Revs high then stumbles upon start; hpfp?
05-19-2014, 10:47 PM | #1 |
23
Rep 105
Every second or third cold start, my car will rev up to 2k or so then drop into a protracted stumble lasting five to ten seconds before settling into a normal idle. I am not experiencing extended cranks, just the weird rev-then-stumble. Is this a symptom of a failing high pressure fuel pump?
If not, does anybody have any ideas what it could be? I have a jb4 running map 1 (stock otherwise) but this is a recent development and I've been running the jb4 since December. Thanx!
05-20-2014, 08:12 PM | #3 |
23
Rep 105
Thank you for the response. I'm surprised at the lack of opinions here. When I installed my JB4 it threw a code, so I changed the plugs and haven't had any codes since. This makes me think the plugs, coils and injectors are all good. To my knowledge my car has never had the carbon removed, but there are no other symptoms of carbon buildup. I'm puzzled at this odd idle situation...
05-20-2014, 08:55 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
After a tune I've heard that besides plugs, coils and injectors will degrade a lot sooner than normal so don't discount it just cause you did the plugs. Have you pulled codes?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
