Idle Surging
05-29-2014, 09:14 AM | #1 |
President
Rep 239
Drives: e92 Coupe Crimson Red
Garage List 2011 Mercedes-Benz ... [0.00]
2009 Posche Cayenne S [0.00] 2000 BMW 323CI [0.00] 2007 BMW 328xi Coupe [0.00] |
Idle Surging
Alot of the time during the day while im out driving in the heat, I will usually get quite a few surges or points where the car whille suddenly jerk, making the idle fall about 200 revs and then balance back out. THIS ALMOST ALWAYS HAPPENS WHEN IT IS WARM OUTSIDE BUT ALMOST NEVER WHEN ITS EARLY IN THE MORNING AND CHILLY. Ive been trying to diagnose it for some time now, but i was recently told by a local indy shop that since it is only when the car is sitting at idle without being under load such as half throttle driving, that it is most likely just a vacuum leak. Can anybody confirm this or give me some type of answer to what I should do?
05-29-2014, 12:17 PM | #2 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Ate you talking about when you're at a stop light it goes from 600 to 800 rpms then back down? It happens like once or twice but then it stops. Thought that was normal for the 335i Idk about the 328. For me it's really rare so Idk. I don't worry about it cause I've seen it before. If your symptom is a little different please elaborate.
05-29-2014, 01:25 PM | #4 |
The power of V!
99
Rep 1,971
Drives: 2007 335i coupe steptronic
Garage List 1998 Lexus Gs400 [0.00]
2010 ebony & ivory [0.00] 2006 BMW X3 [0.00] 2009 pics [0.00] 2009 e92 335 xdrive [0.00] |
hpfp
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm. |
05-29-2014, 01:26 PM | #5 | |
President
Rep 239
05-29-2014, 02:20 PM | #6 |
35
Rep 1,652
Well i probably don't jerk cause i'm in a MT and at idle im in Neutral, is yours AT?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
05-30-2014, 08:43 AM | #7 |
221
Rep 1,073
Drives: 1991 318is; 2017 M2
05-30-2014, 09:13 AM | #8 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
Could be a gummed up injector, a bad coil pack, bad spark plug, or it could be fixed with a DME update.
My car had a rough idle here and there. The dealership performed SIB 12-21-12 (which I've not been able to find details for) and it seemed to get better. It still happens from time to time, but not as frequently and it smooths out more quickly if it does come up. Good luck!
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
05-30-2014, 11:43 AM | #9 |
Rep 263
Drives: E46, E91, F21
Check your eccentric shaft sensor connector. See if you have oil residue in it. It's a free and easy check and at least you can check that box off the list.
05-30-2014, 11:50 AM | #10 | |
964
Rep 3,854
Drives: 330i, 135i
05-30-2014, 02:58 PM | #11 |
The power of V!
99
Rep 1,971
I can't tell from the e90post phone app who has what. lol
05-31-2014, 03:05 PM | #12 |
President
Rep 239
I think I have it narrowed down to the eccentric shaft sensor. It had oil in it when we did the VCG and we didnt think anything of it. I guess thats probably it.
05-31-2014, 03:27 PM | #13 |
35
Rep 1,652
05-31-2014, 03:28 PM | #14 |
President
Rep 239
05-31-2014, 03:32 PM | #15 |
35
Rep 1,652
