Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Dimming Homelink Rear View Mirror
      05-21-2014, 04:17 PM   #1
CT_335D
37
Drives: 2009 BMW 335d
My 2009 335d non-sport model does not come with a auto dimming rear view mirror, so I was thinking about replacing it.
Does anyone know if the 2009 models are pre-wired for the auto dimming mirrors with the Homelink buttons?
Or will I need a harness of some sort and get the power from the front overhead lights?
Also, does anyone have a part number for a auto dimming rear view mirror with Homelink that will fit my 2009 335d?
Thanks
      05-21-2014, 04:58 PM   #2
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
I would take this question over to the "main line" E90 forum as it's generic and has nothing to do with diesel. There are way more people over there and so increases your chances of an informed answer.
      05-21-2014, 06:10 PM   #3
CT_335D
37
Thanks. That's exactly what I did.
I also found a post on how to do this and what I need to buy.
So I am all set.
      05-22-2014, 06:59 AM   #4
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
Also check ebay you might find one and good luck
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      05-22-2014, 11:49 AM   #5
CT_335D
37
Thanks. Found a used one in good condition for $150 and $31 for the wiring harness. Also found an install guide, which looks pretty simple to do it yourself.
      05-22-2014, 12:34 PM   #6
Puerto Rican 335d
Puerto Rico
229
de nada my amigo
      05-22-2014, 02:02 PM   #7
BB_cuda
BB_cuda's Avatar
765
Is the car pre-wired? When i was shopping for a car, i came across one with no alarm. I found out after a certain production date in 2009, the wiring wasn't included. With the alarm there is a motion detector mounted within the interior overhead light (not the front one, the middle of car one). The headliner was going to need to be removed to run the wiring. Labor was going to be expensive so I bailed and found another car with alarm already.
I ask this as you are talking about your rear view mirror and i was thinking about wiring under the headliner. Good luck
      05-28-2014, 05:03 PM   #8
CT_335D
37
Needed to by a wiring harness for the extra rear view mirror features. Harness was around $35 from South Atlanta BMW. There is also a detailed install procedure online that shows you how to install the harness. Received the mirror, harness should arrive tomorrow morning.
Tags
auto dimming, homelink, rear view mirror
