Scangauge 2 clears codes...
05-26-2014, 01:23 PM | #1 |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
Scangauge 2 is for sale for $109 for Advance Auto with promo code, it will clear your JBD codes and at the same time monitor all your vital gauges plus do a ton of other functions...cheaper than the JB scan tool plus it monitors...
BMW Advanced Diesel, 2011 335d M sport...
05-26-2014, 09:30 PM | #4 |
87
Rep 783
I did not order one for my bmw I just saw the sale, I did not know it wont read egt any reason why not...
08-24-2015, 05:13 PM | #5 |
Rep 69
New X-gauges for Scangauge (SGII)
For the few that have a Scangauge, I just received my SG II back with new x-gauges loaded onto it. I was a test mule for SGII.
Please see the attached for all of the gauges. I should be able to try them out this week. While the SGII is strictly a reader, the new addition of information is amazing. There is EGR activity, CAT temps, Status since last regen, and even urea consumption. Hopefully, all of the gauges will work.
VAC Performance Built Differential with Quaife
Snow Performance MPG MAX Injection System |
08-24-2015, 06:07 PM | #7 | |
Warrant Officer
375
Rep 1,341
Deleted, ATM I/C and tuned by B.R.R.
09-14-2015, 05:16 PM | #8 |
Rep 69
Follow-up assessment:
Most of the x-gauges work. The Scangauge engineers were great to work with and helped correct the gauges that were not working. I would imagine the Scangauge website will be updated with the new x-gauges. Of great use is the EGR (to determine when a regen is taking place); SLR (Status since Last Regen--displays miles/kms when last regen started); all the cat temps one could ever need. Charge Air Temp is also available. Right now, I have Temperature in SCR Cat Converter, EGR, MPH, and Coolant temp. I'll cycle between Load, SLR, and Charge Air Temp as required. I'll list the ones I know: Status Last Regeneration (km) TXD: 06F1122C1022E7 RXF: E56C06100000 RXD: 3810 MTH: 010003E80000 -- If you want to read SLR in miles, use a MTH of 010006490000. NAM: SLR Exhaust Temperature Before Cat (Degrees Fahrenheit) TXD: 06F1122C10085A RXF: E56C06100000 RXD: 3008 MTH: 000E0001FFC6 NAM: TBC Commanded EGR(%) TXD: 07E0012C RXF: 0441052C0000 RXD: 2808 MTH: 006400FF0000 NAM: EGR
09-14-2015, 06:34 PM | #9 | |
Warrant Officer
375
Rep 1,341
Thank you for the X-Gauges.
09-14-2015, 07:21 PM | #10 |
Rep 69
I believe Charge Air Pressure works. I don't have anything to compare to the reading. Do you think it's boost pressure?
Also, it looks like I jumped the gun on those codes. My scangauge has a different firmware than stock. See below for the message I received from the software engineer. In other words, the X-gauges won't work unless you have the new firmware. "With regard to posting the codes online, I would avoid that for the time being. The firmware you currently have has extra unreleased coding designed to handle these BMW XGauges, so if anyone else tried these with their ScanGauge, they wouldn't work. You're welcome to let people know what gauges we have working, and if people are interested they can get in touch with me and I can update their units to this experimental firmware or they can purchase a ScanGauge directly from us with this firmware installed." James DeLong is the software engineer and can be reached at xgauge@linear-logic.com
09-17-2015, 10:16 PM | #11 | |
Warrant Officer
375
Rep 1,341
09-23-2015, 10:34 PM | #12 |
Warrant Officer
375
Rep 1,341
I received mine back from him. CAP is boost pressure, and it is absolute pressure as well. At least now I have a use for my ScanGauge again.
09-26-2015, 12:48 PM | #13 | |
Rep 69
Also, do you think CAP is reading correctly? I have a boost gauge in my Snow Performance system and will have to compare the two values.
09-26-2015, 09:54 PM | #14 | |
Warrant Officer
375
Rep 1,341
I found the "TBC" gauge had a more accurate temperature reading for the DPF. It will also show when the regen is happening, opposed to relying on the EGR value.
02-26-2016, 04:35 PM | #15 |
22
Rep 64
Was hoping someone could give me some help here I've got a ScanGauge 2 that's around 5 years old running Version 4 software. Took it out of my other vehicle where it's been working flawlessly for the last 4-5 years and tried plugging it into my 2009 335d to erase a CEL caused by the JBD Tuning Box and the SC2 wont connect. Tried troubleshooting and tried every different mode and tried forcing it to connect but nothing would work.
