Check your serpentine belt,mine broke and went into the engine.
05-31-2014, 09:52 AM | #1 |
24
Rep 161
My serpentine belt broken on me about a month ago, didn't think about it too much. Went to bmw got myself a new belt and put it on. All was fine, drove it for few weeks then my throw a 2A87 and 3100 code. I searched the forum and got myself two new vanos solenoids. Then new exhaust cams sensor. Still having same code. Then more reading I found out I might be the victim who have the cam bearing ledge problem. So took my car to eurowerks in florida. They said mostly is the cam ledgs problem plus hook rings. Once they open up my engine. They found my old belt made its way into timing chain from the front crank seal, they are trying to fish it out now. Still wanting on update.
Don't know was it the belt cause those problem or just my luck. so far the damage is front crank seal, new intake and exhaust cam bearing ledge plus hook ring. Looking at a $2000 bills. Moe update on post 17 Last edited by wanna325i; 05-31-2014 at 03:39 PM.. |
05-31-2014, 09:59 AM | #2 |
295
Rep 2,202
Thanks for the heads up brother!
I've been pondering on replacing the pulleys and such for a couple months now from a recent oil cap filter leak I had.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
05-31-2014, 10:02 AM | #3 |
24
Rep 161
yeah, i do have oil filter leak to begin with when my belt slip off. So everybody who have a oil filter do not delay on fixing it
05-31-2014, 12:01 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Thx for the warning. Hope your car's fine after bro.
05-31-2014, 12:25 PM | #6 |
Rep 263
Drives: E46, E91, F21
05-31-2014, 12:30 PM | #7 |
98
Rep 1,647
Same thing happened with me. Dealership fished out the pulley out of the engine as much as possible but never ran the same after. Later bigger issues happened had my engine replaced 6 months later
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3 |
05-31-2014, 01:39 PM | #8 |
Rep 8
Wow
It's kinda scary that you post this OP on the same day that I posted this thread regarding my car.
http://www.e90post.com/forums/showthread.php?t=992424 |
05-31-2014, 01:45 PM | #9 |
26
Rep 551
Damn, thanks for the heads up, bro. My car is at 106K and the belt is still the original one.
I'm going to order a new one and make sure I replace as a preventive maintenance, before it breaks and creates havoc. |
05-31-2014, 02:01 PM | #10 |
Libertarian
132
Rep 1,577
I wonder if this affects the N55 engine in the 335?
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
05-31-2014, 02:39 PM | #11 | |
Rep 263
05-31-2014, 03:00 PM | #14 | |
24
Rep 161
05-31-2014, 03:04 PM | #15 | |
24
Rep 161
77K |
05-31-2014, 03:12 PM | #17 |
24
Rep 161
More update from the shop. I will need new camshafts. Camshafts were damage cause lack of oil. Now the question is will it be stupid idea to put a used camshafts in it?? Or I should put a brand new pair?
Good news is they were able to fish out my old belt. |
05-31-2014, 03:27 PM | #18 |
217
Rep 1,909
05-31-2014, 03:38 PM | #19 |
24
Rep 161
05-31-2014, 03:47 PM | #20 |
35
Rep 1,652
I read it was resolved after 08 model. Hopefully I'll just have to worry about replacing at a normal interval. Still, good thing to know about in case there's any weird symptoms down the road.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
05-31-2014, 04:25 PM | #21 |
41
Rep 642
Started occasionally hearing belt chirp when I start my car in the mornings. Read around here and figured it was the pully not spinning freely because its bearings are going out and will probably lead to problems with the belt. Ordered the parts kit from Amazon (belt, pully, tensioner and bolt ) and a month later still haven't replaced. Just don't feel like working on the car. But you have motivated me, because I really don't feel like working on the car with the problems you got because of a snapped belt.
05-31-2014, 04:59 PM | #22 | |
24
Rep 161
