E92 with Spacers
03-25-2014, 12:10 PM | #1 |
14
Rep 135
E92 with Spacers
I know that this subject has been beaten to death with different size wheels and tires, but I've searched all over and can't exactly find a direct answer. For 18x8.5 et35 with 225 tires, and 18x9.5 et33 with 255 tires, what is the maximum size spacers that can I run without any rubbing and without fender rolling? My goal is to look as flush as possible but still functional as I drive it everyday. I'm lowered on coil overs, if that helps.
03-25-2014, 02:00 PM | #4 |
Out Boosting...
242
Rep 3,987
i think im going to try that sizing as well.
Alpine White M-Sport F30
03-26-2014, 08:53 AM | #7 |
56
Rep 325
Drives: Bmw 328xi 2008 Coupe
I got 12f 15r on 18' style 197 same tire sizes as you I believe.
front - 225/40-18 rear - 255/35-18
Current 2008 Bmw 328xi Coupe Sport N51 /w 3 stage IM | VMR 710 w/ Conti DWS | AA Tune Stage 2 | AA Signature Exhaust | Red Cyba scoops | Lux V4 | Euro-box mod w/ Silicone intake hose | Eibach pro kit w/ Bilstein Sport | Carbon Fiber Hood powerdome | Mtech Bumper w/ Akyrim CF lip |
03-26-2014, 09:49 AM | #8 |
78
Rep 1,353
Actually I'm even dropped on an H&R sports springs. Wheels are stock 220's 19/8.5f and 19/9r. Tires are still stock rft 19/225f and 19/255r Pirelli pZero RFT's. Offset I'm not too sure. I believe it's 35f and 37r if I'm not mistaken.
03-26-2014, 10:10 AM | #9 |
62
Rep 531
220's are ET 29 front, ET 23 rear. They're 8.5 front, 9.5 rear. People have trouble fitting these without spacers. How did you manage 12mm front and 15mm rear?
03-26-2014, 01:54 PM | #12 |
BimmerPost Supporting Vendor
2040
Rep 25,989
Check your gap.
VMR|Wheels | 714.442.7916 |
03-26-2014, 08:40 PM | #13 |
14
Rep 135
I've measured before, and I know that I have about 20mm of space to work with but I wanted to know if anyone had personally spaced out their wheels and how well they worked. I'm sure that it'll work though, 12.5F and 15R sound like they work well. Thanks guys!
03-26-2014, 08:41 PM | #14 |
14
Rep 135
03-26-2014, 09:26 PM | #15 |
101
Rep 912
honestly, the best way to do it its by measuring it yourself like mention before. That's the best straight answer you will get. If you have 20mm to work with go for those 20mm if you do not want to risk it go 15 mm or 18mm on the rear 12.5 front sounds good. hope that helps. I just don't want to see you like other members that once they installed they be like "o man I should of gone 5mm more"
03-27-2014, 04:25 PM | #16 | |
14
Rep 135
03-27-2014, 07:08 PM | #17 | |
101
Rep 912
Check out my built thread of my white beauty! http://www.e90post.com/forums/showthread.php?t=1045460
Follow me on Instagram! l_gomez1215 |
03-27-2014, 07:37 PM | #18 |
56
Rep 325
stock and no rub.
05-02-2014, 07:54 AM | #19 |
Rep 64
I have an e92 with 197's too. Do you experience more noise with spacers or more steering pull on shitty roads? That's what I am told can happen some times. Did you have to modify anything else? Thanks in advance!
2009 E92 328i - Jet Black - Fully Loaded - Sport Package - M3 lip spoiler - BMW Wheels Style 197
05-02-2014, 09:16 AM | #20 |
56
Rep 325
Haven't had any issues with noise, but the pull is slightly there but not bad enough to notice right away. I did put some anti seize between hub/spacer contact but not too much so don't know if that helped with noise cancellation.
05-02-2014, 09:48 AM | #21 |
Rep 64
mine is RWD. does anybody know if that would cause more or less pull? noob question: what is anti seize? lol. thanks!
05-02-2014, 12:23 PM | #22 |
88
Rep 509
Drives: 2016 435i
I just moved my 12mm up front and installed 15mm in the back. I'm on OEM style 189 wheels dropped on ST coilovers.
front is 18x8, et 34, rear is 18x8.5, et 37 I have been inching my way up to the point at which I am at but to be totally honest I will probably move to 18mm in the rear and keep the 12mm in front. That being said with Style 189 wheels 12mm/18mm seems to be perfect.
2016 435i MSport ZHP #85
