permanent "fix" to failed electric water pump? improved aftermarket alternative?
05-07-2014, 10:30 PM | #1 |
70
Rep 377
it seems strange that the e90 water pump has basically been designated as a wear item at this point, similar to the old e46 water pump....but has any company made a much sturdier alternative (like how there are metal impeller e46 water pumps)?
and if not....why not? surely there is some specific component that fails on the water pump, and that component can be replaced with a more hearty version |
05-08-2014, 11:54 AM | #4 | |
70
Rep 377
however there might be packaging restraints |
05-08-2014, 01:00 PM | #5 | |
General
17326
Rep 18,748
05-08-2014, 02:20 PM | #6 |
70
Rep 377
05-08-2014, 09:21 PM | #7 |
General
17326
Rep 18,748
When I dissected mine it was clear by the smell and melted conformal coating that the electronics over heated. There is a trouble code that indicates when the electronics get over 170 deg. C. they shut down. The impeller is plastic, but the one on mine looked as good as the new one.
05-20-2014, 10:38 PM | #8 |
70
Rep 377
i'd be curious to see if using something like evan's coolant (100% antifreeze) would help, since it tends to run much cooler than standard 50/50 coolant and also can run at atmospheric pressure instead of needing a massive PSI pressure cap
maybe that will keep the electronics in the water pump cooler? also, this trouble code the water pump throws, is it a ghost code (can only be read by a bmw-specific diagnostic tool)? Last edited by joekitch; 05-21-2014 at 06:57 PM.. |
05-21-2014, 11:55 AM | #9 | |
General
17326
Rep 18,748
05-21-2014, 06:59 PM | #10 |
70
Rep 377
05-21-2014, 08:31 PM | #11 | |
General
17326
Rep 18,748
You should search in the maintenance section on the water pump there is a lot of accurate information rather than what you have "heard". Look up Eninty's post on his failed water pump. That post explains the entire failure issue. |
