Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 11.8 sec 120 mph Quarter Mile
      05-17-2014, 12:56 PM   #1
TDIwyse
614
Drives: 2011 335d
After last weeks bad weather and a 12.1 sec 1/4 mile I was looking for another opportunity to break into the 11's. Found out there's another NHRA sanctioned track within driving distance and they were doing a Test-n-Tune today. And the weather today is unusually good. Nice high pressure system on top of us, and we actually had frost on the ground this morning...
~52F, ~30.13 pressure, dew point ~32 F at 1000 ft -> Density Altitude of ~ 603 ft for these runs.
Only did two runs and left before breaking anything. Both runs were 11.8's.
Due to traction issues last time I did a couple things that are counter intuitive from what I've done in the past... Had over half a tank of fuel in there for more rear weight and left the traction control nannies on. There's just too much slippage that occurs without the traction control using the Hoosier DOT drag radials. Think I'd need even better tires to apply full fuel without the traction control nannies and LSD helping maintain the grip.
Oh, I also changed the shifting procedure a bit based on what I was seeing after studing some of the data I've collected. Think others will find getting out of 2nd gear earlier is better. The transmission is in fluid coupling mode in 2nd and 3rd is full lockup. You'll transfer power better in full lockup.
Got a video to post at some point as well. But I've got a bunch of home chores to do now.
      05-17-2014, 01:02 PM   #2
iaknown
425
Drives: 335D
Very interesting.... Nice work!
      05-17-2014, 01:02 PM   #3
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Drives: 2021 X3 M40i
I also changed the shifting procedure a bit... Think others will find getting out of 2nd gear earlier is better. The transmission is in fluid coupling mode in 2nd and 3rd is full lockup. You'll transfer power better in full lockup.
Thanks TDIwyse. When you have time, could you translate the quoted paragraph into "Shifting for Dummies" level?
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      05-17-2014, 04:23 PM   #4
TDIwyse
614
Drives: 2011 335d
Video is up.
      05-17-2014, 04:42 PM   #5
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
Excellent. Sure to see some respect from the 335i gas owners now! And the beauty is besides the meth... This does not require exotic priced race fuel either. Would be awesome to see how vbox numbers compare with that track also. What did you run against that was doing 129mph in the qtr?
      05-17-2014, 04:48 PM   #6
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
87
Drives: 2011 335d M sport
Every BMW BENZ AUDI VW is a monster in 3rd and 4th gear the others are almost useless, Im running this friday and the local track fully stock on street tires I will post vid and times...
BMW Advanced Diesel, 2011 335d M sport...
      05-17-2014, 05:24 PM   #7
TDIwyse
614
Drives: 2011 335d
The first time slip was vs a Crotch Rocket motorcycle. There were a bunch of them there today. As usual I was the only diesel.
Filled up after I was done and reset the mpg predictor. Car was predicting 49 mpg when I pulled into my garage (It's usually a little optimisitic, but still ...). This has been my favorite car I've ever owned.
Thank you Stan for helping make this possible.
      05-17-2014, 06:00 PM   #8
ASAP
ASAP's Avatar
10163
Drives: '23 X3 M40i
The 119 trap is EXTREMELY impressive for D. What mods are you running?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      05-17-2014, 06:06 PM   #9
335dM
128
Drives: 335d m package
+1
      05-17-2014, 06:59 PM   #10
TDIwyse
614
Drives: 2011 335d
Thanks. But I'm curious ... isn't 119.95 mph closer to 120 than 119?
      05-17-2014, 07:03 PM   #11
335dFan
Jumping Jack Flash
335dFan's Avatar
321
      05-17-2014, 07:51 PM   #12
32valves
32valves's Avatar
109
Drives: 2011 335d sport
I knew it could be done
Congrats....
      05-17-2014, 08:13 PM   #13
ASAP
ASAP's Avatar
10163
Drives: '23 X3 M40i
You didn't answer my question... I am gonna guess you figured out a way to integrate meth/increase fuel pressure even further.
      05-17-2014, 08:22 PM   #14
FrankyGTR
FrankyGTR's Avatar
18
Drives: N54 335i 6MT-R32GTR
good job,congrats
2008 335i coupe 6MT BOOST FIEND
      05-17-2014, 10:02 PM   #15
135i_vs_
135i_vs_'s Avatar
72
Drives: M5, 135i, 335d, F10 550xi
Tune + exhaust bolt on's, less than $2,000 and the 335d breaks into 11's.
This is probably my most favorite BMW to date.
Thanks for doing all the work to unlock the car's potential.
      05-18-2014, 12:38 AM   #16
DieselRacer
87
What are the bolt ons???, Nitrous is considered a bolt on...
      05-18-2014, 06:22 AM   #17
TDIwyse
614
Drives: 2011 335d
Well, many of us have been using water/meth for quite some time now, and rail pressure mods have also been used for sometime, and remaps have been used for sometime. I am doing something a little creative with one or more of these things. But it took Ecotune and the DPF delete to really free up the EGT margin to safely do some of this stuff.
      05-18-2014, 06:32 AM   #18
TDIwyse
614
Drives: 2011 335d
The Quaife LSD was the most expensive item, but as you can see from the 60' times I haven't quite figured out how to fully exploit it. So I don't think that was significant in this 11 second equation.
There's a cobbled together water/methanol setup. Pieced together from ebay. There's the downpipe. There's the DDE that was remapped. Homemade AEM intake (no OEM airbox anymore). Some homemade electronics. And that's it.
Stock intercooler, turbo's, injectors ... The car has all the inherent DNA from the factory to do some amazing things.
      05-18-2014, 02:08 PM   #19
AzureHaze
AzureHaze's Avatar
69
Drives: 2011 335d Sport
That engine in the video sounds amazing!
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
      05-18-2014, 04:27 PM   #20
TDIwyse
614
Drives: 2011 335d
If you're talking about the engine sound at the initial launch, then that was the really loud car in the other lane. He was also doing a heavy burnout before coming to the line (you can see some of the smoke slowly drift into frame at the beginning). It was some kind of really pretty blue Acura (I think) with a lot of nice looking aero ground effect cladding. Maybe an RSX? It looked and sounded heavily modified.
After the launch the diesel engine sound takes over. I really like how it sounds now with the mufflers deleted and straight pipes put in their place.
Just remembered a "bolt on" item I forgot. I did make a homemade functional rear diffuser to reduce the under car turbulence created by removing those massive mufflers (I do still have the mid pipe SCR catalyst in place).
http://www.e90post.com/forums/showpo...0&postcount=38
      05-18-2014, 09:27 PM   #21
natefank
Drives: 335d
What kind of homemade electronics? U have any tips on launching? I'm going to the strip this next weekend, I wanna surprise some people
      05-19-2014, 07:18 AM   #22
TDIwyse
614
Drives: 2011 335d
What kind of tires are you using? I'd suggest getting something to measure (Gtech, Vbox, even the little android Toruqe App is useful) what you're doing so you can see real data and not go on emotions/feel. Then experiment.
About the only suggestion I haven't seen discussed before is the shifting early out of 2nd gear to get into 3rd where the torque converter locks up. I tried to time it this weekend so the 3rd gear shift came online at ~3000 rpm's (a bit before peak power, but the Gtech data I have shows more pwr getting to the ground in 3rd at this rpm than 2nd gear at any rpm).
