e90 thermostat and water pump question
06-01-2014, 08:34 PM | #1 |
Rep 40
this is a common issue and i have read some post here
any recommendation of when should one do a prophylactic change? my car is a 2006 335i with only 35k km true mileage but my main ques is are the new thermostat and water pump really improved compared to the old ones? if yes, what is modified to make it less easy to fail? afterall if it is just the same, then theres no point of a prophylactic change? thanks |
06-01-2014, 08:38 PM | #2 |
33
Rep 655
06-01-2014, 09:49 PM | #3 |
Beamer Mantic
82
Rep 1,191
My original water pump is just now showing signs of T-Stat failure and my 06 325i has over 220000. miles on her.
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
06-01-2014, 10:51 PM | #4 |
Rep 68
They are both very different. Some aren't even made by the same manufacturer. If anyone in the middle tennesse area wants it don't cheaper than a dealer or Indy. I can help you out.
06-02-2014, 12:27 AM | #5 |
Rep 40
06-02-2014, 01:04 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
It's pretty expensive to change prophylactically. They tend to fail around 100k miles. Mine went at about 80k miles. With such low mileage, yours might still last for a long time.
06-02-2014, 07:38 AM | #7 |
92
Rep 440
I can't say if it's any better or not, but my water pump failed at around 60K miles and I had to have it replaced.
06-02-2014, 07:44 AM | #8 |
Accepting Donations
Rep 333
Drives: Montego Blue E92
OP I assume you have no warranties currently on the car?
06-02-2014, 07:52 AM | #10 |
Beamer Mantic
82
Rep 1,191
I am now experiencing a 2EF4 code thermostat map not reading correctly or stuck open, I can reset it, but it comes back after a week or two. According to many forums this is the first sign of water pump failure and from what I have read it seems to be fairly accurate.
There is a safeguard that was built into these thermostats that fails open if there is an issue and your car run cool all the time and less efficient. Hope this helps!
2006 325i
06-02-2014, 11:49 AM | #11 | |
Rep 40
thanks a lot just did a search, looks like b4 the pump fail, there will be a code 2e81 for a while before it fail one day and the code 2ef4 is for thermostat which is usually asso with the SES light on |
06-02-2014, 11:56 AM | #12 |
Rep 40
in case anyone wants to know, heres a detailed thread
http://www.e90post.com/forums/showthread.php?t=561183 the problem appears to be the electronic part of the pump which deteriorate over time due to heat but i still cannot find a post that specifically describe what is improved in the new part hope someone can give me some insight on that also. may i know is this problem also in other bmw models with n52 n54 engines? thanks |
06-02-2014, 04:46 PM | #14 |
70
Rep 628
When warning signs occur, death is certain, no time to CPR, by this I mean, the temp light goes orange to red, BMWs jet engine fan that they put into the N54 starts up and the car goes into limp mode, mine wouldn't even move failed at around 125km or 77k miles
06-02-2014, 04:52 PM | #15 | |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
I searched the forum on this, it's not clear to me that this indicates near term failure for the wp, though I'll be checking codes for it more often than previously. |
06-02-2014, 05:24 PM | #16 | |
964
Rep 3,854
Drives: 330i, 135i
06-02-2014, 05:33 PM | #18 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
I had never heard that term used in automotive context like that but I like it.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
06-02-2014, 05:33 PM | #19 |
Accepting Donations
Rep 333
strong User Title to post content ratio
2009 Montego Blue E92 Sold
06-02-2014, 07:41 PM | #20 |
Diamond Geezer
212
Rep 2,385
06-02-2014, 08:00 PM | #21 | |
Rep 40
do u have the ses light on? may i ask from your reading, 2ef4 means the thermostat already fail or pending to fail? it would be great if you can share some of the useful post that u read thanks |
06-02-2014, 08:53 PM | #22 | |
Beamer Mantic
82
Rep 1,191
It just mean it didn't map (stat location time frame -v- resistive value) correctly.
2006 325i
