Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Mods in order of precedence?
      05-21-2014, 03:57 PM   #1
nb335i
nb335i's Avatar
15
Drives: 07' 335i
My 07 335i is pretty stock, what is the e90 communities opinion on my first upgrades? I'm looking to get modest performance. I'm no track star but everyone just enjoys a little more "oomph." Would you recommend exhaust, tune, fuel or any others? What did you guys start out with and how did it work for you?
-Thanks
      05-21-2014, 04:21 PM   #2
brewnami
100
Drives: 2009 BMW 335i M Sport Coupe
JB4 G5 and DCI (order together) makes it a completely different car and in my opinion, the best bang for the buck as I think its like $600 with the USB cable.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
      05-21-2014, 04:32 PM   #3
nb335i
nb335i's Avatar
15
Drives: 07' 335i
thanks for the input, are there any concerns with having this setup for daily driving?
      05-21-2014, 04:38 PM   #4
pr0gress
Drives: 2008 e92 AW 335xi w/ jb4
Tune (I went jb4 and Wedge back end flash)
DCI (cheap and quick install)
Downpipes (VRSF makes a great product for the $$)
From there it's Fmic, chargepipe, suspension, exhaust, e85 meth and whatever you desire from there. Lots of room for Ideas and getting the setup you want. The tune is the best bang for your buck and might be all you have to do for your needs.
      05-21-2014, 04:44 PM   #5
iturbo_bmw
iturbo_bmw's Avatar
84
Drives: 335i, 530i
a tune will definitely be the best first option. u get more power, can read & delete codes, with jb4 hijack gauges, etc. u don't need the dci unless u want the air suction noise but its cheap anyways. and ur not tracking so no point in doing suspension stuff or lsd.
      05-21-2014, 04:46 PM   #6
pioneercrazed
Drives: 07 e92 335i
JB4 ... No question
      05-21-2014, 04:48 PM   #7
nb335i
nb335i's Avatar
15
Drives: 07' 335i
rather than a dci would it be better to just get a drop in? the jb4 has the deal to buy the dci for pretty cheap, so i figured it may be worth it? also how hard is the jb4 to tune? I know install is a pita but how about normal operation? is it "set it and forget it"
      05-21-2014, 04:51 PM   #8
AggieATO
Drives: 2007 BSM 335i Sedan
Had the exact same setup to start with as you.
My order was:
Cobb w/ dual cone intake
Blacked out grill (mine is Black Sapphire)
Blacklines w/ black emblem roundels
Vrsf downpipes and vrsf exhaust
I think that's all I've done for now, but the Cobb and DCI were BY FAR best bang for buck. Do that first.
      05-21-2014, 04:52 PM   #9
AggieATO
And depending on mileage, I'd change the spark plugs if it's over 50k before adding the tune.
      05-21-2014, 04:57 PM   #10
AzureHaze
AzureHaze's Avatar
69
Drives: 2011 335d Sport
Start with a JB4 or Cobb and then work your way down the list of the numerous mods happily waiting to suck your wallet dry. Installing and using both of them is a piece of cake and everyone I know who owns one love it. If you want to know more, there's a lot of threads on this forum to better school you in the arts. Don't be afraid to use the search button.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
      05-21-2014, 05:02 PM   #11
brewnami
100
I'd just go ahead and change the spark plugs anyways... I had my JB4 installed for a couple weeks and I needed spark plugs at less than 29,000 miles.
The DCI has proven to add power, it sucks in way more air than the air box which weighs out the cons of sucking in hotter air. Though people can debate that all day long and get no where... Its a cheap add on, does its job, and sounds great.
The JB4 took me less than 35 mins to install... Though I've done it a couple times. Its not a pain in the ass at all. Plus, as mentioned above, there are a lot of awesome features such as code reading and clearing, boost gauge hijacks, open exhaust flaps, integrated shift lights, cooling feature. Probably the most popular tune in terms of how many are in use and its also the cheapest by far. That was my first mod twice on two different 335i's.
      05-21-2014, 05:04 PM   #12
e92_enthusiast_1
e92_enthusiast_1's Avatar
35
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
I like the idea of being able to flash/unflash a tune easily and not having to deal with the piggy back install on the ECU so think i'm ordering a Cobb. Think you cant go wrong either way.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      05-21-2014, 05:15 PM   #13
nb335i
nb335i's Avatar
15
Drives: 07' 335i
Great info, thanks.
So after the install of the jb4, what do i do from there? I figure it will have a program that i pop into the ol' dell and i can adjust settings or configure preset maps from there, or can i do all of this from the jb4 itself directly?
      05-21-2014, 05:17 PM   #14
Myrder
Myrder's Avatar
162
Drives: 2010 E92 335i MSport 6MT LMB
How many miles? If high, make sure spark plugs, coils, and injectors are all working great/new.
Tune
DPs
IC
Intake
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
      05-21-2014, 05:17 PM   #15
pr0gress
Jb4 can install and uninstall in 15 minutes. At least I've never struggled with it. Do some research and decide yourself but jb4 is by far the best for the price and function. If you prefer the Cobb style flash just get a BT cable and do some of the BB flashes or contact Wedge. Cobb IMO is too overpriced for the performance gains. To each their own though. The mod bug is hard to shake once you start
      05-21-2014, 05:24 PM   #16
nb335i
nb335i's Avatar
15
Drives: 07' 335i
exactly... ill do some more research on the jb4, but it looks like ill be going with the jb4 and dci kit. THANKS TO ALL!!!!
      05-21-2014, 05:30 PM   #17
brewnami
100
Nope. Just plug it in and start it up. Use your steering wheel controls (there is a guide for this) and set to Map 1, 2, or 5 (auto tune) and you're good to go. Just drive it around for a bit to adapt. You will see power gains immediately, but it will take a couple drive cycles to fully adapt. No laptop programing needed. It's 100% plug and play.
Originally Posted by nb335i View Post
Great info, thanks.
      05-21-2014, 05:33 PM   #18
nb335i
nb335i's Avatar
15
Drives: 07' 335i
AWESOME! Thats what I needed to hear, thanks a ton brewnami!
      05-21-2014, 05:39 PM   #19
e92_enthusiast_1
35
Actually, i wanted JB4 initially but then i read some things about track day limp modes and that's what scared me honestly. Idk if that's still a common thing or what or if it was just aggressive tuning at the beginning of the JB4 days when it was still in a development phase.
      05-21-2014, 05:47 PM   #20
brewnami
100
I've had two JB4 tuned 335i's and never had a problem aside from burning out my original spark plugs. I don't think this holds true in the day of the G5 board.
      05-21-2014, 05:49 PM   #21
nb335i
nb335i's Avatar
15
Drives: 07' 335i
is the g5 just the most up to date jb4 software?
      05-21-2014, 06:02 PM   #22
brewnami
100
It's the newest board. I think it came out last year. I've never had any problems and I think you will find that to be the general consensus too.
