Harness Bars?
06-01-2014, 11:09 PM | #1 |
15
Rep 179
Harness Bars?
I have searched all over with no luck without it being the m3 harness bar(link below), does anyone have any suggestions where I can purchase one(and or if this fits)? I may be looking in the wrong place if so I highly apologize .
Trying to shave weight I am running VFF600 but got walked by a stock turbo+ E50/meth 135i(obviously alot of variables here and I was just running meth but still) but need shave weight now Thanks! Challange Harness Bar: http://europeanautosource.com/bmw/m/...mw-e92-m3.html |
06-02-2014, 07:38 AM | #2 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
But adding a harness bar only adds weight
In semi-seriousness, do you have the supporting hardware (race seats & harnesses)? Also are you even sure if a harness bar is legal for which ever race/school/club you drive with? Or is this purely for street? |
06-02-2014, 10:30 AM | #3 |
15
Rep 179
True however removing the rear seats, and the front seats to be replaced with a set of Corbeau FX1 Pro(19 lbs) seats will be a nice savings I understand you still have to add in the harness bar and the harnesses. Purely for the street(possibly looking to track in near future), nothing else will be removed besides swapping for braille 21 lb battery(I have iDrive I do live in WI but not driving in winter so not worried if it doesn't crank over). Then I currently have a set of 19 M5 reps(wrapped in PSS) I cannot find anywhere but suspect they are 30 lbs each so I was looking to replace those with a set of ARC8 wheels. Any suggestions are more then welcome .
Hard to make more power because of AT so the new HPFP sure I could run 100% E85 but it would blow sadly. For now with adding exhaust I'll be at the 630WHP+- range which is great. It's a hard battle because both are equal options, but both can get $$$. I'm not joking that 135i walked away, however he is around 3250 with half tank no back seats and has LSD running E50. I had a full tank of gas, no E85, full tank of meth(4.5 gallons) and two others in car with me. I'm searching my local area for a scale right now. |
06-03-2014, 08:13 AM | #4 | |
2286
Rep 12,565
You still get plenty of weight savings by switching to race seats and IMO the factory 3 points would probably be safer if you route the lap belt correctly. I wouldn't bother running a Braile unless it was a full on track car and you were trying to shed every pound possible. For a daily I honestly don't see the purpose and same goes for removing the back seats. But if you're just doing it for looks, knock yourself out though. |
06-03-2014, 07:10 PM | #5 | |
20
Rep 147
I can't decide if your brain is having a bad day/life, or if you just can't interpret a weight saving thread. If he wanted advice on how to daily/keep a car looking nice he would have asked. This is about being light and fast not about how you want his car to be on a daily basis. nor did he say a word about the track, he got raped and is out for blood. customize your car how you want and leave it at that, if you want to be a helpful forum poster then post helpful things based on what people want not what you believe they should do. |
06-03-2014, 07:31 PM | #6 | |
2286
Rep 12,565
So maybe you're all about giving pimpmyride-esque advice w/o safety concern but that isn't how I help folks out. Go run along to the photo/video gallery or the cosmetic section. This sub-forum is for people who know a thing or two or wish to learn something. |
tetsuo1111227.00 |
06-03-2014, 09:24 PM | #7 | |
2286
Rep 12,565
Factory 3 points and race seats are only a concern when the lap belt is routed over the side bolster. This could lead to a submarining effect which is why it's typically looked down upon. But if you can route the side belt through the side hole, you're able to negate the effects of the submarining by maintaing the original geometry as well as having the ability to move your head during a rollover. This is something you can't do if if you're strapped into a harness with harness bar but no roll bar. The roof could cave and lead to spinal compression. A harness bar welded to the floor for support? Yea in theory that's great but nobody sells one and regardless, the one OP was looking at isn't designed like that which is why I told him it's not a good idea. Of course a half cage is better, and that's what I run in my car but it was clear OP was looking for a bolt-in harness bar. I'll keep my cars thanks, perhaps you should stop reading interwebz blind leading the blind and come out to the track and talk to real racers. OP if my response wasn't the answer you were looking for, well I'm not going to apologize because I genuinely believe I was giving you sound advice regarding safety. You posted in the Track section and most folks who track their cars and understand the safety aspects will advise against a harness bar only. FWIW I think Brey Krause may offer one but I've yet to see anyone install one in their E9x. |
06-03-2014, 09:45 PM | #8 |
20
Rep 147
lastly he did not ask if hew should do a bar, he asked which to get, it's up to him weather or not it gets old, not for everyone. the i'm thinking people who buy a 600 whp kit may not have safety in mind but going fast, it also doesn't mean it's his daily. lighter=faster it's math....(joke seeing as you won't get it)
What you need to do is buy a town and country according to you because it's easy, comfortable, and safe... why do you even track? obviously not willing to show up to play with the big boys simply be there to be the guy everyone hates because they have to pass you every lap due to you being "safe" I didn't get into motor sports to be safe i did it to have fun... Last edited by pwilde; 06-03-2014 at 09:52 PM.. |
06-04-2014, 08:45 AM | #10 | |
20
Rep 147
And way to go about post count, that totally makes sense because there is race care engineers that have things to contribute and much knowledge who never have posted on a forum... but at least you have more post so your smarter right? |
