2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Er Downpipe Install Diy (sorta) And Pics
      04-11-2014, 01:35 AM   #1
cmkde
36
Drives: Alpine White 15' M4
So with being pointed in the right direction with the help of fellow member Justin, I made contact with Christine over at Evolution Racewerks which has a down pipe for our car available (Possibly sold out) as of right now. Now I apologize for some gaps of photos and quality, we were using Rhino Ramps and the space below the car is pretty compact to say the least.
Let us begin, shall we?
---------------- PREP -----------------
Tools/abilities required:
- Rhino Ramps(or equiv) or special jacks/adapters that fit into the side holders of the car, no real safe place to jack the car up traditionally.
- Metric driver set
- E10/E12 EXTERNAL torx bits (if you don't have these, usually your local auto store/sears etc has them)
- O2 socket removal tool.
- Screwdriver hook tool.
- Some patience.
Optional:
- Anti-Seize
- A friend
- Captain Morgan (The 3rd friend)
Difficulty of install out of 10: 3 Time required with lift: 45 minutes / Without Lift: 1 1/2 hours.
--------------- Removal ------------------------------
1. Let the car cool, burning yourself isn't fun. This seems obvious but still, the transmission and the brackets surrounding and oil pan will be piping hot long after the exhaust cools down as well, be careful. While waiting for the car to cool down, pull off the top of the engine cover and near the back left you will find a Black and Grey O2 sensor wire, remove both of these wire connectors by pressing in and having them completely unattached for the work ahead. It is much easier this way and they snap right back in when ready. Sorry for no pics on this at the moment.
2. Remove the underbelly protector from the car which is about 22 small bolts, this is relatively easy and fast. There are 4 bolts facing the front of the car that hold some sort of protector flaps that you will not have to remove for the underbelly cover to come off. Pics of this below with the cover off.
3. There is a small exhaust hanger (not pictured) behind the flex pipe on the 6th picture down, it literally says exhaust on the bracket. It has 2 torx bolts that you should remove to gain some play in the mid pipe back to the exhaust for removal. The instructions state to drop the exhaust fully. I have the M Performance exhaust already installed here which is essentially one piece all the way back, by loosening this hanger you can let the mid pipe safely rest on a cross support brace on the car to gain play to remove the stock DP. Full removal is really not required here.
4. Next there are two main bolts for the stock DP that need to be removed that flare off on a brace of the stock DP that you can see on both the old and new one that are attached to a transmission bracket take these out and save them for later. There are also 2 additional bolts attached to where these bolts go that you can remove for the installation portion.
5. The V-Band clamps have 1 bolt/nut combo that are on the lower end attached to the mid pipe and the upper attached to the turbo charger itself, these bolts are very easily removed and BMW seemed to use good quality bolts. The V-Band clamps are TIGHT, we used a screwdriver hook to separate the clamps, they take some effort and then snap free with some extra pressure. Once both are removed the Down Pipe itself will fall.
------------ Installation --------------
1. Swap the O2 sensors to the new DP, Black wire is UPPER on the DP, and Grey wire is LOWER on the DP. These need to go back in their same place if not unicorns may burn your house down, or your car will run shitty. Neither of which you want to deal with after everything is done.
1. This is pretty much everything in reverse, with a few tips that will literally save you probably 30 minutes, Place the Downpipe up and LINE IT UP, DO NOT PUT ANY BOLTS IN OR ANYTHING. Hold it in place and get a visual representation of the upper and lower portions of the DP, the upper will line up easily but if you start putting bolts in you will not close the gap to the lower portion with the V-Band at all and you get to start all over again like we had to.
2. Now that you see how it should line up, place the V-Band upper clamp in place first on the turbo charger and tighten this about 1/2 way to where the clamp is closing the gap but not removing play in the new DP.
3. Do not put the brackets back on the new DP yet, you can line them up but keep the actual bracket off the transmission until you place the lower V-Band on the DP and meet it up with the mid pipe. This is the most difficult part, if you tighten all those bolts and brackets first your V-Band will have a gap to the mid pipe. If you do the V-Bands first and give the bottom portion a good tighten first you will be in great shape. After you tighten the bottom V-Band, then do the upper portion. Take your finger nail and try and poke it in the small opening in the V-Band (or something small and thin) if it fits in, you may have an exhaust leak back it out a little and have a friend push to make sure there is a proper seal. I'm super anal about taking your time on this portion I would highly recommend it.
4. After your V-Bands are tight and clean bolt up the exhaust hanger torx bolts then the 2 bolts on the new DP to the transmission bracket and the supporting bracket.
5. Rewire your O2 sensors in the engine bay. Don't worry about swapping the O2's in the wrong place here, they can only go in certain plugs, meaning if you didn't suck at Legos as a kid you'll probably surive this step.
6. Replace all 9 thousand bolts on the underbelly cover and make sure you have nothing left over, double and triple check your work. All factory bolts and nuts are used in this installation so nothing OEM has to be replaced other than the DP itself of course.
7. Cold start that mofo and listen to how mean she is, a fire breathing dragon is an understatement.
------------------------------- Small initial review ----------------------------------
The Good -
The overall quality for the DP is outrageously good, the welds and quality of the metal and the O2 bungs are just top notch, honestly if you're planning on doing a down pipe stop looking and buy the ER DP, it has a true 4" pipe. the Super Sprint is priced much more and doesn't look nearly as high quality. If anyone needs help getting in contact with them I'll give you their direct number if you have any questions, great customer service and fast shipping and packaging. Couldn't be happier in this aspect.
