 2 weeks now with no check engine lights what so ever.
      06-07-2014, 01:01 PM   #3
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Turn off exhaust valve actuator
Just figured that out too.
I live in South Florida so any cold weather benefit to the closed valve is lost on me.
      06-07-2014, 03:05 PM   #4
schap12
18
Drives: 2014 M235i Mineral Grey
Hey where is the actuator located on the 235? i know on the eseries its in the trunk.
thanks
2014 M235i Mineral Grey, JB4, ER DP, BMS Intake EWG Beta test, 35% e85,injen intake stage 3 fuel pump by fuel it
      06-08-2014, 12:57 AM   #5
lichenlt
28
Drives: M235i
what does it do in cold weather?
      06-08-2014, 04:02 AM   #6
1stm235i
1stm235i's Avatar
25
Drives: Estoril blue m235i
Want to do it also any help for m235i?
      06-08-2014, 06:28 AM   #7
kerm1t
169
Drives: 17 M3 ZCP Stage 2
so unplugging this keeps it open?
      06-09-2014, 03:16 PM   #8
zkeeper
zkeeper's Avatar
208
Drives: 2017 M2 & 08 Z4 si
Only if you unplug it when the system is warm and now open. The left tailpipe valve is closed when cold and secondary air pump starts process, and heats things up then signals to open valve. Sound dies down a bit, and of course you are more green now.
Unplugging the connection does not throw code, and keeps valve open. It does not then close down when things cool off back there. It adds some depth to the sound...but not much on the PE. There is no golf tee remedy on this little rocket now.
      06-09-2014, 06:41 PM   #9
kerm1t
169
i wish i can keep the warmup sound of the exhaust before it tones down.
how small is the difference in unplugging the sensor?
      06-10-2014, 09:08 AM   #10
zkeeper
zkeeper's Avatar
208
Unplugging the sensor does not do toooo much to the sound, but it does seems to add some burble depth...[zkeeper dictionary], but probably it's in the mind of me and me alone. It still will tone down, and at idle standing at rear of car its low sounding.
Start up IS nice indeed. 30-35 seconds later, down she comes. BUT now the driving sounds a bit deeper...as I said, probably in my mind and an engineer would just laugh at me, as some here might. It's all about warming exhaust emissions up and making sure we get all those terrible fossil gasses used and re-cycled as quickly as possible to keep our planet going for the next generation.
      06-10-2014, 02:47 PM   #11
kerm1t
169
interesting, i guess its best to give it a shot since its not that hard to disconnect.
i wonder if theres a way to keep the startup noise..
      06-11-2014, 12:56 PM   #12
zkeeper
zkeeper's Avatar
208
I checked....not much we can do about secondary air pump, without which will throw more codes than a 6 year old with a new decoder ring. I found out it also would make air sensors go crazy indicating too lean a mix and throw more gas at engine.
Bottom line: not much can be done about current PE sound, unless one deletes it.
Aftermarkets? Maybe, but the air pump still does what it does on start up with any rear system. MIGHT find a muffler that's really loud and then it tones down to what would be desired after warm up. Now there's a nice expensive gamble.
      07-31-2014, 11:34 PM   #13
bubsterino
171
Drives: none
delete.
      08-01-2014, 07:14 PM   #14
cbbplanet
28
Drives: space shuttle
Just want to throw it out there I run CG's valve control with my ER downpipe and the sound is definitely noticeable deeper and louder when accelerating 1-3RPM. This is from inside the car with windows closed. I'll have videos posted soon.
      08-02-2014, 04:48 PM   #15
bubsterino
171
Drives: none
hey there. having just done a muffler delete and then 24 hours later getting it out back on (eye roll), wanted to at least try this quick mod.
however, for the life of me, I cannot disconnect it...did to use a screwdriver or anything? the old one you could push it in and then pull it out but can't seem to get it out!
thanks for any help!
      08-03-2014, 07:32 PM   #16
timsev
24
Drives: BMW
You don't push anything. There is a tab you "pull" up and the plug will gently release. The tab you have to raise is plastic and is on the top side of the plug. You could literally remove the whole thing with one finger.
      08-03-2014, 11:01 PM   #17
bubsterino
171
Drives: none
thanks. I'll give it a go again tomorrow. I figured I was doing something wrong.
      04-21-2015, 08:51 PM   #18
joshbromberg
20
Drives: 228i
To bring this thread back to life, I just tried this out on my 228i and I love it. All I did was disconnect the connection to my muffler and now I get nice little burps when I let off the throttle at low rpms. The overall exhaust note is also a bit louder.
      03-25-2016, 03:25 PM   #19
DavidM235i
Macedonia
Drives: Bmw M235i 2014
Hey guys, where is this located on the M235i?
I have the M Performance Exhaust, if it makes any difference...
      03-31-2016, 08:46 AM   #20
blanquito
57
Drives: AW M235i
Is the difference anything like this? Is it as dramatic or an effect?
[u2b]https://www.youtube.com/watch?v=5FuLBewO1b0[/u2b]
2015 F22 M235i : Alpine White | Terra Dakota
2010 E92 ///M3 : Jerez Black | Black Novillo <Sold>
      06-03-2016, 10:59 PM   #21
aorland1
aorland1's Avatar
Drives: 2015 BMW M235i
Just did this on my 2015 M235i with catless DP. I have to say I am a bit disappointed. I have a BMS intake as well. The turbo spool and hiss got louder and more pronounced in my opinion but I actually felt the exhaust was pretty dim in the cabin.
I'll play with it a bit more tomorrow, I'm wondering if this is due to the noise that is piped in through the speakers. Not 100% sure if disconnecting this influences that in anyway. Either way I had my stereo either off or at a very low volume while driving so who knows. No CEL though. Anyone else do this on an M235i? I also noticed the engine doesn't need to be warm, when I turn my car off the flap is locked open. Just my two cents.
      06-13-2016, 12:42 PM   #22
Kolyan2k
922
Drives: 2006 S2000
e92 used to have a connector inside the trunk, 235 doesnt ? it would be nice to disconnect this inside the car to keep the water out of that plug
2addicts
