BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      12-02-2007, 11:57 AM   #1
thooooorgal
Drives: M3 E92 = delivery feb 2008
Winter tyres
I will receive my M3 in february ... cold season, and i want to put winter tyres / rim.
Any feedback on which tyres (size, prices, handling ....) i can choose.
On my previous E60, i had 17' wheels, but i'm not sure it is possible to put 17' rim on an M3.
Thanks in advance
      12-02-2007, 12:12 PM   #2
the_stranger
the_stranger's Avatar
India
37
Drives: e92 M3 6MT
http://www.m3post.com/forums/showthr...hlight=m3+snow
Try that thread. He has winter tires on his M3. Hope that helps.
2008 e92 M3 6MT AW/BLACK (SOLD)
2009 e92 M3 6MT AW/FR
      12-02-2007, 01:47 PM   #3
thooooorgal
thanks for the link.
Pretty strange, the owner has put 245/40/18 both on front and rear wheels.
Stock 18' has the following size :
245/40/18 & 265/40/18.
Should we not keep the same difference between front and rear wheels ??
He has noticed that dsc is flashing all the times with its config.
      12-03-2007, 01:15 AM   #4
UltimateBMW
UltimateBMW's Avatar
399
Drives: MP4
Wider tires perform worse in snow since the larger surface area of the tire reduces its ability to cut in and create traction. In most cases when you get winter tires they don't come in 8" widths, 7" is the largest I've seen. His DSC is flashing because his BMW is RWD and he has wider tires there.
It's always possible to put a smaller rim diameter on your car, you just need tires with thicker walls to accommodate. If your 17" rims are 5 lugnut designed and not some crazy offset I bet they will work fine.
Just so you know, in the tire dimensions the convention is:
Tire tread width / wall height / rim diameter
      12-03-2007, 08:32 AM   #5
thooooorgal
thanks for you answer ultimate, but i'm not sure this is correct.
Tyre sizes is expressed like this i think :
tyre tread width (expressed in millimeters) / wall height (expressed in % of the tyre width) / rim diameter (expressed in inches)
so the front wheel of the M3 does not have the same size of the rear wheel.
In the set used by the M3 owner in the post above, he has choosen the same wheels for front and rear wheel -> this is why the DSC is flashing all the time, as it has been configured for 2 different size of wheels.
Can anybody correct me if i'm wrong ?
      12-03-2007, 10:04 AM   #6
Bastet
Bastet's Avatar
Belgium
18
Drives: M3 E92 aka 'Batmobile'
Thooooorgal, are you buying your winter tyres straight from BMW or somewhere else in Luxembourg (Goedert for ex) for your M3 ? As far as I know, the BMW "winter kit" for M3 is not yet available and we have exactly the same problem, our M3 should arrive on the 3rd week of January and I don't really want to drive it without winter tyres, specially if there's snow/ice.
      12-03-2007, 10:32 AM   #7
thooooorgal
Hi bastet,
the world is small ^^
i'm looking for the best bargain for the tyres, surely after-markets one.
Do not hesitate to post here the config you will find. (size, price, ...)
      12-03-2007, 12:01 PM   #8
Bastet
Bastet's Avatar
Belgium
18
Indeed . We'll keep you posted about the tyres. Our BMW dealer at Esch sur Alzette gave us an estimation for the tyres + rims (around 1800 €), but I'd really like to see the rims, because we wouldn't want anything that doesn't match the glorious all black M3 now, would we ?
      12-03-2007, 12:38 PM   #9
thooooorgal
I have seen a white M3 with winter tyres last week in luxembourg. He had exactly the same as the last two pictures of Ilron's M3 in this thread :
but i did not check the sizes of the tires
      12-03-2007, 02:28 PM   #10
southlight
Moderator / European Editor
southlight's Avatar
1494
Drives: X3M
Yeah, that are the official winter wheels for the M3, in Germany they run on Michelin Pilot Alpin PA3, 235/40 R18 front and rear.
Best regards, south
      12-03-2007, 04:53 PM   #11
thooooorgal
strange size, and no difference between Front and rear as for 18' / 19' OEM.
      12-04-2007, 08:31 AM   #12
southlight
southlight's Avatar
1494
Drives: X3M
It's just in line with the other OEM M winter wheels:
Z4M has 225/40 front and rear, M5/6 have 245/45 front and rear.
The same size for front and rear tires is said to be best for winter usage.
Best regards, south
      12-04-2007, 01:06 PM   #13
Becksgold
14
Drives: E90
As far as I know, an important factor is the size of the brake discs (rotors)- they dictate the smallest diameter wheel which can be fitted..
      12-04-2007, 01:36 PM   #14
thooooorgal
yes, i'm not sure if 17' would fit due to the size of the brake disks.
      12-11-2007, 08:10 AM   #15
Bastet
Bastet's Avatar
Belgium
18
Thoooooooorgal, this is what I received this morning from BMW:
"L'action pneu hiver est sur du Michelin et les jantes sont les jantes d'origine, comme sur votre commande. Le prix est de 2400€ttc". I have asked them to confirm me the exact type of Michelin tyres as well as the exact size. Then we can go hunting somewhere else...
      12-11-2007, 11:53 AM   #16
thooooorgal
thanks for the info ...
EUR 2'400
i will look in aftermarket winter wheels ^^
      12-11-2007, 12:07 PM   #17
Bastet
Bastet's Avatar
Belgium
18
No probs. The price at BMW is ridiculous though ! :sad0147: We'll keep you posted on what else is on offer in Luxembourg. And please post info if you find something else
      12-12-2007, 06:30 AM   #18
Bastet
Bastet's Avatar
Belgium
18
Thoooooorgal - here's more info about the tyres
Les pneus sont des M+S Michelin Alpin PA3 235/40R18 95V
Les jantes sont les Doppelspeiche 270M
      12-30-2007, 08:19 AM   #19
bobr2001
Germany
Drives: F11
Here is a pic of the winter wheel BMW recommends for the M3.
      12-30-2007, 08:50 AM   #20
southlight
southlight's Avatar
1494
Drives: X3M
First pics of the M3 winter wheels mounted on a "regular" 3 series...
Best regards, south
      12-30-2007, 09:49 AM   #21
Martl
Martl's Avatar
Germany
Drives: BMW M3 E30 and M3 E92
Best regards, south
Good look ;-) you took!!!
regards
Martin
      12-30-2007, 09:56 AM   #22
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
Best regards, south
I assume those wheels already existed? What about them makes BMW recommend them for winter duty?
m3post
