HID Cutoff and Vertical Alignment
05-21-2014, 04:32 PM | #1 |
Rep 32
Does anyone have pictures of their HID headlight cutoff against a wall?
After some research, I've discovered that there are two ways of vertical aiming- Using the upper part of the cutoff as reference: 1. Both beams is perfectly aligned 2. Drivers side beam is aimed lower with the upper part of cutoff aligned with lower passenger side cutoff Which way is correct? Also, if my projectors measure 25" from the ground, at 25' from a wall, should the light from the upper or lower part of the cutoff be ~2" lower than the projector height? |
05-21-2014, 04:39 PM | #2 |
Just enjoying my time
128
Rep 855
Normally, the drivers side beam is lower than the passenger to keep from blinding on coming drivers. As long as you're not blinding traffic, having them even won't hurt anyone/anything.
Current - 2022 Rivian R1T, 2021 Ducati Streetfighter V4S, 1969 Chevy C10
Sold - 2018 Tesla Model 3 Performance Sold - 2007 E92 335i If speed is death, then buy a Honda and live forever |
01-18-2015, 12:36 PM | #3 |
16
Rep 109
I need help with this as well, im not sure how BMW aligns headlights but they charge alot for it. If i can't find a specific instruction, im just gonna park next to a friends 335 and match the height up to his.
01-29-2015, 11:23 PM | #4 | ||
Where'd my VTEC go?
481
Rep 6,067
It should look like this: Code:
____/-----____/----- Code:
____/----- ____/----- What I do is get some painters tape, a measuring tape, and find a really long flat wall, then park parallel to it with the drivers side really close to the wall. Tape a shirt or towel or something over the passenger headlight (or have someone stand right in front of it) to block out the light. Now measure the height of the light to the center of the projector. I think there's a dot on the lens to mark the center but I don't remember. Now measure 25 feet in front of the wall, and measure 2.1" less than the height of the projector you got earlier. Mark the height on the wall with some tape. Now adjust the drivers headlight so the cutoff is right below the tape. It's ok if there is a bit of color above that line but the main white part of the beam needs to be below it. Then uncover the passenger side and move the car perpendicular to the wall as far away as possible (at least 20-25 feet out). Finally, adjust the passenger side so the height of the beam is even with the drivers side.
