BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Half country Drive with a loaded coupe question
      05-22-2014, 05:28 PM   #1
CharlieBear
Drives: 08 e92 white red sold bc uknow
I'm moving from Dallas to Los Angeles.
It should take me 20 hours straight, but will stop and rest 1,2, or3 times before reaching my destination.
Questions:
How long should I drive a car for? Will I need the car to "rest" after a certain number of constant driving? 10 hours straight with sleep night? or 7 hours x 3 breaks?
Also this will be a packed car, cloths, golf clubs, etc. I'm hoping I can fit it all without a roofrack/roofbox. What is the recommended max lbs. to stuff in a car like this for a road trip?
Also any suggested route? I'm just following googlemaps from Dallas to Phoneix to LA.
TIA
      05-22-2014, 05:31 PM   #2
e92_enthusiast_1
e92_enthusiast_1's Avatar
35
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
That's a helluva drive. Just make sure you're rested. That's more important than the car 10 hours straight is a long time. I can do like 5 (Go between Phx and El Paso a lot and Phx to LA too) no problem maybe 6 or 7 but after that i get restless.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      05-22-2014, 05:32 PM   #3
335NJ
533
Drives: 2008 335i 6MT E90
It's likely highway the entire way, so pack the car full, you won't scrape on anything unless it's fully packed and you hit speed bumps in a rest stop parking lot too quick or something. You shouldn't weigh it down enough to cause any issue with mostly clothes, and small things.
IMO you shouldn't have to let the car cool down, or rest for a period of time, any longer than it takes to get gas, rest stop, etc.
Make sure you have nice fresh oil, and regular "road trip" things done prior to taking off that's all
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
      05-22-2014, 05:46 PM   #4
kfriceman
52
Drives: 2009 335 xDrive E90
Good grief, your car does not need to rest......seriously?
The cargo capacity is listed in the manual.
-Kevin
      05-22-2014, 06:07 PM   #5
HazChem
HazChem's Avatar
262
Drives: 2019 BSM M2C
Engines were designed to operate at steady state so you should be fine. Make sure you get enough rest!
      05-22-2014, 06:31 PM   #6
El Cheapo Loco
douchebaggo
186
Drives: stick
Bring spare water pump and t-stat.
      05-22-2014, 06:36 PM   #7
ahmza15
ahmza15's Avatar
Drives: 2011 335i vert
Rest most importantly, bring some snacks and something to keep you hydrated along the way. Just be careful though I've done 8 hrs straight driving a few times but I wouldn't go over that and even that was pushing it for me but my biggest issue was havin to take a piss after only a couple of hours. Damn coffee lol sip moderately, trust me..
      05-22-2014, 06:38 PM   #8
drilla2212
Drives: e92 328i, z4, e46 m3
Bring a blanket for your car in case it gets cold at night.
      05-22-2014, 06:47 PM   #9
AviatorBimmer
26
Drives: 2007 BMW 335i E92
Yup. There is a REST button on your climate control knobs. Just hit that after you park.
      05-22-2014, 07:51 PM   #10
NGEE
Fuck it dude, let's go bowling.
NGEE's Avatar
888
Drives: 1M
Here's my e90 pre-trip packing procedure:
Water pump? check.
Thermostat? check.
Coils? check.
Injectors? check.
7 quarts of oil? check.
Every conceivable gasket? check.
MAF sensor? check.
O2 sensor? check.
HPFP? check.
Spare charge pipe? check.
Spare valve cover? check.
Wheel speed sensors? check.
Steering angle sensor? check.
Wheel bearings? check.
12 lbs. walnut shells? check.
Mechatronic sleeve? check.
Window regulator? check.
Full set of metric tools? check.
Tow hook? check.
U.S. map of BMW dealerships? check.
Then once I'm at the office, I do it all over again for the evening commute back home.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
      05-22-2014, 07:57 PM   #11
Gizm0
Gizm0's Avatar
426
Drives: 08 e92 335i 6mt
I don't think you need to worry about the car... You'll run out of juice way before your car does...
Just in case, check your muffler bearings and blinker fluid before you hit the road...
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch
      05-22-2014, 07:59 PM   #12
ErzenE92
ErzenE92's Avatar
12
Drives: 2009 E92 335i
you shouldn't have any issues with that trip. I have done the drive from California to Colorado 3 times. the only thing you will need is to rest.
      05-22-2014, 08:04 PM   #13
Gizm0
Gizm0's Avatar
426
And fill up the gas tank every 400 miles...
      05-22-2014, 08:13 PM   #14
AgentAvalos
VIP
AgentAvalos's Avatar
52
Drives: AW E92 335is
2011 BMW 335is  [0.00]
Water pump? check.
Thermostat? check.
Coils? check.
Injectors? check.
MAF sensor? check.
O2 sensor? check.
HPFP? check.
Tow hook? check.
      05-22-2014, 08:23 PM   #15
Zach1328
39
Drives: 2008 535i / 2007 335i
The car will be fine. Actually, I would argue it will be better than fine and will probably help its longevity to be driven for such a long period.
As a kid the most reliable car we had in the family was my Mom's 2001 Suburban which we drove all over the country. Its been on at least 15 different 1,500 mile long (each way) road trips and that thing is the most reliable car ever!
My parents actually still own that Suburban because its at 180,000 miles and literally hasn't had a single issue. Original suspension, original engine, original water pump - I'll stop there because it is 100% original and still runs like a beauty.
Only things done to it have been regular maintenance including tires, oil changes, brakes, spark plugs, etc.
I agree with most comments, you'll get tired driving wayyyy before the car gets tired!
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings
      05-23-2014, 05:26 PM   #16
LeeCatD8209
Drives: 2009 335i Xdrive
I just drove my 335 from Northern PA to Georgia and back only stopping for gas. It loved every second of it.
      05-23-2014, 05:31 PM   #17
brewnami
100
Drives: 2009 BMW 335i M Sport Coupe
I drove my wife's BMW X5 31 hours straight from Round Rock, TX to Hollis, NH in one shot. Only shut the car off to gas up. No problems with the car. I started to hallucinate, but that's because I worked 8 hours and then drove 31 without sleep haha.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
      05-23-2014, 05:33 PM   #18
Mardio
197
Drives: 2017 X5
Safe to stop every 20 min. and check the flux valve. I would not take any chances.
      05-23-2014, 05:37 PM   #19
NGEE
NGEE's Avatar
888
Drives: 1M
JEEZUS!
      05-23-2014, 06:01 PM   #20
brewnami
100
Live and learn I guess haha.
JEEZUS!
      05-23-2014, 06:05 PM   #21
misterbrister
Drives: Notabimmeryet
I've driven round-trip from TN to CA a total of three times; twice with my wife to take turns, once on my own. I wouldn't worry about the car too much, although if it's loaded down, at high speed, with high temps you might worry about tire temps. Do a proper check-up on your car before you hit the road, things like fluids, belts, etc. Definitely don't want to be stranded on I10 or I20.
      05-23-2014, 11:36 PM   #22
DF
239
Drives: F23
Welcome to LA! What part are you going to live in?
