Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Repeated Ignition Coil Failure?
      05-25-2014, 07:17 PM   #1
bdardashti
bdardashti's Avatar
47
Drives: '12 135i
Hello everyone,
I have a 2011 328i with 88K KM (53K miles) and a few months ago, my car started intermittently 'stuttering' under load. By load, I mean any time when you applied more than 50% throttle (enough to get from 0-60 in 8-9s, perhaps). At this time, I was in warranty. I took it to the dealer, they said they couldn't detect any issues. Few months later, it became much more prevalent. I took it back, they refused to look at it without a diagnostic fee, and said if they could diagnose, it'd be a charged repair. Few days later, I got a check engine light. Took it to my indie BMW mechanic, and he plugged it in and found a cyl 3 misfire - replaced the ignition coil, and we're good to go. Car runs normal, and no errors in his system. Last weeks ago, issue comes back (not intermittent, and very rough this time). Take it back, cylinder 1 is misfiring now. Change ignition coil, and good to go. Now, with probably less than 300/400 miles on the new part, the issue is back (very rough again).
Is there a possible issue with the engine or something else that's damaging these coils? I know he's using genuine BMW parts, and this guy is trusted by many in the GTA as being much more of an expert than the best at the dealerships, so I don't think he's doing something wrong. I've got 5 months left on my lease, and don't want to give up $4k by parking the car and getting something else. Any ideas?
Thanks for your help!
      05-25-2014, 07:28 PM   #2
SS e93
27
Drives: e93 M3
Carbon buildup, or spark plugs.
      05-25-2014, 07:56 PM   #3
Zach1328
39
Drives: 2008 535i / 2007 335i
As far as I knew only the n54 twin turbo engines have serious issues with carbon build-up due to the direct fuel injection.
I think the 328xi uses sequential fuel injection so carbon build-up shouldn't be an issue.
Weak spark plugs is a little mysterious at 53k miles, but that could definitely be the issue. Luckily spark plugs are less than $10 each so you could change all 6 for ~$50 and see if that does the trick.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings
      05-25-2014, 08:12 PM   #4
bdardashti
bdardashti's Avatar
47
Drives: '12 135i
Thanks! Would faulty spark plugs damage the ignition coils?
      05-25-2014, 08:15 PM   #5
Miller335
291
Drives: 2007 E92
Bad plugs can cause a significant spike in voltage within the coils according to websites like ngk.
Easy to replace as well.
      05-25-2014, 08:25 PM   #6
ctuna
1911
Drives: 325xi 06 wagon MT
They tend to give out at the same time.
You have 6 of them with nearly the same amount of use on each one
they may start failing one after the other . I would change them all out and the plugs as well. Since you have a 328 Intake cleaning is not on your list
of things to do.
Well at 55k miles your plugs should be OK but maybe
you got a bad batch of coils.
      05-25-2014, 08:50 PM   #7
bdardashti
bdardashti's Avatar
47
Drives: '12 135i
Thanks guys, I'll replace the spark plugs - hopefully that takes care of it.
      05-25-2014, 09:00 PM   #8
Zach1328
39
Goodluck! Hopefully that will take care of the issue.
Faulty spark plugs put more stress on the coils since they increase voltage as Miller335 mentioned. Its possible your ignition coils are all on their way out too, but its ~$50 for 1 ignition coil vs. $50 for all 6 plugs so your best bet is to start with the spark plugs and hope that works.
Even if you need all new ignition coils the spark plugs should be changed anyways incase they were faulty and causing your ignition coils to wear faster due to increased stress.
07 335i
      05-25-2014, 10:22 PM   #9
ctuna
1911
You should do the rest of the coils as well.
      05-25-2014, 11:44 PM   #10
bdardashti
bdardashti's Avatar
47
Drives: '12 135i
Any particular reason? Not trying to dispute the point - just trying to learn. Thanks!
      05-26-2014, 12:09 AM   #11
e90coast
e90coast's Avatar
28
Drives: m4
Try the vanos plug thingies
      05-26-2014, 01:27 AM   #12
ctuna
1911
You can keep doing them one at a time or
You can keep doing them one at a time or get it over with.
They usually last till around 70 to 90 k miles. If you got a bad batch its likely the others will fail soon.
      05-26-2014, 03:09 AM   #13
A-BAMF
Drives: 2006 325i Barrique Red
I just did this as preventive maintenance. Ensure the connector properly mates with the ignition coil. I had #4 not latch properly, you can tell visually if the connector didn't seat correctly, and it created a rough idle. No cel. After firmly reseating #4, all good.
As stated above, replace any that haven't already failed.
      05-27-2014, 03:31 PM   #14
924er
352
Drives: e92 335i '10
dude i would replace all 6 coils and plugs if you have the money. that would rule out a lot of parts. then if it keeps happening its probably your injectors but thats rare in a 328. how are your cold starts?
      05-28-2014, 08:27 PM   #15
gray boy
Drives: 2011 328ix
many coil are being replaced. plugs should not be going at 50k
one of mine went at 26k, i call BMW customer service and complained becasue my SA indicated that they had a lot of them in stock.. meaning they expected to be used.
got calls and emails back but?
      05-29-2014, 08:54 AM   #16
steel609
Drives: 2010 328i xDrive Coupe
Hello everyone,
I have had the same issues in my 2010 328i xdrive. I had #1 coil replaced at 44,000 under warranty, #6 replaced by my mechanic at 53,000 and have another failing that I will be replacing this weekend at 60,000.
I have decided to go ahead and replace all spark plugs as well. I bought 6 from O'Reilly's for less than $40, the coil was another $60. I'm probably going to order a 4 pack of coils to replace the remaining ones and have 1 set back as a spare, just in case.
It has taught me to accelerate a little slower at take off so I guess that's a good thing.
      05-29-2014, 01:42 PM   #17
r0bert
14
Drives: 2012 E92 335i, 2008 E90 328i
I bought 6 bosch ones from amazon for $160. I would change them all. Not hard to change yourself either. I recommend changing spark plugs while you are at it.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
