Rear wheel spacers on an XI
03-29-2014, 01:36 PM | #1 |
88
Rep 366
So. I want to run wheel spacers in the rear of the car. But. The hub centric hub is pretty long. Longer than most spacers are wide. Are there specific spacers for the rear of the car?
Thanks ! |
03-29-2014, 02:05 PM | #2 |
GuidoDoc
17
Rep 211
Drives: Jeep Wrangler JKU
I was able to fit 12mm with no issues, no special type for rear.
'11 335i xdrive Performance Edition BSM/Black
03-29-2014, 03:09 PM | #4 |
321
Rep 710
Drives: 23 M3 Competition
I have 15mm on there now, switching to 20mm soon.
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
03-29-2014, 07:57 PM | #6 |
Fuck it dude, let's go bowling.
886
Rep 2,480
May want to check these new 15mm Rogue Engineering spacers out. Make me an offer
http://www.e90post.com/forums/showthread.php?t=956392
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
03-29-2014, 08:05 PM | #7 |
Rep 45
Drives: bmw 335xi e90
have 15mm on rear and 12 mm front on e90 335xi.nothing special!
03-29-2014, 08:32 PM | #8 |
319
Rep 1,023
I highly recommend THESE!
I have 15mm in the rear on my 335i, and will be doing the same sometime soon on my new-to-me x-drive.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
05-08-2014, 02:17 PM | #11 |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
Hey sorry to bring this one back but I had a question on 10mm spacers on the rear of my E90 XI. I've seen some places that they don't recommend using a 10mm spacer in the rear like with Turner's statement:
"A note about 10mm spacers: Any 10mm spacer is considered a custom fitment. The stock hubcentric lip on BMWs can stick out by as much as 11mm. This leaves a gap between the spacer and the hub which seriously compromises safety. We recommend using a larger spacer (12mm and larger do not have this issue) or check that the lip sticks out less than 10mm" With that said, I am looking to get 10mm spacers for the rear and was wondering if the spacers were 10mm hub centric would it be ok? Thanks!
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
05-08-2014, 07:18 PM | #12 |
56
Rep 1,464
Drives: 2009 BMW 335xi
You should more or less than 10mm. It is best to have some of the hub sticking out for proper alignment of the wheel. The wider spacers have an extended hub built in. 10mm and narrower spacers are just flat plates. VAC makes hub extenders for the front but none exist for the rear.
09-08-2014, 02:25 PM | #13 |
25
Rep 382
hello all so by reading your comments so its fine to put just rear spacers for xi or bigger in rear?
i just installed 19's 8.5 and 9.5 235/35 and 265/30 and dropped it also with coilovers. right now it sits really nice but i feel like it can still improve with spacers.. they guy who installed my coilovers said i can probably rock 10mms all around but i just read here that its not really good to put 100mm in the back? any advice will be appreciated.. gona measure my wheel gap also when i get home... |
09-19-2014, 03:55 PM | #15 |
13
Rep 185
09-19-2014, 08:12 PM | #16 |
Rep 24
Yes, they are H&R hub centric spacers. But without hub centric rings, trying to figure out which one to order,
