Sunroof error or wtf?
04-06-2014, 12:18 PM | #2 |
Rep 15
04-06-2014, 03:32 PM | #3 |
58
Rep 273
Drives: 2015 X5 50i, 2015 Macan Turbo
Does your sunroof operate fine?
04-06-2014, 03:59 PM | #4 |
435
Rep 686
Drives: 06 330xi (TRADED IN)
Not sure what the problem is, but to answer your question: Anti-trapping is a component for all auto-shut car windows and sunroofs that prevents kids, pets or drunken douchebags sticking their head outside from strangling themselves if it is inadvertently closed during automatic operation, where it would open back up if it detects resistance.
04-06-2014, 07:43 PM | #5 |
58
Rep 273
If your sunroof is operating normally then you probably just need to reinitialize the function.
Power up your accessory power - all dash lights on but engine not running. Make sure sunroof is closed. Push in and hold sunroof button for tilt mode, don't let go. Sunroof will tilt and after about 20 seconds it will tilt up another inch and back down. Continue holding button in. After about another 20 - 30 seconds the sunroof will reset open and close tolerances - it will tilt down and open fully and then close and then I think it will tilt up and back down again. When the cycle is done let go. Should be reset. Last edited by drmdvl; 04-07-2014 at 03:19 AM.. |
04-07-2014, 05:09 PM | #6 | |
78
Rep 1,241
Drives: 2016 BMW 340i
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
05-12-2014, 11:44 AM | #8 |
57
Rep 439
This fix should be DIY'ed and put in that section for fixing misalignment. I had my sunroof not close flush, but no error on dash. Searched, found this and worked like a charm.
05-12-2014, 04:54 PM | #9 |
56
Rep 325
Drives: Bmw 328xi 2008 Coupe
I have the same issue, but the sunroof does not operate as normal. Every time a direction is pressed it will move a bit and continue every time you press. Also my reset doesn't work ;(
Current 2008 Bmw 328xi Coupe Sport N51 /w 3 stage IM | VMR 710 w/ Conti DWS | AA Tune Stage 2 | AA Signature Exhaust | Red Cyba scoops | Lux V4 | Euro-box mod w/ Silicone intake hose | Eibach pro kit w/ Bilstein Sport | Carbon Fiber Hood powerdome | Mtech Bumper w/ Akyrim CF lip |
