Damn Son! Car starts when it feels like it (Video Inside)
05-27-2014, 09:55 AM | #1 |
Rep 65
Hey guys I had this happen to me once before where my car would not start and the screen between the gauges would flicker and show lines. My fix back then was to plug it in with a trickle charger or boost it and that worked and still works.
Fast forward to this week and this started happening again except this time it happened to me at work and with no one around to jump start me or no plugs for my trickle charger I tried pushing to start a couple of times and after about 4 tries it started up, not without its share of ABS and other faults mind you. This "push-a-couple-of-times-to-start" worked twice so far. The battery compartment does not seem to have water inside nor is it damp. I did notice though that it DOES seem like it happens more on days where it's raining or it rained before but I'm not sure if this can be related at all. Please see the video below for a better description of what happens. BTW I do get "increased battery discharge" every once in a while. Battery seems OK though.. View My Video
2009 BMW 335i e92 --- Black Sapphire Metallic / Coral Red Dakota / iDrive / Sport Package / Comfort Access
05-27-2014, 11:57 AM | #2 |
687
Rep 2,770
It looks like it is time for a new battery. When a battery is going out it can cause all kinds of little gremlins like this. Don't forget you need to have the replacement battery coded to the car.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
05-27-2014, 12:28 PM | #4 |
Rep 65
Yeah are you sure? Why did it start after 4 tries though and the accessories work? I will probably end up replacing the battery but if its something else causing a short or something I don't want to put a new battery to waste
05-27-2014, 01:00 PM | #5 |
687
Rep 2,770
These cars are filled to the brim with computers. They do not like having "unclean" power (i.e. voltages not within normal). That is what is causing all of your issues. The battery is toast. You battery is 5 years old so it is due.
05-27-2014, 02:32 PM | #6 |
Rep 65
Fair enough! Thanks for your answers I really appreciate it. So I will replace the battery. Hopefully there is nothing causing a short and draining it too much and it won't happen with the new battery.
05-27-2014, 03:31 PM | #7 |
687
Rep 2,770
Good luck. And be sure that whoever replaces the battery knows how to register it correctly in the car. The car needs to know it has a brand new battery and what capacity and type it is to work correctly (yes, it is that picky unfortunately).
As for a short, I doubt it. A short would have other issues (like smoke or something not working at all).
05-30-2014, 09:37 PM | #8 |
Rep 65
Alright got my appointment Monday for battery change at an indy shop. ~200$ +tx parts and labor. Not so bad.
Once I get the car to start i sometimes get a "abs malfunction" on the dash that goes away after a few seconds/minutes: should i also be looking at something else? It only happens when the car struggles to start |
05-31-2014, 12:42 PM | #9 |
1086
Rep 1,912
That is also because of the battery. Computer controlled or electrical systems show faults when they arent getting enough electricity.
06-08-2014, 11:44 AM | #11 |
Rep 65
Battery change fixed everything! thanks guys
