Charge Pipe Removal N54
05-24-2014, 05:22 PM | #1 |
39
Rep 315
Does anyone know what would prevent the charge pipe from easily disconnecting from the throttle body? I've undone all clamps, bolts, etc and put a ton of force trying to disconnect the charge pipe from the throttle body.
It seems like something it caught under the charge pipe where it attaches to the throttle body. I put my hand under there and there aren't any clamps or bolts than need to be undone. Any ideas? All the videos I've seen say this is self-explanatory and you simply need to undo all the clamps/bolts.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings Last edited by Zach1328; 05-24-2014 at 05:32 PM.. |
05-24-2014, 05:40 PM | #2 |
Fuck it dude, let's go bowling.
888
Rep 2,480
That's pretty much it - just the one clip. Do you have all other connections uncoupled (IC pipe and both diverter valves)? There is an o-ring on the CP-TB connection that makes it a little tight. If all other connections are uncoupled, you should have enough play to wiggle it loose.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
05-24-2014, 05:54 PM | #3 | |
39
Rep 315
Still wouldn't budge.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
05-24-2014, 05:58 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Stock CP? Doesn't sound like you removed the t40 bolt at the bottom of the CP . For me it was one clamp by the IC inlet, the t40 bolt, and the C clip by the throttle body.
Hmm 07 e90. Think you CP is a little different than the '10 e92. Its shorter though AFAIK so should be easier. I'll see if I can Google something up. View post on imgur.com View post on imgur.com
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
05-24-2014, 06:20 PM | #5 |
888
Rep 2,480
Good point!
05-24-2014, 06:38 PM | #6 |
39
Rep 315
Where is the t40 bolt? I've looked under the CP-TB connection point ~10x and haven't seen any bolts. Also, I put my hand under there multiple times and can't find a bolt?
Isn't a t40 massive? I would imagine I would have seen or felt it by now?? This is on my '08 535i by the way. I was waiting to do the 335i after as I figured my 5 would have a little more room to work with in the engine bay.
07 335i
05-24-2014, 06:44 PM | #7 | |
35
Rep 1,652
Did you take off the airbox? On the 3 its under the front outlet from the airbox. Right next to the alternator. So its kinda hidden and needs to be removed or at least lifted up to see. Unfortunately I'm not sure if this configuration is true in the 5 series but I imagine its very similar. I can go outside and snap a pic if need. On my post above there is a pic but that pic is with the airbox completely removed just FYI.
05-24-2014, 06:51 PM | #8 |
888
Rep 2,480
Oh hell, I don't know a thing about the '08 535. N54, yes? Should be similar.
The T40 bolt is featured prominently in e92-enthusiast's photo.
05-24-2014, 06:54 PM | #9 | |
39
Rep 315
Looking at this guide: http://www.n54tech.com/forums/showthread.php?t=12258 I have done everything up to the throttle body step where I popped the clip up from the TB-CP connection, followed the CP to the to where its mounted to a bracket (I believe thats the t40 you're referring to), and loosened the clamp all the way at the front of the engine bay where the CP connects to the IC. It seems to be stuck underneath the CP where it attaches to the TB. The top of the TB-CP connection is wiggling a little bit - but something underneath the CP-TB connection itself is preventing the CP from breaking loose.
07 335i
05-24-2014, 06:59 PM | #10 | |
35
Rep 1,652
Yeah that's definitely it. I'm thinking maybe you just need to put a little elbow grease into it. Although it sounds like you did already. I'm confused. Let us know when you get it. On a side note my broken CP came off easily cause it was broken where yours is stuck. I struggled to get he new one on cause it was such a snug fit. Think you might be having my same issue but vice versa if that makes sense. The main problem is there's not alot of give North and South cause of how its connected. Almost like you don't have enough room to pull it out.
05-24-2014, 07:08 PM | #11 |
Rep 263
Drives: E46, E91, F21
Take the big lock clip entirely out of the pipe. Try not to drop it, then jiggle jiggle, up and down while pulling backwards towards you. Sometimes that clip is still slightly locked on the TB. Other than that it should come off pretty easily.
05-24-2014, 07:10 PM | #12 |
35
Rep 1,652
This too. The guide says to pry it up a bit but I recommend taking all the way off. But like x_drive says be careful not to drop it onto your undertray.
05-24-2014, 07:12 PM | #13 | |
39
Rep 315
I don't know anyone personally who is any more capable of doing this than I am so it looks like I'm going to have to pay an indy shop to do the work for me and wait to get a Jb4/DCI for my 335i. Thanks for trying though guys! I was really hoping I just missed some kind of bolt/clamp underneath the CP-TB connection point.
07 335i
05-24-2014, 07:12 PM | #14 |
Rep 263
05-24-2014, 07:16 PM | #15 | |
39
Rep 315
I'll give it another shot with the clip completely off and see if I have any luck. I already lost a Torx down in the engine bay somewhere, so hopefully I'll have better luck with hanging on to the clip!
07 335i
05-24-2014, 07:16 PM | #16 |
888
Rep 2,480
"Calls for" is a nice way of putting it I usually "call for" JFC.
05-24-2014, 07:17 PM | #17 |
888
Rep 2,480
Whatever you do don't let on that you are the least bit worried about dropping it - that guarantees it will be dropped every time!
05-24-2014, 07:23 PM | #18 |
35
Rep 1,652
Funny thing is I dropped mine and luckily it bounced near the edge of the tray by the wheel well and was able to reach it barely w/o unscrewing the tray. Yeah man I prayed I wouldn't have to remove the belly. Its like 100 screws lol.
05-24-2014, 07:29 PM | #19 |
Rep 263
The worst is when you don't hear it hit the bottom. ting ting....aw crap.
05-24-2014, 07:34 PM | #20 | |
39
Rep 315
Still took a lot of pulling but it came off! Now onto the TB and then finally the intake manifold! Thanks again guys!
07 335i
05-24-2014, 07:36 PM | #21 |
Rep 263
05-24-2014, 07:44 PM | #22 |
35
Rep 1,652
Yay!