The sound is absolutely fucking amazing, it sounds like a really angry exotic car with the M Performance exhaust, it has a loud pop and nice gargle, when getting on it the sound is smooth and aggressive but not overtly loud to be loud. The sound has a purpose and it isn't annoying or droning. If you're in Sport+ and moderately accelerating the car garners a lot of street presence with the sound it emits with the DP just like any other video you have to hear it in person, even though I may post a video on this later.
One of the absolute best things about this car and the DP is, light cruising has a fantastic tone to it, but if you want to make this car super quiet with a similar exhaust note that Infiniti cars seem to have, you can actually throw the car in ECO mode and you wouldn't know you're driving relatively on straight pipes.
The Bad -
CEL after 25mi (duh) cleared with JB4 or deal with it
Internal housing has a rough patch near the ER logo weld, overall cleaned up but a minor gripe.
---------- DYNO NUMBERS TO COME ------------------
Appreciate 5
david51537.50
Scadam245.50
      04-11-2014, 01:51 AM   #2
h0pe
Drives: M235i
i know you just posted this but info on easiness? and time(how long it took)?
      04-11-2014, 02:36 AM   #3
cmkde
36
I have that near the top of the post.
      04-11-2014, 03:09 AM   #4
JustinCredibleM
47
Drives: '15 GT-R, '02 996TT
Good job and great write-up! I'm glad I could help you out on this .
      04-11-2014, 03:41 AM   #5
JBizzle135i
Drives: M235i
Thanks, that's really useful
M235i Auto: Alpine White / Black Dakota Leather, Brushed Aluminium / High-gloss Black Interior, Driver Comfort / Professional Media / Sun Protection Packages, Harman Kardon Hi-Fi, Enhanced Bluetooth, Lumbar & Heated Seats, Adaptive M Sport Suspension
      04-11-2014, 08:52 AM   #6
Mike@N54Tuning.com
Joint Chiefs of Staff
4912
Drives: 2007 335i, 2015 M3
Awesome write up!!! This is great as I can refer my customers to this thread as we've been selling bunch of these!
Mike
      04-11-2014, 06:50 PM   #7
ska///235i
***** noob
ska///235i's Avatar
1369
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Nice writeup
Can admins make a DIY section???
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      12-28-2014, 12:25 AM   #8
jeffery_stearns
jeffery_stearns's Avatar
35
Drives: Mineral White BMW M235i, X5
2015 BMW m235i  [0.00]
2015 BMW X5  [0.00]
Just installed my Meisterschaft Turbo Cat-less downpipe! Used this post a lot to reference off of thanks a lot! Definitely feeling the improvement!
      12-28-2014, 07:31 AM   #9
zipphreak
No_Country
454
Drives: m235xi
Thanks for the DIY!
      12-28-2014, 11:54 AM   #10
mike@x-ph.com
mike@x-ph.com's Avatar
24178
Drives: 07-335/12-328/18-M4/21-M4CP
Thanks for the write-up
These DP are not sold out btw
https://x-ph.com/sale/
Phone number 702-494-9435
      12-28-2014, 12:10 PM   #11
Anderw
Anderw's Avatar
659
Drives: F80 m3
thanks for the write up going to refer to this when I do my dp install!
      12-29-2014, 11:54 PM   #12
CONTROL ONE
CONTROL ONE's Avatar
69
Drives: 2014 BMW M235i
This is completely reversible, correct? (lease wise).
      12-30-2014, 05:08 AM   #13
mike@x-ph.com
24178
Yes.
When it is time to return your car, you can install the stock DP back.
      01-08-2015, 01:19 AM   #14
Weezy310
Drives: 335i
After you reset the CEL with jb4, will it pop back on then you have reset it again? or will jb4 suppress and hold the CEL off for that o2 code? COBB would suppress the CEL when installing downpipes. Im hopping jb4 will do the same cuhz if not, that is very annoying.
      01-08-2015, 01:47 AM   #15
mike@x-ph.com
24178
If you are using the jb4 , you won't get a CEL light .
      01-21-2015, 04:07 PM   #16
Regardless
Regardless's Avatar
33
Drives: turbo'd inline 6
I'm jumping in here, but does the jb4 need special coding to prevent the CEL light or automatic? and does this apply to downpipes of different makes as well?
Thanks in advance!
      01-21-2015, 04:16 PM   #17
mike@x-ph.com
24178
Thanks in advance!
Does not need any special setting
It works on all catless DP
      01-21-2015, 06:33 PM   #18
M235ixDriveMP
M235ixDriveMP's Avatar
Drives: M235i xDrive w/M Performance
The top one is BMW M235i original downpipe? If so, why the new aftermarket downpipe got more curve?
      01-22-2015, 09:40 PM   #19
inktomi
64
Drives: 2015 EBII M235i
You've had your downpipe for a while - still awesome? Still happy with it?
Thinking of picking one up!
      04-16-2015, 08:36 PM   #20
Dosturbos
55
Drives: 2017 F48 X1 MSport
If you want to impress me show me how you do a DP for an Xdrive 335i
      05-08-2015, 12:22 PM   #21
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
One of my friends remarked at an autocross "dude your car sounds like it's inhaling small children as it goes by"
I was like hell yeah
Appreciate 5
Powaup1253.00
      05-08-2015, 12:52 PM   #22
cmkde
36
Yeah the 235 is a great sounding car, I remember shocking quite a few people on the street when slamming the gas pedal. Just picked up an m4 and does it ever need down pipe treatment.
2addicts
