Why no recall?
04-14-2014, 11:51 AM | #1 |
1861
Rep 2,554
Why no recall?
I'm just curious and please don't flame me for I do not know the legality behind this.
Why hasn't BMW been obligated to do a recall on cars affected with the water pump issue. From what I understand every E90 has this issue and I was curious to know why it wasn't mandated by law that they fix it? I've seen recalls on issues that affect much less cars than the water pump so if anyone could clear that up that would be great. Thanks! |
04-14-2014, 12:18 PM | #2 |
131
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
I have had two e92 and neither had water pump issues.
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks '07 BMW 335i Coupe & BMW Z4 3.0i - Gone |
04-14-2014, 01:03 PM | #6 |
19
Rep 595
I think many mistake this as a prominent issue with the E9x 3 series, but this is not true. Yes, some of the early model cars had a "bad" water pump design, but it was promptly updated and there are still 06-07 cars driving around with their original pumps. Already stated, but water pumps are a wear item and do eventually require replacement. I also don't know where you are getting your numbers from, but I don't think that the water pumps which have failed so far have affected all that many cars. I have nothing to back this up, but I have also noticed that this issue is much more often posted about if A) the car in question is 335i [400 watt pump/more heat] and B) the car has been tuned [some tunes allow water pump maps to be altered] Finally, they aren't going to initiate a recall on an issue which is 6 or more years old with some of the applicable cars being even older. With these observations in mind, I simply don't see BMW justifying a recall anytime soon.
04-14-2014, 01:57 PM | #8 |
815
Rep 2,869
Same reason they don't issue recalls on your tires.
You can argue that the water pump is a maintenance item and will need replaced at some point, regardless of how well you take care of your car. It is a "wear" item, meaning, over time, it wears out. Now, do BMW water pumps "wear out" a little faster than other mechanically driven pumps? Sure. Did BMW put the water pump in a pain-in-the-ass area of the engine where you need to rip the thing apart to fix? Sure. Do either of those items warrant a recall? Unfortunately no. Recalls are usually "safety" items. A water pump is hardly a safety item, considering you "could" still drive the car to a safe area even if the pump went out. ...with all that said, do I wish my Water pump was covered when it goes out, or wish our e90's didn't have "problems" with our electronic pumps... hell yes.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
04-14-2014, 03:01 PM | #9 | |
1861
Rep 2,554
04-14-2014, 03:03 PM | #10 |
7478
Rep 10,120
A water pump will fail around 80-120k miles on most cars. BMW is not like most cars and its pump can fail a heck of a lot sooner. My failed at a little over 30k miles, someone else on here had theirs fail at under 20k. And no my car is not tuned and mostly highway driven.
04-14-2014, 03:26 PM | #11 | |
928
Rep 5,538
04-14-2014, 03:27 PM | #12 | |
1007
Rep 2,109
I wonder what is the ratio of 335 with early water pump failure vs N/A models. My thinking is the engine compartment will be hotter with turbo, plastic and heat don't go that well. I also wonder the ratio of plastic valve cover cracks on turbo vs N/A BMW's. |
04-14-2014, 07:14 PM | #13 |
Thats all you need to know.
43
Rep 1,188
It's the variable speed electrics that are failing from what I have seem. I don't have any concert proof that is the only reason, but I don't hear about leakers. This design is a big step from the more passive mechanical pumps of the past and frankly 60-100K was about all you got from the E36 and E46 pumps. What owners don't like about the electric pumps is they cost 4-8 times the mechanical version.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
04-14-2014, 07:17 PM | #14 |
15
Rep 251
bmw has cut a lot of corners using plastic parts but it still doesn't warrant a recall...
ie ever had your window fall into your door? I had a few in the x5... ever have a key lock break? bmw has had plenty. |
04-14-2014, 07:44 PM | #15 |
just another bmw douche bag
195
Rep 3,640
Also, most cars have a passive, mechanical water pump, driven by a belt. It was common practice to replace the water pump with the timing belt on my old honda and integra, which was about every 60-80k miles. But the pumps were a lot cheaper than the electric unit on the E9x.
FWIW, the water pump on my E90 lasted 119k miles before it went out. |
04-14-2014, 07:51 PM | #16 |
2054
Rep 6,119
Not so on turbo cars. You change the water pump when you do the timing belt (60k miles). 335 has timing chain, so people haven't been doing it. It is a wearable item. Nothing more, nothing less.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
04-14-2014, 08:15 PM | #17 | |
928
Rep 5,538
E46 M3 pump failed at 40k or so. |
04-14-2014, 08:38 PM | #19 | ||
2054
Rep 6,119
If not, timing chain? Manufacturers also say you should go 15k between oil changes. Believe that? My water pump lasted to 110k miles. I replaced it then bc I didn't want it to fail at an I opportune time. They obviously can last different mileages.
04-14-2014, 08:45 PM | #20 |
928
Rep 5,538
Santa Fe with belt about 120k miles on pump, rest are chain with 150-160k on pump. All were sold or totaled so I never actually replaced any. None of those are turbo. M3 is obviously NA and its pump failed.
04-14-2014, 09:27 PM | #21 |
39
Rep 227
I've never heard of a "lifetime water pump." I've worked in the automotive field for 20 years. There are instances where some have gotten an extended amount of time out of a pump. They are wear items such as tires, brakes and suspension parts.
04-14-2014, 10:26 PM | #22 |
928
Rep 5,538
Engine and transmission are wear items too that will eventually fail. When they fail prematurely, its a shitty design or a defect....same with water pump.
